Need new suspension - Mustang Evolution
Old 05-09-2016, 12:02 AM   #1
Need new suspension
so i had a set of used kw coilovers on my 14 gt and now theres loud clunking noises coming but hey i got 15k miles out of them. so i looking for something else i have a $1500 budget, i just want to get an imput of how coilovers are around that price range and which ones i should be getting or if i need to spend 2k or more on coilovers im just going to go with koni or bilstein set up with springs so imput on those 2 would much be appreciated.
I'm leading towards the st xta coil overs
mikegt323 is offline   Reply With Quote
Old 05-09-2016, 12:19 AM   #2
oxford5pointoh's Avatar
You know the only way anyone can give you advice on this would be if they know what you intend to use the car for. If you are not tracking the car you prob don't need coilovers. And depending on how serious you are about tracking it would determine which ones that might get recommend.
Old 05-09-2016, 12:22 AM   #3
I'm looking for a decent set up I'm not all that crazy into tracking but I will a few times a year for fun
Old 05-09-2016, 12:39 AM   #4
The other question would be what type of track events you go to. Drags a few times a year or autox?
Based on what you are saying I'd probably just do some nice adjustable strut/spring setup and call it a day. You don't need coilovers in my opinion.
Old 05-09-2016, 12:46 AM   #5
I will drag it more than I will autocross it, I would've ordered konis by now cuz my cars not drivable but one reason is I like the height adjustable on the coil overs so I just want to know if it'll be worth spending the extra for it, is handling a big difference from them? I was looking at the eibach multi pro r1 they're $1800 have you heard any cons about them, it is over my budget but I guess I'll squeeze out a lil more of it'll be worth it
Old 05-09-2016, 12:49 AM   #6
Ima place an order tmrw cuz I need my car in driving condition lol lets say I end up going with the strut/spring set up what springs would you suggest I'd like to be pretty low but not low where it'd blow the struts
Old 05-09-2016, 08:08 PM   #7
5pointYoBro's Avatar
Need new suspension
I have BC Racing coilovers from my old car, that eventually I will get put on my new car. But I've considered selling the BCs and getting Yellow Koni's and Eibach Sportlines. I think sportlines have the most drop in height out of most springs on the market. These give your car a leveled look, 1.3" in front and 2" in rear
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 05-09-2016, 08:31 PM   #8
I had the sport lines when I first got my car and it does have a nice drop to it, you think the sport lines are too much of a drop for the koni's?
Old 05-09-2016, 10:32 PM   #9
The eibach sport system plus is a good deal, but I think I'd rather have Koni's than the eibach shocks and struts. They'll work fine
Old 05-09-2016, 10:37 PM   #10
Whatever you do avoid Koni oranges. I have the yellows with Steeda springs and I love it.
I don't think someone going to the track as rarely as you do needs the height adjustability or stiffer ride associated with coilovers.
Old 05-10-2016, 10:41 AM   #11
Is it better to use the 05-09 yellow Koni's with the GT500 strut mounts? Or the yellow 11-14 Koni's?
Old 05-10-2016, 10:43 AM   #12
Voltwings's Avatar
I think the real issue here should be why are they clunking... Start there, because it would suck to drop $1500 and still have a clunk...
Old 05-10-2016, 12:19 PM   #13
I think the 05-09 with the GT500 mount is a great setup. It really depends how low you want to go and if you want to spend the money on CC plates or better/replacement mounts. Because those stock ones will fall apart on you unless you get lucky.
Old 05-10-2016, 12:46 PM   #14
so i talked to kw they said that they could rebuild each shock for $130 but they said they wont really know whats wrong with them until they get it apart so i might go this route
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
how low do the springs seat?
Old 05-10-2016, 01:10 PM   #15
As in how much drop? It's a conservative drop. I have the Steeda sport springs. It's like 1.25 rear 1" front. This is my car.
Name:	ImageUploadedByMustang Evolution1462907377.770206.jpg
Name:	ImageUploadedByMustang Evolution1462907434.816559.jpg
Old 05-10-2016, 07:11 PM   #16
Need new suspension
For sportline springs what would you go with?? CC plates are a lot more expensive than gt500 strut mounts lol
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension options...need advice jmp782 Pre-2005 V6 Mustang 2 10-12-2008 03:12 PM
Need New Rack-n-Pinion and Suspension... Whats best brand?? superstarjade 1996-2004 Mustang GT 0 03-13-2008 08:09 AM
rear suspension need help fixing it... rpm Pre-2005 V6 Mustang 18 10-03-2005 07:01 PM
01:40 AM
