Pinion seal leak?? Help - Mustang Evolution
Old 04-30-2016, 05:23 PM   #1
I have a 2014 5.0 ...I noticed the the other day this was leaking it looks like that piece isn't all the way down against the orange seal any idea?
dude0715 is offline   Reply With Quote
Old 04-30-2016, 06:58 PM   #2
k1DBLITZ's Avatar
Are you sure it's not coming from the axle vent? There is a TSB to add a hose.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 04-30-2016, 07:14 PM   #3
Name:	ImageUploadedByMustang Evolution1462065246.993561.jpg
It looks like it's coming right at the pinion seal
Old 04-30-2016, 07:25 PM   #4
k1DBLITZ's Avatar
That is unfortunate. Sorry man.
Old 04-30-2016, 07:54 PM   #5
Its a 2014... take it to Ford...
Old 05-01-2016, 10:09 AM   #6
olerodder's Avatar
Region: Oregon
I had the same issue with my 14 TrakPak at around 7k miles only worse.
I took it to Ford and they replaced it....apparently the OE seal is mostly plastic and the revised seal is metal....never had an issue after it was replaced. Quite a few 14's had this issue.
I assume it's still under warranty!?
Old 05-01-2016, 10:32 AM   #7
It's NBD, take it to Ford. They can replace the seal without opening up the rear end in a couple hours. I've done it in my driveway on jackstands. It just takes a little careful measuring and marking.
Old 05-01-2016, 06:51 PM   #8
Pcanno167's Avatar
Heads up - I had the issue on my 2013 TP Manual within 36k and the three year warranty. They fixed it. WARNING - it is not covered after the warranty expires.
I had the same problem at 68k a few months ago. I had to pay $170 something dollars to repair it and that was on the cheap side if it. It was strange (durning the second issue) when the first dealer quoted me the price with taxes - that was about $280. I Called Ford customer service and got the run around. Basically they said that even though it occurred the first time at 28k, the warranty for the new part is only good for 12 months.
This is BS. I told them that they have a problem with the install procedure or the part. At the dealership service that I rejected, I was informed that the problem is common. They say that they get cars with the problem offend. I was also informed that the problem will occur over time if the the differential was over filled be the mechanic. I have not touched my diff yet. So that means that all fingers point back to Ford's part or their procedure.
I would not expect any new car to leak under 100k - especially twice in the same area and same seal.
It frustrates me that Ford would not stand by or fix their failure problems in this area. The is is a lot of money being made off of this problem....
2013 Mustang GT/TP:
Red Candy
Track Pack
SLP Loudmouth Axle Back
MGW Shifter (w/EPCO Rally II Shift Knob)
Pcanno167 is offline   Reply With Quote
Old 05-01-2016, 10:01 PM   #9
olerodder's Avatar
Region: Oregon
When I had mine replace towards the end of the year...under warranty...their rear end guy said they had a revised seal that was metal instead of plastic...I took him at his word so I can't verify if this was true or not......the car never had another issue. Wednesday when I'm at the dealer I'll ask the parts manager and service manager if that was true and try and get a part number.
Old 05-02-2016, 10:34 PM   #10
Pcanno167's Avatar
older odder , Thanks for the info.
that's the problem - the question that most will ask is why does one "rear end guy" has this knowledge and not all of Ford. Second, one may ask why are we paying for a mistake that Ford made. I had to fork out over $170 for the second one, which means I may have gotten the same bad seal twice. And may others may do the same. Now possibly the third time. This sounds like a RECALL to me - or one may ask is this a Money maker...
Thanks for the info. We look forward to hearing his response.
2013 Mustang GT/TP:
Red Candy
Track Pack
Old 05-03-2016, 08:08 AM   #11
olerodder's Avatar
Region: Oregon
The old saying goes, "If you buy a used car you buy the owners issues, and if you buy a new car you buy the factories issues", couldn't be more true. The issue here is that not every Mustang is having this problem with seals going bad and what percentage would constitute a recall....the service manager at my Ford dealer told me that mine was the first 13/14 that the pinion seal had let go although after mine was fixed they have fixed 2 or 3 more.
Not sure what you mean by a "Money Maker", as Ford gets no kick-back on service from it's dealers and the dealers....at least my dealer....doesn't really care to do warranty work because Ford sets a limit on time spent to repair the issue and the dealer usually doesn't make much if any profit.
The thing that amazes me is that my first new car, a 70-1/2 Z 28 cost just over $4000 and in 2016 money it's over $25,000........inflation!#*@
Old 05-03-2016, 11:56 AM   #12
WJBertrand's Avatar
I think the repair should be covered for the length of the 60K mile power train warranty or the 12 months, whichever is longer. It would not be acceptable to have a part fail at say 12K, then have it fail again at 25K and be told at that point it was no longer covered when in fact your power train warranty is still in effect.
In your case the problem seems to be that with 68K you are past the power train warranty and the 12 month repair warranty. Nobody covers repairs past the warranty unless it's a safety recall or a TSB program.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 05-10-2016, 01:10 PM   #13
tfalk's Avatar
If there were 'enough' cars that had this problem, Ford would have at least a TSB on it. It's not a safety issue so I don't see why you would expect them to recall how many hundred thousand mustangs they sold. It's a minor problem on an (apparently) small number of vehicles.
$170? I just replaced the pinion seal on my 99 Saleen with 64K miles. The replacement was $24 from AM, took about 30 minutes.
If you want a car a 100K warranty, either buy a car that comes with one or purchase an extended warranty that covers the time and mileage you want.
99-122 Bright Atlantic Blue S281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Saleen - Power in the hands of a fool!
tfalk is offline   Reply With Quote
Old 05-10-2016, 02:00 PM   #14
Mine went out at 7k ( or at least that's when I saw all the oil under there ). It was replaced and I noticed it again at 60,120 miles. Damn Ford. I think the vents are plugged because when I took out the fill plug, there was a pshhh * pressurized rear end. Ughg
Sent from my Nexus 6 using Tapatalk
buschris is offline   Reply With Quote
Old 05-10-2016, 02:49 PM   #15
My boss's 2013 just had the rear completely go out actually.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-10-2016, 04:27 PM   #16
WJBertrand's Avatar
What you heard was probably a vacuum being released. That breather valve is a one-way check valve that allows heat expanded air out, but then seals when the differential begins to cool and draw air back in. It's designed this way so that for example if you are driving a fully warmed car through a deep puddle that might suddenly cool the final drive, water is prevented from being drawn in.
-Jeff-
Ventura, CA
Old 05-11-2016, 09:03 AM   #17
OK, makes sense. I wonder if the seal really is leaking like the first time, it didn't seem really low on oil
Pinion seal leak?? shellac 2011-2014 Mustang GT 4 08-28-2014 03:28 PM
Pinion seal leak? silverstang831 2005-2010 Mustang GT 4 06-17-2013 01:14 PM
Pinion seal advice 04machazblue 1996-2004 Mustang GT 9 09-07-2011 09:18 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 07:19 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 08:19 PM
08:22 AM
