Serious HELP needed!! - Mustang Evolution
Old 05-07-2016, 11:20 AM   #1
StolenSinner09's Avatar
70-80MPH hood/front end vibrations. 2014 GT
Before you say that theres a thread that has covered this, I've already read it.
Heres the back story;
While driving down to Austin one Sunday, two weeks ago, I decided to open the car up. I do not do this often, I dont race or track my car. But, I wanted to have some fun. I got it up to 101 at a very moderate pace, 5-5500 RPM shifts, and the hood popped open. Got out, closed it, continued to drive normally and as soon as i got to around 80, my problems began.
Here's what I've done:
Balanced wheels
Checked all suspension components for faulty parts.
BOUGHT A F***ING DRIVESHAFT
And i just returned from a test drive with duct tape all over the front the car to see if it was wind.
Nothing.
So Im pleading for help. I do not have the money to keep buying parts for it to not solve anything. Does anyone have ANY advice to share before i get completely discouraged and give up and get rid of it.
StolenSinner09 is offline   Reply With Quote
Old 05-07-2016, 11:49 AM   #2
Adjust the hood bumpers a bit; I think yours are too high, if the latch popped open like that....and check that latch. If that comes open at speed, it'll smash the windshield and likely wreck you. You are damn lucky that didn't happen.
You could also start by being smart and analyzing the situation instead of throwing parts at it....or just slow down a little until you figure this out. Think about it, why would your driveshaft suddenly go bad when your hood popped open at speed, or your wheel balance go off? It's likely related to what actually happened. This is a pretty ridiculous reason to get rid of a car.
Old 05-07-2016, 01:50 PM   #3
Old 05-07-2016, 02:01 PM   #4
I completely understand what you are saying, I also forgot to add to the list that I have adjusted my bumper. It was the first thing I did.
I also didn't just start throwing parts at it. A $700 driveshaft isn't something I would impulsively buy, thinking automatically that was the solution, it was a result of research and having multiple people tell me (with them looking at it with the car off the ground) that my carrier bearing was shot.
Now with having tried all these possible solutions, and spending damn near $1000 and getting absolutely nowhere, I hope you can understand my frustration.
I do appreciate your input and advice, this isn't me criticizing you, but just me hoping to explain to you and future advice givers where I'm standing when I originally posted this.
Old 05-07-2016, 02:14 PM   #5
Is the undertray in good condition on the car? Any damage to these plastic pieces under the engine can have serious consequences.
Old 05-07-2016, 02:43 PM   #6
TRMN8ER's Avatar
I had a very similar issue to what you're describing, and it took me a while to figure it out, but I did end up figuring it out. So please hear me out with what I am describing.
First I'll start with how my issue began. I was parked (front facing curb) in a stall on a downhill sloped lot. In front of my car was a standard curb, where on the other side of the curb was plants and dirt. I went to back out, thought the car was in reverse, gave it a little gas since I was on a slope, and basically launched my car forward... the car was in 1st gear (yes that was very stupid, please laugh with me!). As a result, my front bumper cleared the curb, but slammed into the dirt and plants on the other side until my tires hit the curb itself. My front bumper became dislodged from its side brackets, and I had to snap them back in. I thought that was the end of it... unfortunately it was not.
After that incident, during highway speeds driving (60-90mph), my hood began rapidly vibrating / rattling, which looked like 1+ inches of movement on the hood itself. I troubleshot the latches and pins in the hood etc. - no soup.
Skipping over more irrelevant details, my issue ended up being a torn underbelly air deflector from the curb I hit. Air was not flowing under the car as designed, due to the tear in the deflector. Instead, lots of air was entering the engine compartment from the tear in the deflector. I am not sure of the technical details, but that air is not meant to be in the engine compartment - the car had no way to expel the unnecessary air. In return, the additional air was forcing its way out of the engine compartment in any possible way... which ended up causing the massive vibrations / rattling of the hood. The air was pushing the hood up to escape.
Once I replaced the torn underbelly air deflector, my problem was resolved 100%. Now I am not sure if this is your exact issue, but your problem is very likely due to incorrect airflow into your engine compartment.
