Shelby kicker subwoofer upgrade - Mustang Evolution
Old 04-05-2016, 05:43 PM   #1
Seanp94's Avatar
Has anyone upgraded their shaker 500 door subwoofers with the Shelby kicker upgrade kit?
Seanp94 is offline   Reply With Quote
Old 04-06-2016, 08:45 AM   #2
5pointYoBro's Avatar
That mike ruby Dood on Instagram has.
@mikeruby954
The ones in the front doors right????
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 04-06-2016, 02:31 PM   #3
I bought it and it def. makes a diff. I just took it out a few days ago because my car is on a diet. I have the amp and subs for sale
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 04-06-2016, 02:44 PM   #4
Seanp94's Avatar
You wouldn't happen to have a picture of them installed would you? How much are you looking to get for them?
Old 04-06-2016, 06:20 PM   #5
I dont have a pic of them installed and if I did you wouldnt know it, they bolt in the place of the others and the amp goes under the glove box, I have the wiring harness and amp and two subs, I paid alot for them but would let them go for half, maybe 225.00 pm me
Old 04-06-2016, 08:07 PM   #6
Seanp94's Avatar
I think we're talking about different kits. This is from shelby's eBay page Click image for larger version
Name:	ImageUploadedByMustang Evolution1459994837.157069.jpg
Old 04-06-2016, 09:38 PM   #7
Yellowblaze12's Avatar
I have them and they do make a good difference from the factory subs. My only complaint is the cheap feeling speaker grilles.
Yellowblaze12 is offline   Reply With Quote
Old 04-06-2016, 10:34 PM   #8
Seanp94's Avatar
I was worried about that. They almost look like they're Styrofoam?
Old 04-07-2016, 10:25 AM   #9
That's pretty cheap too for all 3 speakers.
Old 04-07-2016, 11:16 AM   #10
Shaker 500 door subs
I upgraded my shaker system. I didn't use any sub woofer in the doors. I pulled out the cheap subs and instead installed a pair of 6.5" Polk MM 651 series coax speakers. And Polk MM 571 5"x7" coax speakers on the top side in both doors. The sound is as different as night and day. I also have a 12" Polk sub in a sub woofer box in the trunk. I'm running everything with the stock navigation / sync unit. With after market Rockford Fosgate amps. And a Kicker EQ.
sbacowboy is offline   Reply With Quote
Old 04-07-2016, 12:23 PM   #11
KATO's Avatar
I have them in my Mustang front Speakers, both 6X8 and Subs. But my Rear are JL Audio 6X8/5X7. And JL 10" sub in Trunk.
Old 04-07-2016, 02:05 PM   #12
Did you have to buy something to bypass the factory amp?
Old 04-08-2016, 08:42 AM   #13
Alerotaz's Avatar
I swapped them out. the 2om vs 4 omh issue makes them no very loud. Since I have the Sync mach system I am looking for someone who can actually splice in an aftermarket amp.
Alerotaz is offline   Reply With Quote
Old 04-08-2016, 12:45 PM   #14
Would these fit in the doors???
JL Audio 6W3v3-4 W3v3 Series 6.5" 4-ohm subwoofer at Crutchfield.com
Old 04-09-2016, 07:26 AM   #15
Region: Nevada
Tried to PM you about this, but your inbox is full.
daustin is offline   Reply With Quote
Old 04-12-2016, 05:00 PM   #16
WJBertrand's Avatar
I've got the 8" Shelby kickers in the doors. Definitely provide a cleaner bass. The way that the '13 Shaker system is set up though has the OEM subs running off of their own amp and the OEM speakers are dual voice coil. Substituting in the single voice coil Shelby's results in less volume output unless you also add an additional amp. Turning up the bass EQ also works well.
Instead of doing that, I ended up buying the Shelby Kicker powered trunk sub and the under dash amp that powers the four other interior speakers (also upgraded) but not the door subs. I think I ended up with a pretty good sounding system. The door subs kind of provide the middle bass while the trunk sub handles the heavy hard hits.
Now if I could just figure out how to stop my rear view mirror rattling from the bass!
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 04-12-2016, 05:24 PM   #17
There isn't really a way to get the rattling to stop. My 2 W3s used to rattle the s*** out of my rear view mirror
Kicker Shelby Subs Socal Stangman Mustang Audio & Video 2 08-05-2014 01:58 PM
Shelby Kicker Door Sub Wiring question WJBertrand 2011-2014 Mustang GT 1 07-25-2014 09:40 PM
Kicker Upgrade kit thecos54 Mustang Audio & Video 6 08-17-2013 11:50 AM
Got two Kicker 12s Dom Mustang Audio & Video 1 03-12-2004 09:07 AM
Just got me a KICKER 500SS Amplifier Autobadges.com Mustang Audio & Video 12 11-11-2003 06:11 PM
06:38 AM
