Reducing the weight of a Mustang. - Mustang Evolution
Old 04-24-2016, 04:33 PM   #1
stanggtcs's Avatar
I would love to shave off 1000 lbs. but this is not realistic without spending big dollars on carbon fiber this n that. How about a more obtainable goal of 250 lbs.? Replace the front seat with a light weight racing seat (no passenger seat) and remove the rear seats, ac, spare tire, jack, lug wrench, some of the carpeting and anything that doesn't have a purpose. What is the ballpark gain for weight reduced? 100 lbs equals 10 horsepower gained? Not really added hp but there is less weight to propel down the moway. Fell free to throw out suggestions.
Scott
2014 GT/CS 6spd., Ford Racing handling pack, Flowmasters out the rear.
stanggtcs is offline   Reply With Quote
Old 04-24-2016, 04:49 PM   #2
Grabber Blue5.0's Avatar
Why are you wanting to shed weight? For the drag strip?
Old 04-24-2016, 04:58 PM   #3
stanggtcs's Avatar
@Grabber Blue5.0 -No particular reason other than to give it more get up n go. A different approach versus tunes, exhaust, intakes etc.
Old 04-24-2016, 05:18 PM   #4
Light weight brakes, wheels etc etc. You can remove the front sway bar and the axle weights. You have a full weight premium C/S though so you're already off to a bad start.
Old 04-24-2016, 05:40 PM   #5
stanggtcs's Avatar
No nav or glass roof. I'm assuming the glass roof is heavier. I don't really need heated leather seats, the rears are going first.
Old 04-24-2016, 06:06 PM   #6
No interior, no options, lexan glass, k member, manual steering, no sway bars, CF wheels, DS, Shedding weight is about the cumulative affects of losing many small weights. Usually nothing big. The glass roof, for example adds a whopping 40 pounds to the car, becaue it isn't glass, it's actually high impact polycarbonate plastic. Back seat, with everythng? 35 pounds.
Stock wheels are heavy as hell, as is the stock K member and stock front seats but, the rest of the losses will be incremental and you will turn the car into something you may not like or want to drive in the end, if you go hard at this.
Old 04-24-2016, 06:39 PM   #7
c_rizzle's Avatar
I've lost about 100 lbs, and my car looks completely stock.
And most of the weight loss I did was in unsprung and/or rotation mass, so the effect is more like 4x the normal weight loss.
Here are my changes:
upgrade to Brembos w/ 2-piece front rotors -5 lbs x 2 corners = -10
2-piece Girodisc rear rotors -4 lbs x 2 = -8 lbs
lightweight wheels - 9 x 4 = -36+ lbs
tubular radiator support = - 10 lbs
Steeda billet LCA's = - 6 lbs
1-piece alum. driveshaft = - 20 lbs
GT500 axleback exhaust = - 6 lbs
steeda adj. panhard = - 1/2 lb
soundtube removal = -1/2
TOTAL = 97 lbs weight loss
All of that with out sacrificing any comfort. And meanwhile improving performance A LOT. The wheels and driveshaft where the biggest difference. I could actually feel the difference after those mods. The expensive (b/c of all 2-piece rotors) brake mod I could only really feel the difference in better stopping power.
I was thinking about doing these next: http://www.jpcracing.com/2010-2014-f...pport-package/ - 24 lbs or at least the front one, as thats where the car needs to lose weight the most.
c_rizzle is offline   Reply With Quote
Old 04-24-2016, 06:56 PM   #8
Comparatively, these cars aren't heavy when you look at its direct competition.
My old car was fully loaded and on fumes t was 3680, with ME in it. I'm 150. My new 14 is an auto and is about 40 pounds heavier with the same option load. Finally the new Camaro has shed its pork but the Challenger is 4000+, ludicrous. My old 74 Trans am with iron, steel and fibreglass from the front to the back, weighed 3700 with wind up windows, no ac, or power options of any kind, hehe.
Old 04-25-2016, 02:53 AM   #9
stanggtcs's Avatar
@c_rizzle, thanks for your list of light weight mods.
@5LHO, was thinking the same, if I go full tilt on this endeavor will I enjoy a stripedd down interior? I certainly don't need back seats though.
Old 04-25-2016, 08:31 AM   #10
Jza1736's Avatar
Vented Cf hood cost me 1600. 20 lbs saved and helps cool the engine.
Sent from my SM-N920P using Tapatalk
Jza1736 is offline   Reply With Quote
Old 04-25-2016, 08:40 AM   #11
Gotcha. Keep in mind, pulling things means nothing works, codes get thrown, weirdness. Stuff doesn't go back in right, etc. It's not a race car....it is it? You tell us.
Old 04-25-2016, 02:02 PM   #12
Scott
It really isn't worth taking apart you car to save about 100 pounds. Wheels and driveshaft would probably be the best thing you can do. Tires usually differ by a couple of pounds, but you start spending a lot for little gain. Gears would be good way to feel a little more get up and go. Remember some day you may want to sell it and you don't want to ruin your resale either.
2013 RedMustang is offline   Reply With Quote
Old 04-25-2016, 02:23 PM   #13
stanggtcs's Avatar
@2013 RedMustang, Gears are in the works, currently has 3.31's, 3.55's would wake it up.
Old 04-25-2016, 05:02 PM   #14
Going from 3.31's to 3.55's would be a waste of money. Honestly your approach to all of this isn't very well thought out.
Old 04-25-2016, 05:43 PM   #15
If you want light weight. Build a Body In White car
Old 04-25-2016, 06:23 PM   #16
Beviking's Avatar
???? Please help reduce my ignorance????
Axle weights... Any negatives to removing those?
Beviking is offline   Reply With Quote
Old 04-25-2016, 07:04 PM   #17
Along with the axle weights, who needs any tires or wheels too?
Old 04-25-2016, 09:36 PM   #18
TommyV's Avatar
Originally Posted by Beviking View Post
???? Please help reduce my ignorance.
It looks like an aluminum body.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 04-26-2016, 05:56 AM   #19
c_rizzle's Avatar
Remove everything! just start with the empty shell & rollcage, then only add back in what is absolutely necessary... (no extra wires, wiring harnesses, insulation, AC, radio, etc.)
Old 04-26-2016, 07:21 AM   #20
audioAl's Avatar
I've done driveshaft & wheels and will do brakes next, but not much more for me. Research is your friend. I found Optic Armor for glass replacement $500.00 windshield.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 04-26-2016, 07:48 AM   #21
REG
I'm think about adding a supercharger next winter, this might be ideal, since the bumper has got to come off anyhow.
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 04-26-2016, 08:45 AM   #22
???? Non sequitur...
Old 04-26-2016, 10:17 AM   #23
king_13's Avatar
Take out the AC, I would, I've only used mine 5 times in 3 years.
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 04-26-2016, 10:38 AM   #24
Beviking's Avatar
Gotcha, thnx!
That's what I was thinking TommyV but didn't want to assume.
changed the oil from a 20 weight to 30 weight SangheiliSpecOp General Mustang Discussion 5 01-07-2016 12:14 PM
Glare reducing mat for dash steve63 2011-2014 V6 Mustang 11 05-18-2015 02:19 PM
reducing intake and exhaust reversion Dubau2 2011-2014 V6 Mustang 2 01-08-2015 05:33 PM
Reducing Rattling from Window Switches Kustumb Mustang Paint, Appearance & Detailing 1 02-05-2014 01:17 PM
Reducing Wind Noise/Resistence Kustumb 2005-2010 V6 Mustang 6 11-13-2013 07:33 PM
06:45 PM
