Cylinder 1 missfire code, help - Mustang Evolution
Old 04-26-2016, 06:43 PM   #1
yunior32's Avatar
Well, i have a cilinder 1 missfire code, my wife had placed 91 oct on my car which is tuned for 93 oct, it was driven hard and according to bama it could be a spark plug that went bad or the coil, i replaced the spark plug and the code is still on, could it be i have to replace the coil as well? I dont want to just buy the coil which is 70$ and not solve the problem? Anyone else hd this issue in the past?
Sent from my SM-G900P using Mustang Evolution mobile app
yunior32 is offline   Reply With Quote
Old 04-26-2016, 06:46 PM   #2
yunior32's Avatar
Also, engine has like a lgging motion kind of like if it had cams
Old 04-26-2016, 06:57 PM   #3
Grabber Blue5.0's Avatar
Switch the #1 coil with a different one. If the misfire follows the #1 coil you know it's that.
Did you clear the code after replacing the plug?
Old 04-26-2016, 07:03 PM   #4
yunior32's Avatar
Yes, i cleared the code right after seitching the plug, even retuned he car. I will go ahead and switch the coil to cylinder 2, but if it is the coil wouldnt it damage my spark plug on cycinder 2?
What if its not the coil? What would i check next? The injector?
Old 04-27-2016, 12:44 PM   #5
UrMaster's Avatar
Might have damaged a piston from detonation...
Sent from my SM-G928V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 04-27-2016, 06:01 PM   #6
RCrumb's Avatar
It sounds like a bad coil, I assume the plug you put in was the right temp range, either way that will only throw a code not kill the cyl. Test the #2 coil in place for functionality with a meter. Compare to others and with luck you have your problem.
RCrumb is offline   Reply With Quote
cold engine missfire? 1shotkllz 1996-2004 Mustang GT 7 08-03-2012 04:16 PM
NIGHTMARE MISSFIRE! 04silver 1996-2004 Mustang GT 11 05-03-2011 11:45 AM
Cylinder 4 missfire BigSteve305 Pre-2005 V6 Mustang 24 02-25-2011 09:59 PM
P301 Missfire Cyl. 1 BruThru2002 Pre-2005 V6 Mustang 3 06-06-2007 08:40 AM
Missfire Cylinder 1 BruThru2002 Pre-2005 V6 Mustang 12 05-15-2007 04:36 PM
03:33 AM
