Now Available -Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) - Mustang Evolution
Old 04-29-2016, 12:02 PM   #1
tj@steeda's Avatar
Hello All:
You asked ... we listened!
We are now offering the Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) ... you can check it out here - Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) | 555-7023 | Free Shipping!
Product Benefits
Improve clutch pedal engagement feel
Modulate your clutch engagement with ease
Piano wire construction with high tensile strength and high elastic qualities
Consistent spring rate and minimal sag even after repeated use
More linear clutch feel
Complete replacement of factory 200 lb/in clutch assist spring
Avoid slave cylinder damage due to removal of stock clutch spring
Steeda quality, backed by a lifetime warranty
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 04-29-2016, 03:00 PM   #2
I have a question about this. I've read that people say the pedal is how a bit "heavier" than with the stock clutch. Isn't this spring pushing the pedal back out? If the spring were lighter, than i'd assume that the pedal feel would also be lighter? Kinda confused but interested in the spring! Thanks
beef97 is offline   Reply With Quote
Old 04-30-2016, 07:17 AM   #3
tj@steeda's Avatar
Yes, it is indeed HARDER to press the clutch down with our spring offering.
The main difference is it allows you to "feel" the engagement and disengagement better.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 04-30-2016, 08:16 AM   #4
oxford5pointoh's Avatar
Ordered mine last night. Steeda FTW
Old 04-30-2016, 09:21 AM   #5
tj@steeda's Avatar
Here is a review of the spring - We Test the Steeda Mustang Clutch Assist
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 04-30-2016, 09:43 AM   #6
TJ, the 3.7 spring is much ligher than the GT spring. Is the 35 lb/in 15-16 spring compatible with the 11-14? for those that want a very minimal spring (The assist spring setups look identical 10-16).
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 04-30-2016, 09:50 AM   #7
tj@steeda's Avatar
I will have to inquire ... stay tuned.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 04-30-2016, 10:50 AM   #8
Does this assist with the high RPM clutch sticking issue?
SVOGT302 is offline   Reply With Quote
Old 05-01-2016, 04:51 PM   #9
I ordered but did NOT get free shipping.
Old 05-01-2016, 04:53 PM   #10
Free shipping is on orders over 99 bucks I believe
Old 05-01-2016, 05:54 PM   #11
TommyV's Avatar
Just ordered one, thanks.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 05-02-2016, 03:20 PM   #12
tj@steeda's Avatar
Negative - the 11-14 spring setup is completely different from the 15+. The lengths and diameters are all different.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 05-03-2016, 09:53 PM   #13
Region: New Mexico
Anyone know. .. that'd be awesome.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 05-05-2016, 05:48 PM   #14
RaceRed2014's Avatar
I put mine in today. Had a heck of a time until I got a helper to push in the clutch. It definately feels more linear to me. I am happy with it. Will have to drive it more though.
One thing that happened during my install is that center shaft on the top black mount broke off when the spring popped out of the top cradle. It now has nothing other than the spring to keep the top and bottom spring perches straight. Makes me wonder if the spring is going to shoot out of there one day.
RaceRed2014 is offline   Reply With Quote
Old 05-06-2016, 12:10 PM   #15
tj@steeda's Avatar
This may help with future installs & feedback regarding the spring
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 05-06-2016, 07:56 PM   #16
Got mine today and installed it. Comes out pretty easy. Going back in was a bit of a beeyotch. Need like one more arm and need to be half my current size.
Name:	ImageUploadedByMustang Evolution1462585744.963027.jpg
Compared to stock (holy crap that thing is a beast)
Name:	ImageUploadedByMustang Evolution1462585785.638541.jpg
For anyone doing this, here is a tip/trick I used for reassembly. I should have taken a pic but I was too dang happy to get it back in once I did this.
Take the bottom white plastic perch, put the new spring on it, then put the black plastic spring perch on the top of the spring. Get a nice long zip tie or put 2 together. Route it through the top of the black plastic piece under the metal pin. Then route it around the bottom white plastic piece and compress it as much as you can and pull the zip tie. Be careful because it will want to walk off the bottom piece of it isn't centered. Once you get it compressed all the way then just slip the white plastic piece on the bottom back on, depress the pedal and the top piece should slip right into place. Then let the pedal go, cut the zip tie off and your done. Trying to compress it while you are down there and pushing the pedal in all at the same time is for the birds.
New spring is pretty sweet. I'm enjoying the new feel.
Old 05-07-2016, 08:37 PM   #17
It's just too bad they didn't do a 35lb/in sprung for the 11-14. That 95 lb/in still looks beefier than the 3.7 spring or at best very similar rate. This is definitely not geared towards anyone other than the 5.0 unlike their spring for the 15+.
Old 05-08-2016, 04:36 PM   #18
There's a few youtube video;s out there too....
Now that the rain finally stopped, I'll do mine tomorrow.
Old 05-09-2016, 08:43 AM   #19
noldevin's Avatar
I just got this spring as well. The spring itself feels fantastic (though I feel like I have to relearn the clutch now).
It pretty much eliminates the springy uneven feel the stock spring gives you near the center of travel, but really doesn't feel much harder to push at all. Great balance and great job by steeda.