Here is a link to the exact part I am referencing: http://www.cjponyparts.com/ford-lowe...All%20Products
TRMN8ER is offline   Reply With Quote
Old 05-07-2016, 02:51 PM   #7
This is exactly an example of what I am referring to.....
Old 05-07-2016, 04:17 PM   #8
That's completely wild! But I'll take a look. Did you just end up having to replace the whole damper? Appreciate the advice, you two!
Old 05-07-2016, 05:51 PM   #9
grabber12's Avatar
TRMN8ER that's a great answer to this dudes problem. Gosh who would ever think air would come up threw the bottom that hard and force an issue like that. GREAT info. Hope this is StolenSinners issue and it gets fixed.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 05-07-2016, 05:53 PM   #10
aerodynamics is half art, half science and the forces here are not to be toyed with.
Old 05-07-2016, 06:36 PM   #11
TRMN8ER's Avatar
The only thing I replaced was the underbelly air deflector. Self install is 20 minutes or less - its held in by 8 or so screws.
Old 05-07-2016, 06:50 PM   #12
Is it not under warranty or something?
Old 05-07-2016, 07:04 PM   #13
Not if you rip it off on a kerb....
On the 13+ cars it's held in by 19 long skinny screws with fender washers on....
What the thing does primarily is aid the cooling system by placing an area of negative pressure underhood but it also smooths airflow under the car as well, as you can see from termini8r's example.
Old 05-08-2016, 10:20 AM   #14
Psmith129's Avatar
Same issue , you're spot on with the deflector as mine is torn also . I have a similar embarrassing story . I broke my deflector by not putting my car in gear when I parked it and the e brake either disengaged or I didn't put it on. Car rolled forward into the curb and bushes luckily clearing the bumper by a hair . That little plastic piece is somewhat important though . Who would have thought
Psmith129 is offline   Reply With Quote
Old 05-08-2016, 10:25 AM   #15
tym_v6's Avatar
By popped open, did it just unlatch, or did the hood fly up while driving?
Factory hood?
Have the latching mechanism and rubber bumpers been checked?
Old 05-08-2016, 10:31 AM   #16
king_13's Avatar
You bought a driveshaft to fix a hood vibrations?
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 05-08-2016, 10:45 AM   #17
Strange Mud's Avatar
if stuff is out of sync/sound weird it's because I merged two threads.
5LHO again!
and they also get ripped off by hunks of truck retread (learned that one from experience)
Old 05-08-2016, 10:54 AM   #18
TRMN8ER's Avatar
What the thing does primarily is aid the cooling system by placing an arcade negative pressure Underwood but it also smooths airflow under the car as well, as you can see from termini8r's example.
Maybe it's more than 8 screws... lol. But my point is, it's a very easy self install.
Old 05-08-2016, 12:36 PM   #19
It just unlatched. Didn't fly all the way open. But I've checked my latch and compared it to my friend's. No difference.
Old 05-08-2016, 12:42 PM   #20
Yes, because I researched this issue and most people that had the same issue, was due to broken carrier bearing. After looking at mine, and having a few mechanics look at it, it was said to be faulty. So, new driveshaft it was.
Old 05-11-2016, 01:40 PM   #21
So, I was able to find some time today and got the car up and inspected the deflector. It was sagging in near the splash guard. My guess is when the hood popped open, the rush of air that entered the hood blew the deflector off the screws. So I did a hasty mend on it with some duct tape...aaaaand I just got done going 110...smoothly.
SO! I do very much appreciate all of you and your help and advice! I would have never guessed it was that.
Old 05-11-2016, 02:05 PM   #22
Old 05-11-2016, 02:15 PM   #23
TRMN8ER's Avatar
Awesome bro, glad we could help you out!
Serious Problems Need Serious Help Red Stallion 11 2011-2014 V6 Mustang 18 08-02-2012 06:30 PM
My 4.6 pony needs SERIOUS help! VadenKwinn 1996-2004 Mustang GT 17 05-25-2010 10:42 AM
need help with a serious issue Kyle The Bar 13 04-22-2005 07:48 PM
Help! Serious problem. Laser02 Pre-2005 V6 Mustang 9 07-19-2004 12:52 PM
04:29 PM
