Cat delete without tune? - Mustang Evolution
Old 05-03-2016, 03:20 PM   #1
nicholasmadill's Avatar
Wondering what will happen if run the car with cat deletes and pype Bomb axle back without a tune ( car had tune but was un married by previous owner)
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 05-03-2016, 04:01 PM   #2
Red_Menace11's Avatar
Probably burn up the rear O2 sensors
Red_Menace11 is offline   Reply With Quote
Old 05-03-2016, 04:36 PM   #3
Ferr's Avatar
What he said. Your check engine light will also come on until you tune it.
Ferr is offline   Reply With Quote
Old 05-03-2016, 05:40 PM   #4
Grabber Blue5.0's Avatar
Yea no that's not gonna happen.
Running a car without cats and no tune will result in a CEL and the car won't run well since COT will kick in. COT needs to be turned off or the car will continue to dump fuel to cool the cats which have been removed.
Old 05-04-2016, 09:46 AM   #5
It will run decent and the CEL will go on but a tune is strongly suggested
sterling_5.oh is offline   Reply With Quote
Old 05-04-2016, 10:26 AM   #6
It won't run "decent" with the car dumping fuel to cool the cats.
Old 05-04-2016, 05:33 PM   #7
Jn2
It will dump fuel to cool the cats regardless of them being there or not. COT enabled when the car guesstimates that the cats have reached a temp higher than what is set in your tune. From the factory I think min was around 1700*f. When this occurs the car will richen up to around .75 lambda to cool the cats down and keep them from melting.
There is a 02 sensor over temp control that does the exact same thing, it will richen the a/f mix to cool off the exhaust temps. This will protect the 02's, not burn them out. If you turned these settings off and did not let the car richen the fuel mixture than you would be running the risk of burning our the 02's, and in catted sets up, melting the cats.
So to clarify, the car will run fine, just like it did when it was stock. COT will kick in when temps get to hot regardless of there being cats present or not. If it does kick on, its only protecting the car, not damaging it.
If you re curious on what it takes for COT to kick in, Im attacking a log I did when mt car on stock tune and stock exhaust. If you notice the vertical line, that is the start of my WOT pull. Where the cursor is when COT kicked on, noticed that my lambda start to drop to around .75-.76. This is bc of what I described above, the car wants to cool the exhaust temps down to protect components. It will not make your car run like crap as you cannot even feel COT kicking on. If you were to dyne the car and COT kicked on you would notice a drop in power for sure, but it's only from it running richer.
Name:	Screen Shot 2016-05-04 at 6.39.16 PM.png
13' Mustang GT w/Track Pack: Bottle fed CJ manifold, FRPP Intake,FRPP Monoblade TB, Speedmaster headers, Magnaflow 3" X pipe, Bassani quad tip ABs, Jn2uned, SRP Axles, MGW shifter, BMR LCA's
Jn2 is offline   Reply With Quote
10mpg after cat delete tune Fax22 2011-2014 Mustang GT 17 08-13-2015 07:32 PM
Cat delete. Tune? Do I need one and how howellrobby Pre-2005 V6 Mustang 5 12-18-2014 03:10 PM
Header to cat/cat delete pipe gasket. nosympathy 2011-2014 Mustang GT 9 12-14-2012 09:36 PM
I got my ghost cam tune from bama and bbk cat delete Mustang_5.0 2011-2014 Mustang GT 19 08-29-2012 12:39 PM
cat or no cat 96mustangv8 1996-2004 Mustang GT 15 05-12-2011 02:00 PM
07:06 PM