The downside - I didn't have the needle nose vicegrips or a helper, so I decided to disconnect the pedal from the master cylinder (as can be seen in some of the youtube videos for this...) and pull it up further to release the spring. Made removing the spring much easier, but I somehow managed to damage the master cylinder in the process and now it is leaking. So yeah I'll be replacing that master cylinder whenever the replacement shows up...
Moral of the story, be very careful if you try an alternate installation method.
noldevin is offline   Reply With Quote
Old 05-09-2016, 11:19 AM   #20
Originally Posted by noldevin View Post
I somehow managed to damaged the master cylinder in the process and now it is leaking. So yeah I'll be replacing that master cylinder whenever the replacement shows up...
Yea sometimes things just go wrong in the pursuit of better performance. For me it was the inner shaft on top spring mount breaking off during uninstall. Ford sells them but I have to buy the whole pedal assembly. It will be here tomorrow. I feel your pain.
Old 05-09-2016, 11:21 AM   #21
noldevin's Avatar
The master cylinder wound up costing me $150. I also ordered the clutch safety switch since it's dripping on that and I don't want to have to wait for another order if it fails in the meantime.
It wouldn't be so bad if my daily didn't also have a failing wheel bearing at the same time lol
Old 05-09-2016, 11:29 AM   #22
The pedal assembly costs $130 and includes both the clutch and brake pedal. I am hoping I can sell it once I get the part I need off of it. When the parts guy told me that I needed to buy the whole pedal assembly I was kind of worried that it was going to be really expensive. It was but not overly so. I was thinking more in the $300 plus range. I could live with my problem but I want my baby perfect.
Old 05-09-2016, 12:01 PM   #23
noldevin's Avatar
I think my buddy wound up breaking the same part as you and just decided to live with it like that lol
Old 05-09-2016, 07:09 PM   #24
tj@steeda's Avatar
Appreciate the feedback!
Yes, this is one of those small - tricky - but very rewarding parts!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 05-10-2016, 04:41 AM   #25
Put mine in yesterday without any real issues. Used an adjustable hiking pole between clutch & steering wheel to hold it down which worked well.
Although I didn't drive around much, clutch operation feels a bit smoother & works well.
I heard spring removal doesn't help for the high RPM sticking issue so this probably doesn't either but I do like it. Over the winter I put in a braided clutch line which I hope addresses that. We'll see shortly.
Old 05-14-2016, 10:31 AM   #26
jayochs's Avatar
wrote to steeda, got no response.
i just got this for my 3.7 and upon doing installation realized how much lighter the 3.7 spring is from the 5.0. i didn't even put this in yet, but i'm feeling like i wasted my money.
is there any point whatsoever in even attempting to install this on my 3.7??
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 05-14-2016, 11:26 AM   #27
Robostang's Avatar
Seems to be a theme here. I wrote to Gus last week with a simple question and haven't heard back. They used to be very responsive.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 05-14-2016, 01:21 PM   #28
IIRC Gus hasn't been with steeda anymore for well over a year.
Old 05-14-2016, 01:34 PM   #29
jayochs's Avatar
well, I got no response so i give up with this spring. gonna contact them to look to get a refund.
Sent from my Samsung Galaxy S7 using Tapatalk
Old 05-14-2016, 02:06 PM   #30
Robostang's Avatar
I didn't know that. His e-mail didn't bounce back to me so I assumed that he was still there.
Old 05-14-2016, 07:46 PM   #31
Bro, shipping will cost what the spring cost. Returning it isn't going to get you any money. Just install the dang thing or sell it to the next guy you see at a meet.
Old 05-15-2016, 12:00 AM   #32
Anyone know if this fixes the high rpm clutch sticking??
visback is offline   Reply With Quote
Old 05-15-2016, 07:29 AM   #33
Region: New Mexico
At least read the thread instead of jumping into a thread and randomly posting without reading. It shows how lazy we've become. This was already asked and answered.
Old 05-15-2016, 07:15 PM   #34
Well can you point to where that has been answered? I read the thread..there is no answer to the question except a "probably won't". I read the review and even they didn't know if it has. So yeah ur useless comment shows instead of being helpful, how big of a dick u are.
Old 05-15-2016, 10:12 PM   #35
Region: New Mexico
My apologies, i got my research and this thread confused.
No need for name calling or hurt feelings, I said we've become.
But to answer it for you, from all I've seen, no.
Frankly, I'm sure it'd be a selling point if it did. ...
s197 mustang
Steeda's S550 Mustang Clutch Spring Assist 35 lb/in - Now Available! tj@steeda 2015 Mustang GT 1 02-11-2016 07:37 AM
The Wait is Over - Steeda S550 Mustang Camber Plates (15-16 All) - Now Available tj@steeda 2015 Mustang GT 0 10-22-2015 07:55 PM
New Product - Steeda S550 Adjustable Rear Toe Links (2015 All) - Now Available! tj@steeda 2015 Mustang GT 0 03-11-2015 10:46 AM
2015 Steeda Tunes Now Available tj@steeda 2015 Mustang GT 0 12-24-2014 09:18 AM
Spongy clutch after removing clutch assist spring. Fax22 2011-2014 Mustang GT 2 09-06-2014 10:19 PM
04:45 AM
