Another tire and offset question - Mustang Evolution
Old 04-06-2016, 07:16 PM   #1
Whats up guys, first post here. I have a 2012GT with 20x10.5 in the rear. The offset is +43. My question is if 305/35zr20's will clear the fender without rubbing. The car is lowered 1.5" all around. I also just installed an adj panhard bar so the rear wheel isnt nearly as close as it looks in the picture. I currently have a set of worn 275/40's on the rear. Any help or input is greatly appreciated. Thank you for your time
GTaggie is offline   Reply With Quote
Old 04-06-2016, 09:07 PM   #2
The_Chech's Avatar
You'll touch with that one, my 20x10 with a 305 gets very close with +45 offsetClick image for larger version
Name:	ImageUploadedByMustang Evolution1459998429.588909.jpg
2011 Kona Blue Gt
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 04-06-2016, 09:46 PM   #3
Thanks for the reply!! Do you think the extra half an inch in rim width would keep tire bulge to a minimum to give it those extra 2mm clearance? What brand tire are you using?? Oh and youve got one badass mustang btw!!
Old 04-07-2016, 07:58 AM   #4
Diehard's Avatar
Tires sectional width increases with rims increase.
Tire Rack says, "The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
You should check out this site. Allows you to compare how change will effect tire clearance. But you have to measure existing clearance to have something to compare it to.
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
Old 04-10-2016, 03:29 AM   #5
Sakol's Avatar
I'm curious, what brand of tires are your 275/40s?
Sakol is offline   Reply With Quote
Old 04-10-2016, 04:16 PM   #6
k1DBLITZ's Avatar
Hey GTaggie, I know you were asking for help, but it turns out you can help me!
Would you might taking some close up picks of your rear wheel/tire combo? (particularly from the side profile, trying to determine bulge) I've been debating on sizes myself with a 19x10.5 wheel in the rear.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 04-10-2016, 05:50 PM   #7
Diehard's Avatar
FYI
Here's a 275/35 on a 10.5" wide rim from another thread.
2012 RS3 Roush with 20X10.5 Niche Intake and VMP 675HP Tune.
No bulge. In fact, as you can see it may be a bit less then the wheel width.A 275 tire width is roughly 10.8"+/-, while the outside width of a 10.5" rim is close to 11". And I think this picture kinda of reflects that. Should ask AM why they recommend that tire size for that rim width, based on this abnormal appearance.
Hopefully you are able to zoom in on this pic for a good look.
EDIT: Apparently a 275 is near the limits of the recommended width range, and as a result will widen a couple of tenths of an inch above it's normal width when mounted on a 1" wider rim.
Old 04-10-2016, 06:23 PM   #8
k1DBLITZ's Avatar
Thanks Diehard! That thread helps a lot!
Now I can see the difference between a 275 and 305 on the same size wheel.
Old 04-11-2016, 09:43 PM   #9
Pardon the dirty car but this is the only one i have from an angle that kinda shows tire bulge. I actually dropped her off at the body shop today (new hood), if not i would've snaped a better one.
Old 04-11-2016, 09:54 PM   #10
Nooooo ideeeeaaa to be honest haha. Some random economy tires i got for free from my wheel shop for my hardships with them, but ive actually seen Mickey Thompsons in 275/40zr20's
Old 04-11-2016, 10:00 PM   #11
k1DBLITZ's Avatar
d00d... I'm not gonna lie... that is a really.......really bad pic. LOL. So many artifacts... thanks for trying though.
From that angle the tire doesn't look like it is peeled back...
Old 04-11-2016, 10:04 PM   #12
Haha i know. I'll try to get you a better one sometime this week
Old 04-12-2016, 02:41 PM   #13
There you go
Old 04-16-2016, 09:26 PM   #14
hdez41's Avatar
There you go
So that's a 275/40 on a 20x10.5 rim?? Looks good I've been wondering if that would fit or if there was any problems cause I was wanting to go that route
hdez41 is offline   Reply With Quote
Wheel offset question RUNNWLD 1996-2004 Mustang GT 3 11-18-2012 10:51 AM
Wheel/Tire Question 17x9+24 offset doug5.0 Mustang Wheels & Tires 4 10-07-2012 08:03 PM
Wheel offset question. Napoleon85 1996-2004 Mustang GT 5 03-22-2012 07:58 PM
Offset question Rolltide 2011-2014 Mustang GT 2 01-24-2012 11:13 AM
OFFSET question DMAC Mustang Wheels & Tires 0 08-07-2004 12:17 PM
12:59 AM
