Rear tire wear - Mustang Evolution
Old 05-19-2016, 05:55 PM   #1
Rear tire wear
Hi guys, i just so happened to look at my rear tires and I have horrible camber wear... This does not make sense because i have a 2011 and it's a solid rear axle. My tires are shot because the insides of both the left and right are worn smooth with wires now showing. If you guys have any ideas of what is going on I would appreciate it.
sterling_5.oh is offline   Reply With Quote
Old 05-19-2016, 05:57 PM   #2
ZombieSlayer's Avatar
Were they properly inflated and rotated?
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 05-19-2016, 07:55 PM   #3
They are a staggered set up and yes they were properly inflated
Sent from my SM-N910T using Mustang Evolution mobile app
Old 05-19-2016, 07:58 PM   #4
Diehard's Avatar
Are you sure those tires didn't come from the front?
Are you the original owner?
Old 05-19-2016, 08:14 PM   #5
Voltwings's Avatar
Is the vehicle lowered, and does it have a panhard bar or any means of correcting the alignment if it is lowered? That is very strange indeed...
What size tires on what size rims? Maybe a little stretch would cause the shoulder to wear first?
Old 05-19-2016, 08:45 PM   #6
bluey lewis's Avatar
Region: Nevada
Very odd and with a staggered set up it rules out those being on the front at one point. Are you the first owner and did you put the current set up on the car? Almost seems impossible. Over and under inflated tires will cause either middle or BOTH edges to wear so I don't see how that is relevant.
bluey lewis is offline   Reply With Quote
Old 05-19-2016, 09:54 PM   #7
crjackson2134's Avatar
Some tires have a stiffer sidewall on one side of the tire. Improper inflation on these can cause increased wear on one side of the same tire.
2014 Black GT Premium - Track Pack - (Apocalypse)
2018 Black Nissan 370Z Nismo - (Lucille-2)
crjackson2134 is offline   Reply With Quote
Old 05-20-2016, 05:51 AM   #8
They are 285 super sports. The only thing I can think of is that my lower control arms bushing is worn out
Old 05-20-2016, 06:47 AM   #9
Diehard's Avatar
Although they're not adjustable for camber and toe (not easily that is) you should have the rear checked for alignment.
Tire wear bigsmitty24 2011-2014 Mustang GT 23 11-18-2013 08:36 AM
New sumitomo tire strange tread wear maverick214 Mustang Wheels & Tires 8 07-01-2013 08:01 AM
Excessive inside rear tire wear CakeOrDeath? Pre-2005 V6 Mustang 14 12-14-2010 12:39 PM
tire wear zack1134 1996-2004 Mustang GT 3 02-26-2009 07:18 PM
max camber w/ even tire wear? tedness Pre-2005 V6 Mustang 1 07-29-2005 02:16 PM
05:42 PM
