Paxton vs jpc single turbo - Mustang Evolution
Old 05-20-2016, 01:28 PM   #1
canesfan727's Avatar
Planning on boosting my car and I was pretty set on the Paxton until I can across the jpc single turbo kit. I daily drive my car and usually just 7min to work and 7min back most driving is in town but I am on the highway a decent amount of time. I travel back to my hometown frequently and that's an hour drive on the highway to get there. I realize twins would be better but they're a little out of my price range.. The single turbo kit looks to be around the same price as the Paxton. I don't track my car but I do get into it sometimes with other cars. What would be the pros and cons of each? Bang for buck and reliability? I don't know a ton about this subject just the basics so take it easy on me haha
canesfan727 is offline   Reply With Quote
Old 05-20-2016, 07:26 PM   #2
where are you seeing jpc single turbo at the same price as a paxton kit?
JPC tuner kit (needs separate injectors and tuning device) runs close the same a a full paxton kit, maybe that's what you're seeing.
go on google or youtube and see pros and cons of turbo systems vs centrifugal blowers. In a nutshell, turbo make more power because there are no parasitic losses but they are more expensive, more complex to install, more prone to heatsoak.
Centri blowers build power more steadily and less dramatically.
nate714 is offline   Reply With Quote
Old 05-20-2016, 08:07 PM   #3
Well it's $6k something for the kit and I already have a tuner so I would just need the injectors. Even if it's a little more but it's better that doesn't bother me I wasn't saying like the same exact price just around it. I know the basic stuff about turbos, superchargers, and centri superchargers but I was asking more specifically about our cars.. I've heard multiple things about Paxton's lacking torque and people having to get a torque booster so you can add that into the price of the Paxton kit too if you want. I've tried looking things up but I haven't found much about this kit compared to other things such as the Paxton. I found a guy talking about how he had a Paxton then switched to twins and said he would never go back to a Paxton because he had to be at high revs to get anything from it and the twins had power all through the curve and more peak power but like I said that's about a twin kit not the single.
Old 05-20-2016, 08:11 PM   #4
Basically I know how they work I was just wondering if anybody had any experience with this kit or something similar vs the Paxton kit. Which one would be the hardest on the engine, most reliable, best daily driver, not going to cost me a ton of money in the long run. I know these engines can handles over 600whp stock just fine but eventually something is going to go wrong so which kit will cause the most problems and money overall? Again if it's a few hundred more or whatever I don't really care. When you're already spending that much money a couple hundred for something better isn't a big deal to me
Old 05-20-2016, 08:16 PM   #5
Rapinator126's Avatar
Fast or slow that's what your asking for the most part.
So your answer is JPC
LSX 408 FTW
Dragging your a$$
Old 05-21-2016, 06:00 AM   #6
Grabber Blue5.0's Avatar
Rap, you're being a little hard on the Paxton no?
How about fast or faster?
Old 05-21-2016, 08:33 AM   #7
REG
JPC
OK now you guys have piqued my interest. Since this is a dual exhaust which side drives the turbo or do both sides.
Was thinking about a supercharger but now maybe a turbo, less power off the line with an auto and no converter but should scream once wound up.
Will the stock internals handle it?
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 05-21-2016, 10:01 AM   #8
We can go with the fast and faster route.
LSX 408 FTW
Dragging your a$$
Old 05-21-2016, 11:30 AM   #9
The turbo has more capability but both will handily make enough to bust the stock rotating assembly into little pieces. Hard on the motor is both about the same because essentially a centri blower is a belt driven turbo.
I'd suggest you examine your skill set. Turbo installs are double the trouble because you have both a hot and a cold side of piping to run. NBD if you've been at this hobby since 1983 like I have and have access to a full battery of tools but, something to consider if you're paying someone to do the work. I can put a Pax kit on one of these cars in a decent day's work.
Frankly, if I was going SC, I wouldn't go centri on this car, I'd go PD, like TVS or Whipple...or even Edelbrock. I want a car that feels supercharged and centri don't play dat. It wants you to rev it out, NA style to make boost.
Old 05-21-2016, 12:25 PM   #10
So basically the turbo has harder install with more capability and putting about the same amount of wear on the engine as the Paxton? What would you recommend doing to the engine for the turbo or Paxton just for peace of mind not necessarily building the whole thing? With a little work to the engine you should be able to turn the boost up a little and still be safe correct?
Old 05-21-2016, 12:50 PM   #11
Oil pump gears and, well, a forged bottom end come to mind but, this is really if your goals exceed 600 wheel. When I did centri on my last car, I kept it under that for that reason.
Old 05-22-2016, 11:48 PM   #12
TRMN8ER's Avatar
Unless you are an expert mechanic and will be doing all of the install + future maintenance yourself or with your team, go with the Paxton. There's a lot less potential issues surrounding the entire application.
