Would a 275/40 tire fit on a 20x10.5 rim?? - Mustang Evolution
Old 04-16-2016, 10:34 PM   #1
hdez41's Avatar
Hey guys I currently have 295/30/20 nitto motivo tires on my 12 gt on kmc 20x10.5 rims. I wanted to know if I would have any kind of issues putting a 275/40 or 275/35 tire on it. I also have eibach sportline lowering springs. I was looking into getting some nt05s for better traction.
hdez41 is offline   Reply With Quote
Old 04-16-2016, 10:35 PM   #2
hdez41's Avatar
Forgot to mention my offset is 35mm
Old 04-17-2016, 12:07 PM   #3
Yes that fit. It has a bit of a round off. I have this set up and I like it. The rounding isn't to bad. But it will fit.
2013BlackBeast is offline   Reply With Quote
Old 04-17-2016, 12:29 PM   #4
hdez41's Avatar
Would you mind posting some pictures kind sir.
Old 04-17-2016, 12:37 PM   #5
I would but don't know how to. Can you do it on the app? What app do you have also?
Old 04-17-2016, 12:40 PM   #6
hdez41's Avatar
I have the app on my android phone. When you reply there's an addition sign and you just click it and then at the top right corner it gives you options to attach files. Anyhow you said you have the 275/35 or 275/40 and your rim is 20x10.5?
Old 04-17-2016, 12:56 PM   #7
Hopefully this worked lol. Yes 20x10.5
Old 04-17-2016, 01:02 PM   #8
hdez41's Avatar
Yes it did. Thanks. It doesn't look bad at all. Are you lowered? Any rubbing?
Old 04-17-2016, 01:04 PM   #9
Yes. I lowered it 1.5 all around and no rubbing at all.
Old 04-17-2016, 06:56 PM   #10
hdez41's Avatar
Good to know I'll get those tires then thank you.
Old 04-18-2016, 01:35 PM   #11
A Faster Horse's Avatar
Your Beast is sick, man! Sick Black Beast! LOL
I see what you mean by the rounding... doesn't look like its too bad though huh?
A Faster Horse is offline   Reply With Quote
Old 04-18-2016, 02:00 PM   #12
Thanks. It's not at all. I like the way it looks. I could have gotten the bigger size but decided to keep them.
Old 04-20-2016, 09:18 AM   #13
noldevin's Avatar
I wouldn't undersize with Nittos, they tend to run small as it is. Why not run the 305/30?
noldevin is offline   Reply With Quote
Old 04-20-2016, 09:35 AM   #14
275 wide will fit on a 10.5" rim but the rim lip will go out past your sidewall. And that is with a big 275... with a Nitto it'll be even worse. I would run at least a 295 Nitto.
Old 10-07-2016, 04:55 PM   #15
Dans5oh's Avatar
Scotty, I searched but couldn't find an answer to this. Do you know what is the largest rear tire that can fit on a Brembo rim? I have a 2014 GT with the Brembo's. Would a 275 or even 295 fit on the brembo rim? thanks.
2014 GT Premium, Sterling Grey Metallic, 6sp, Brembo's, 3.73's, Comfort, Security, Spoiler Pkgs. Barton short shifter w/two post bracket, Redline hood struts, AM shifter ball, BMR lca, Roush axle backs.
Dans5oh is offline   Reply With Quote
Old 10-08-2016, 12:59 AM   #16
DallasStang77's Avatar
10 inch rims are best for 275-285 tires.
10.5 are best for 295-305.
If you size the too small you end up stretching the tires out and you will run into a myriad of problems.
The sidewalls are meant to offer stability. When you angle it you lose the ability of the tire to keep its structural integrity on corners and even straight line.
In corners, you will have less grip because the sidewall isn't there.
Honestly, Nitto NT555 G2 305/30/20 will be a perfect fit for your 10.5" rims and will give you max performance for your setup (short of DR or slicks).
Old 10-09-2016, 01:21 PM   #17
k1DBLITZ's Avatar
For comparison, I'm running 295/35/19's on a 10.5 in the rear. (fronts are 275/35/19 on a 9.5in wheel)
I like the twisty's as much as the straight line so I opted for 295 over a 305.
I have not been disappointed with straight line traction in the least. They grip and go.
When I bought those wheels, I spent some time doing research trying to figure out what size tires to put on them.
You can follow that journey here: 19x9.5 and 19x10.5 - Tire Options? and learn a lot in the process!
Essentially you will learn how to find the information you need from tirerack in regards to tire sizes, and use that in conjunction with a wheel/diameter calculator to find your optimal size.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 10-30-2016, 06:44 PM   #18
13Mustang5.0's Avatar
yep
13Mustang5.0 is offline   Reply With Quote
Tire size 20x8.5 and 20x10 dieseldog 2011-2014 Mustang GT 0 02-23-2014 07:56 PM
WTT/WTB .... Rim or Rim & Tire swap back n a stang Mustang Parts for Sale and Wanted 0 10-19-2012 04:47 PM
Whats the widest tire you can fit on a stock rim ? SloMoGT 1996-2004 Mustang GT 15 09-10-2012 05:30 PM
275/60r15 on 10" Rim? SilverBullet12 2011-2014 Mustang GT 0 08-21-2012 09:34 PM
275/35R19 front & 275/40R19 rear tires combined? M3hunter 2011-2014 Mustang GT 4 07-29-2012 05:15 PM
06:02 PM
