Pulled fenders? - Mustang Evolution
Old 05-02-2016, 07:31 AM   #1
canesfan727's Avatar
Pulled fenders?
Anybody have any pictures of rear fenders pulled on the 13-14 body style? My car rubs on the right rear so I'm thinking about getting the fenders pulled I just don't know how it will look
canesfan727 is offline   Reply With Quote
Old 05-02-2016, 04:23 PM   #2
Why not just get an adjustable panhard bar and pull it a little left until it doesn't rub? Axles are off centre on these things from the factory. You could also get different wheels with more inset. There is room here on the inside. Since the fenders are rolled and stamped factory I don't see how what you are suggesting would work or look good.
Old 05-02-2016, 08:31 PM   #3
If you have an instagram, look up "101blur." He has has what you're looking for.
GTaggie is offline   Reply With Quote
Old 05-03-2016, 03:15 PM   #4
I do have an adjustable panhard bar but I have 305's on the rear and I'm lowered an inch and a half so they rub on bigger bumps just on the right side tho. They're rolled but not pulled and that's exactly why I was wanting to see a picture of it done before I did it. The picture above doesn't look bad at all in my opinion. I could have gotten wheels the same style and finish that would fit 305's but the extra idk $1,200 just didn't seem worth it for those.. I would rather put that money towards a supercharger
Old 05-03-2016, 07:13 PM   #5
Diehard's Avatar
Well rolled or not, sounds like you should be checking your tracking and probably re-adlusting your Panhard bar.
Old 05-05-2016, 04:55 PM   #6
It has been adjusted but the tires stick out just a little bit on each side of the car. No idea why it only rubs mostly on the ride side tho I read somewhere else where a guy was rubbing more on his right rear too
Old 05-05-2016, 05:14 PM   #7
Sam's car (@101blur) is what i was about to post but i see his has already been posted. He had them pulled and then the rear end of the car repainted because there were chips in the paint and his rear bumper was off from the factory. His car is purely amazing. I actually know him personally and have ridden in his car a few times at track days. Still scares the crap out of me. He tucks 335s back there on a 12" wheel.
Old 05-05-2016, 11:18 PM   #8
Yeah I looked through is Instagram that's pretty crazy. This dude in Texas said he was running 325's with no body work but I don't see how..
Old 05-07-2016, 10:21 PM   #9
5pointYoBro's Avatar
Dayumm
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 05-08-2016, 01:30 AM   #10
bellski's Avatar
Pulled fenders?
Tire width is not your problem. If only one side rubs, it's fixable with adjustments of the panhard bar. If you are rubbing on both sides you have the wrong offset on your rear wheels. I have 314/35-20's on 11" x20 rims on the rear of my '11 GT and they have never rubbed.
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
Old 05-08-2016, 06:45 AM   #11
Diehard's Avatar
OP may be lowered more.
Old 05-08-2016, 06:45 PM   #12
It's centered like I said the tires stick out a little on both sides idk why it usually only rubs on the right side.. It barley ever does on the left side. I'm sure that's what it is but like I said $60 for somebody to pull my fenders is a lot cheaper than buying new wheels
Old 05-08-2016, 08:15 PM   #13
oxford5pointoh's Avatar
It rubs on the right because that's where the Panhard bar pushes it when your suspension cycles. Might be cheaper to look into a watts link setup then to mess with pulling fenders.
Old 05-10-2016, 12:15 AM   #14
Kustumb's Avatar
Can someone explain what pulled fenders are exactly?
Kustumb is offline   Reply With Quote
Old 05-10-2016, 02:00 PM   #15
Revvv's Avatar
It is normally a gentle roll of the inner rear wheel well lip. Instead of a 90° angle the lip is literally rolled or bent upwards.
For Some there is a need to pull the rear quarters out to accomodate a wider tire. Think of it as a wide body kit, without the kit. This also is not as pronounced as a wide body.
Old 05-10-2016, 02:29 PM   #16
Kustumb's Avatar
Interesting. Thank you for the explanation.
Weird 65 fenders Dmay65 Classic Mustangs 7 11-13-2011 09:49 PM
removing gt emblems from front fenders ronn 2005-2010 Mustang GT 11 05-17-2010 09:16 PM
Help reinstalling front fenders LPlum Classic Mustangs 2 09-19-2006 12:57 PM
Rolling rear fenders GTBrad Mustang Wheels & Tires 25 08-05-2006 11:37 PM
POCKET FENDERS OMEGA7STARR Mustang Audio & Video 3 07-27-2003 11:17 AM
02:56 AM
