1. Where can I go to figure out if the wheels will fit.
2. Will I need a Spacer, If so, what size?
3. If anyone has done this, what size tire did you run?
Yes 19x10 square is possible, but you're getting into very tight fitment territory. Most of what American Muscle has available in 10" wide will not fit, as the offset is way too much for the front.
You'll have to look at it on a per-wheel basis (some might fit and some might not, even with the same specs), especially if you have Brembo brakes. Spoke design and offset are key.
I'm going with forgestar CF10s in 19x10, 40 offset (the ones you're looking at are 48, probably too much). You're looking at 275/35, 275/40, or 285/35 with this setup.
I'll need a 5mm spacer up front to clear the brembos because of the spoke design. Some other wheels would fit without a spacer if the spokes allow for it.
Basically you should be in the 40-42 range on offset, but you'll want to try to find someone else who has run the same wheel and offset to be sure it fits.
Note that guy says "no rub, only when I turn the wheel all the way"
That is rub, and it would be accentuated by any bumps or weight transfers (it could rub more at speed, under braking, on harder turns, or on bumps)
I just put on these in 9.5 inch square setup. I have a 14 GT/CS. They only weigh 21.5 lbs each. They have them in 10 and have proper offset. Just like the Boss 302r wheels. I know someone that is running the 10s on a Boss 302. But they only come in 18, but all of them fit Brembos with no spacers. http://www.apexraceparts.com/apex-products/S197-SN95-Mustang/#.V0k2rPT3anM
10" tire on the front of that car lowered that much will be a nightmare. . I tried that same setup and could never find a happy place.. I've seen a few with it in front but I find it very hard to believe they don't rub some.. or they're driving it like a baby so it doesn't
There should be no issues running 19x9.5 all around. I ran the SVE drifts in 19x9.5 and loved the setup.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
