Installed new rims from AM, PROBLEM - Mustang Evolution
Old 04-30-2016, 10:18 AM   #1
stampde's Avatar
SO I got a couple rims from American Muscle a couple weeks ago ( 18x10 GT/CS replicas they had on special )
had Pep Boys mount up some tires for me took them home mounted them up
never thought anything about it they looked good
but every time I look at the car I noticed something was off ?
couldn't put my finger on it ? then a friend mentioned it looks like one of your wheels sticks out more than the other
so i took it to an alignment shop to see if the rear was in line ,it was ,they said looks like the wheels have different back spacing ,SO I did a quick measure with the rims on the car and it appears i got 2 different rims,boxed wrong i presume ? so I called AM , talked to a girl about it asked If there was a problem exchanging it for the correct one and she says i need writing from the shop yada,yada
that's a little a little much isn't it ? if one's boxed wrong ,whats the issue ? just replace it ..... i don't feel like taking it to another shop and paying again or the same info ,just to verify ,WTH?
2011 GT Auto
Old 04-30-2016, 01:21 PM   #2
Region: New Mexico
Seems like they should be able to measure it when you return it.
WoodDA is offline   Reply With Quote
Old 04-30-2016, 01:49 PM   #3
stampde's Avatar
I agree
im going to take it off tomorrow and give it a correct measurement , but its a good inch off , either backspacing or its an inch narrower wheel ,not sure yet ,to be honest I never took them out of the boxes ,just opened them ,checked them out ,dropped them off to get tires mounted
2011 GT Auto
Old 04-30-2016, 01:58 PM   #4
Region: New Mexico
The AM guy here seems to respond to a lot of posts so maybe after the first of the week you'll hear from him. Looks like you have the Same color car as my 2012 so post a pic when you're all set. I'd like to see them.
Old 04-30-2016, 02:03 PM   #5
Shouldn't the back spacing be on the inside of the rim?
StarzTA17 is offline   Reply With Quote
Old 04-30-2016, 02:30 PM   #6
I guess i'll play devils advocate....
You didn't check the wheels before putting them on the car?
Old 04-30-2016, 02:43 PM   #7
TRMN8ER's Avatar
If you believe that your wheels are mismatched, do a quick measure yourself to confirm. If confirmed, your measurements will be adequate to be considered fact. I would simply tell AM that you received mismatched wheels and you confirmed the mismatch by measuring it yourself. It does not take a professional to use a tape measure. If they tell you that it must be in writing from a "professional" shop, then tell them you'd be more than happy if AM pays for the wheel diagnosis and your rental car.
Point is, AM doesn't have much of a leg to stand on here... They are in the wrong and should own up to their mistake. I buy 90%+ of all my parts from AM, and have had nothing but excellent customer service in any given scenario with them. As long as you word your statement to AM correctly, you should be able to get your way without much pushback.
TRMN8ER is offline   Reply With Quote
Old 04-30-2016, 03:25 PM   #8
Diehard's Avatar
Maybe you can snap pictures and send them.
Attachment 200468
Old 05-01-2016, 09:54 AM   #9
stampde's Avatar
no of coarse not
just opened the boxes and looked at them .never pulled them out
dropped them off had the tires mounted
then installed them myself and really didnt take notice they are the exact same wheels , but now that i realized there was something off . i took them off yesterday and they have different backspacing , ones about 7.25 and the others around 6.5
and looking at the hub thickness ,you can tell their different , i can't believe i didnt notice it , duh
guess i was in a hurry to get them on
2011 GT Auto
Old 05-01-2016, 10:11 AM   #10
stampde's Avatar
ya i doubt ill any problem , now that i've actually measured and checked them out , maybe because i want sure what the problem was when i called ? just seemed odd to me that she said that ?
any way after a little investigating i believe i received a wheel for a 99-03 car and 1 for a 05 and up ///
but i actually like the 99=03 back spacing better its a little more tucked in
---------- Post added at 10:11 AM ---------- Previous post was at 10:10 AM ----------
I'll call them tomorrow and straighten it out , thanks for the input
2011 GT Auto
Old 05-01-2016, 01:17 PM   #11
Strange Mud's Avatar
PM Alex (look in AM forum) he'll hook you up.
Old 05-01-2016, 02:13 PM   #12
This.
Wheels typically have the backspacing and size stamped on the inside. It's also possible that since you went with wider wheels your axle is ever so slightly not centered and the wider wheels made it apparent.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-01-2016, 02:39 PM   #13
The 99-04 offset would push it out more actually being a lower offset.
Old 05-02-2016, 05:52 AM   #14
Devil Strider's Avatar
The Walmart of mustang parts. Lol
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 05-02-2016, 10:14 AM   #15
stampde's Avatar
thanks , he took care of it
2011 GT Auto
Old 05-04-2016, 07:29 PM   #16
stampde's Avatar
that's the problem , I got the new wheel Today and its the same 6.5 offset , pushing the rim out , I guess AM miss understood me? but I thought i was supposed to have the 7.25 /7.3 backspace ???? so I don't know why I'm getting the 6.5 , WTH ? so now I have 2 rims I don't want , geez
2011 GT Auto
Old 05-05-2016, 02:24 PM   #17
Diehard's Avatar
Just Curious
Why do you think you were suppose to have the 7.25 Backspace (19 mm offset)?
Old 05-05-2016, 02:34 PM   #18
stampde's Avatar
it has it listed on thier site ,7.3 bacspace
2011 GT Auto
Old 05-05-2016, 02:38 PM   #19
Diehard's Avatar
Well you're absolutely right!
If they have them available with other offsets and backspace, I wonder why they make no mention of it?
That's a pain in the butt!
Old 05-06-2016, 12:47 PM   #20
stampde's Avatar
wheel 2 is on the way, see what happens
2011 GT Auto
Old 05-16-2016, 09:53 AM   #21
stampde's Avatar
finally got it all sorted out ,AM has GREAT Customer service !!!!
2011 GT Auto
Old 05-16-2016, 09:55 AM   #22
stampde's Avatar
they look great
2011 GT Auto
Old 05-16-2016, 07:50 PM   #23
A Faster Horse's Avatar
they look great
Yes they do! Love that blue too!
A Faster Horse is offline   Reply With Quote
how can i tell the difference between factory installed a/c & a dealer installed? Anthony90GT General Mustang Discussion 0 12-01-2012 09:42 PM
AvantGarde M310 Rims installed!!! Mustanggt11 2011-2014 Mustang GT 3 08-17-2012 04:45 AM
New clutch installed.. need new cable now Rascal Pre-2005 V6 Mustang 5 06-03-2010 07:55 PM
Rims on, fogs in, CAI installed *DUW* Stangthang Pictures and Videos 6 03-13-2005 07:35 PM
rims installed,DUW Thomas91169 The Bar 32 06-19-2004 10:40 PM
12:03 PM
