Advice on DD street tire for 18x10(taller than 27.5) - Mustang Evolution
Old 04-10-2016, 02:46 AM   #1
Jvibe92's Avatar
Well right now I've been running a 285/40 nt555 with 3.73 gears and I am actually hitting 7800 in 4th before the finish line. I need a taller tire that I can also use for DD purposes. Considering I drive 1000 miles a month on average, anything that can last 15k is what I'm looking for.
Is 295/45 or 305/45 too tall? I was feeling that 295/45 nitto nto5 might be a good option, or maybe some nitto nt555r 305/40
Any suggestions? If I can bring down my 4th gear trap RPM to 6800 RPM then I'd be happy but not sure what size can achieve that
Jvibe92 is offline   Reply With Quote
Old 04-11-2016, 08:39 AM   #2
I have the MT 325/50s on the back of my 2014 GT Mustang. But that's on a 15" wheel. Huge tire but with the relocation brackets they fit nicely. Looks great from the rear. Sorry don't know how to post pics.
bodon is offline   Reply With Quote
Old 04-11-2016, 10:06 AM   #3
Scott2's Avatar
I switch between 325/50/15 (27.8" dia) and 315/35/20 (28.7" dia) The 315 are on the right.
My differential has been shortened 1" per side and both sets of wheels tuck nicely.
Old 04-12-2016, 12:54 AM   #4
Jvibe92's Avatar
How do nt05 last? Curious vs nt555R. I know nt555R last like 10-15k depending on how you drive.
Old 04-12-2016, 08:02 AM   #5
Diehard's Avatar
With regard to your RPM question...
Excluding consideration for the effects of torque changes to your ET, etc., to achieve 6800 RPM at what I estimated your speed at about 103 MPH, would require a substantial change in tire size. Like a 32" dia tire (Like a 305/50R20) I assume you have 19" wheels now.
It would be approximately equivalent to going from 3.73 gears to 3.25 gears.
Old 04-12-2016, 01:57 PM   #6
Jvibe92's Avatar
Well right now I'm trapping 116 at the limiter. I'm thinking of going 295/45/18 or 305/45/18. I think the 295 ones are 28.4 in tires but I've heard they run shorter (nt05)
Old 04-12-2016, 08:00 PM   #7
Diehard's Avatar
Hmmm....
I used an on-line calculator with the following input...
7800 RPM
285/40R19 Tires
Rear gears: 3.73
Gear ratio in 4th gear: 1.69(Manual)
Gave me calculated speed of: 103 MPH
So 116 to 103 MPH is a substantial difference.
Something's not right.
Old 04-12-2016, 10:56 PM   #8
Jvibe92's Avatar
4th gear for the MT82 is 1.32
I ordered nt05 295/45/18 since the were readily available here. I'll go 555r in 305/40/18 after these
Old 04-13-2016, 08:02 AM   #9
Diehard's Avatar
Not only did I screw up the 4th gear ratio, I had the wrong wheel size.
It will be interesting to see how much that brings down the RPM and what effect it has on ET and trap speed.
Old 04-13-2016, 02:02 PM   #10
Beviking's Avatar
Nah, you just "mis-keyed" Diehard. Happens all the time.
I don't track/strip at all and I'm interested in your results!
Beviking is offline   Reply With Quote
Old 04-13-2016, 03:17 PM   #11
Diehard's Avatar
I've never done either but the strip is on my bucket list.
New gears or new taller tires? Jvibe92 2011-2014 Mustang GT 9 05-12-2015 07:31 AM
Taller tire for a 01 new edge Kingmidas87 Mustang Wheels & Tires 10 06-09-2013 03:09 PM
Wider and a little taller tire. Kingmidas87 Pre-2005 V6 Mustang 4 06-08-2013 08:22 PM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
Taller headrests? MonteCitan Mustang Parts for Sale and Wanted 4 07-01-2009 09:54 AM
11:57 AM
