Whiteline UCA - Mustang Evolution
Old 04-19-2016, 05:37 PM   #1
Joaquin_ii's Avatar
Whiteline UCA
Has anyone installed the whiteline UCA? I am going to be installing it this weekend and was wondering if anyone has adjusted it because the adjustment instructions are a bit confusing
Joaquin_ii is offline   Reply With Quote
Old 04-19-2016, 07:39 PM   #2
Diehard's Avatar
I can't help, I'm afraid. I do recall someone else asking for help on this same item, and probably for the same reason.
They appear to use an eccentric bolt(similar to the way a camber bolt is used to change camber.)
These instructions to me leaves me wondering how do you adjust pinion and the eccentric on the UCA BEFORE it is install to the vehicle? At least that's the way they make it sound. ??
"8. Prepare Whiteline Arm and Mount for installation by adjusting pinion angle of eccentric crush tube to desired position. Then tightening the lock nut up against the mount."
But apparently the eccentric is used to make the adjustment(couldn't be a hell of a lot) and then you lock it in with the lock nut.
Old 04-19-2016, 08:18 PM   #3
Joaquin_ii's Avatar
Thanks bro i think I'm going to try to write a review and video for others to see but thanks bro
Old 04-27-2016, 02:26 PM   #4
When I bought my car it came with it, I had a problem where one of the bolts fell out and it was loose had to order a bolt from Home Depot because no one had it in town, and then had to take it off and put in the new bolt. They also claim it's adjustable but it doesn't make any sense on how it's adjustable.... It doesn't lengthen or shorten, it just squeezes the bushing to make it stiffer I guess? But I see no benefit in that.
Massery94 is offline   Reply With Quote
Old 04-27-2016, 02:44 PM   #5
Also if you drive over a freakin leaf it will squeak...
Old 04-28-2016, 03:46 PM   #6
k1DBLITZ's Avatar
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 04-28-2016, 04:47 PM   #7
Diehard's Avatar
You can see the eccentric piece within the bushing. I would assume you can position that for what appears to be a small amount of adjustment, by turning the bolt.
Old 04-28-2016, 06:17 PM   #8
Joaquin_ii's Avatar
I gave up on this uca I just bought the bmr one
Old 04-28-2016, 06:19 PM   #9
Joaquin_ii's Avatar
I tried adjusting on the car but even the directions don't say what way to turn to extreme the arm.
Old 04-28-2016, 09:14 PM   #10
Yeah the "adjustment" makes no sense.
Old 04-29-2016, 08:11 AM   #11
Joaquin_ii's Avatar
Yea I said **** it and just bought some other one
Old 04-29-2016, 02:48 PM   #12
Diehard's Avatar
Did you get the BMR Mounting Bracket with it. I believe that's typically recommended.
Old 04-29-2016, 05:05 PM   #13
Joaquin_ii's Avatar
Yes I did
Whiteline Adjustable UCA Question Fax22 2011-2014 Mustang GT 1 02-20-2016 11:12 AM
For Sale: New Whiteline UCA w/GT500 or CE Poly Carrier Bushing olerodder Mustang Parts for Sale and Wanted 3 11-04-2015 07:53 AM
For Sale: Whiteline UCA w/either OE or Poly Carrier Bushing olerodder Mustang Parts for Sale and Wanted 10 09-01-2015 09:43 PM
For Sale: Whiteline (UCA) rear upper control arm - adjustable KonaPony12 Mustang Parts for Sale and Wanted 13 05-18-2015 10:37 AM
10:21 AM
