Axle looks twisted to the rear. - Mustang Evolution
Old 05-02-2016, 07:16 PM   #1
Installed eibach sport line springs about 1000 miles ago. And yesterday I was parked uneven in a parking lot, not too bad and my rear passenger side was bottomed out. Then when I moved it it was normal again, not sure if that means anything. Also I bottomed out 3 times the past week or so wich hasn't happened before. And the rubber stoppers on the rear axle aren't up and down the lean to the rear alittle. Is this all normal and it's all in my head? Or is there something wrong.
Massery94 is offline   Reply With Quote
Old 05-02-2016, 08:43 PM   #2
Not a good idea to put higher rate lowering springs on ****ty stock dampers than can barely control the stock springs. I'm not surprised it's bottoming now that the springs have settled a bit. You do need to replace the bump stops with something lower or cut the stock ones down an bit.
...and get some real shocks will ya?
Old 05-02-2016, 08:53 PM   #3
Haha I need better shocks, but the dampers came with the eibach kit
Old 05-02-2016, 09:47 PM   #4
TRMN8ER's Avatar
Shocks, struts, and springs all need to be replaced / upgraded together (if they are stock). As @5LHO mentioned, the stock setup is garbage, even worse if paired with aggressive aftermarket parts.
As far as the uneven look goes when parked, regardless of your stated suspension setup, not all ground is actually even, giving the impression that your car's suspension may be out of alignment / imbalanced. A slope of marginal amounts can make your car look skewed and appear even worse when viewing from certain angles. Not something I would really worry about unless we are talking inches of difference when parked on what appears to be a generally flat surface. If that's the case, you have a suspension problem - time for more upgrades.
TRMN8ER is offline   Reply With Quote
Old 05-02-2016, 10:29 PM   #5
[IMG][/IMG]
Here's a picture of the offset of the bumper.
Old 05-03-2016, 12:03 AM   #6
looks normal, my bumpers looks like that with stock spring and shock, if axels twisted you can tell by the way springs are seated.
13' Mustang GT, A6, Whiteline adj. phb & support brace, Roush a/b, Boss 302 brace, Pioneer door speakers, Alpine 10" 500 Watt RMS Amp and Sub, Michelin Pilot Super Sport
winkawak is offline   Reply With Quote
Old 05-03-2016, 07:52 AM   #7
Thanks! I had an 84 gmc 1500 before this so I had problems often haha so I get these ideas in my head that something is wrong with my car and it's not...
Old 05-03-2016, 01:00 PM   #8
olerodder's Avatar
Region: Oregon
Since you have Sportlines I assume you received the shortened bump stops with the springs???
I installed Sportlines in my 14 with less than 3000 miles and never had it bottom out once...also ran stock shocks and struts for over 7000 with no issues.
Yes, changing shocks and struts along with strut mounts would give a better ride it's not totally necessary....depending on how many miles you have on the stock ones of course.
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 12:14 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
Weird and Twisted Video bluemustang Pictures and Videos 12 11-21-2006 05:37 PM
How twisted is this woman? *WW* steedav6builder The Bar 20 01-27-2005 10:03 PM
New kinda twisted Happy Meal? Seph The Bar 7 08-28-2004 12:23 PM
04:29 PM