TRMN8ER is offline   Reply With Quote
Old 05-24-2016, 01:31 PM   #13
Is a single turbo set up really that much more involved that you need to be an expert mechanic or have a buddy that is to run one compared to the Paxton set up? Part of the reason I was thinking the single turbo is its less parts than the twin turbo obviously and one less turbo so less things to break and less moving parts so I figured it would be less involved than the twin kits plus it's cheaper and I think one 76mm turbo would be plenty for what I want haha
Old 05-24-2016, 02:09 PM   #14
You will find hot side piping much more challenging with a single turbo. Clearance for the k member, steering rack and sway bar cabe close. Twins run like two four bangers with a common crankshaft so it's much simpler. Plus, twins give you the mega torque of a tvs setup with the high rpm power of a turbo. This is bc you can run a pretty tight a/r on the turbine side, bc it's feeding off four cylinders not eight.
Old 05-24-2016, 02:27 PM   #15
TRMN8ER's Avatar
Do some research on turbo installations and maintenance. Then do the same research on centrifugal superchargers. You'll see that one is a much more simple application than the other.
Old 05-24-2016, 02:34 PM   #16
Voltwings's Avatar
Yes. I personally prefer a turbo to SC, but if you just want to set it and forget it get the paxton.
Turbo has oil lines, both feed and drain: Potential leaks.
Turbo has vacuum lines to the wastegate and/or a boost controller: lines that slip off, crack, or otherwise fail lead to overboost conditions.
turbo has a wastegate: If that fails open you make pretty much no boost, fails closed you make all the boost and pop a motor.
There's more and less of each, but basically yes, the turbo is much more involving.
Old 05-24-2016, 04:23 PM   #17
Comp = oil less
LSX 408 FTW
Dragging your a$$
---------- Post added at 04:23 PM ---------- Previous post was at 04:23 PM ----------
Hot side on the JPC kit is far from complicated
LSX 408 FTW
Dragging your a$$
Old 05-24-2016, 06:41 PM   #18
Voltwings's Avatar
You also have to send Comp turbos in every so often to get serviced and re oiled, so that needs to be taken into account as well.
Old 05-26-2016, 12:26 PM   #19
Thanks for the info guys.. Turbo seems to be better but honestly more than I would like to deal with haha. Also valid points on the Paxton and having to rev it out.. Whipple is definitely more expensive than a Paxton but that would solve the torque issue and also have that nice whine. What do you guys think of a whipple compared to a Paxton? Worth the extra money? Way more involved or no?
Old 05-26-2016, 12:50 PM   #20
bluey lewis's Avatar
Region: Nevada
I always like torque more than horse power so for my opinion, whipple. It just works better with my driving style. I tend to be a short shifter. And for street driving it's nice to have that torque, makes it fun.
bluey lewis is offline   Reply With Quote
Old 05-26-2016, 01:33 PM   #21
Why not just have a nice 11 second car NA and install a cheaper nitrous kit when you want to go even faster?
Old 05-26-2016, 01:49 PM   #22
Sterlingbeast5.0's Avatar
I cant say about the Turbo but I have the Paxton for about 6 months now and I drive the car every day everywhere. I LOVE it. I am at about 620rwhp and could squeeze more. just tryin g to be moderately safe with my DD. The Paxton is good for over 1,000 but not on stock block. Less parts, easier/cheaper install that Turbo. I did get my Tremec swap T56 from them though. Great to deal with
Old 05-26-2016, 02:47 PM   #23
Another option is the VMP blower.
Old 05-26-2016, 02:49 PM   #24
Yeah I have 3.73 gears and I don't rev it out much at all unless I'm racing. Just driving around I almost always shift before 3k
---------- Post added at 04:49 PM ---------- Previous post was at 04:48 PM ----------
Just not really a fan of nitrous personally
Old 05-26-2016, 02:51 PM   #25
No problems with it so far? What other mods do you have? I was set on a Paxton and about the same whp you have but I just started looking at other options and was just wondering about people's opinions that know more than me haha
Old 05-26-2016, 02:59 PM   #26
A turbo setup will not be as parasitic to the engine as a supercharger setup.
2013 mustang v6 premium package
Powder coated gold metallic wheels
MPT ghost cam tune
Quarter window louvers
3.55 gears manual
2008 fz1
Chris44117 is offline   Reply With Quote
Old 05-26-2016, 03:14 PM   #27
MPT ghost cam tune
3.55 gears manual
2008 fz1
That's why I was considering it but from this thread it seems like it would be a pain in the *** to install and maintain. Just seems more involved than I really want to deal with
Old 05-27-2016, 08:20 AM   #28
Nothing at all. Been completely great. I change the lubricant every 5,000 miles. I have driven it hard as hell. Love it. I will say that i have the extra loud BOV... quite a whistle. listen to it before getting that option lol. Me and kids love it. Girlfriend and neighbor says it sounds like a jet airplane. As for performance mods I have the Beefcake racing kit so it came with ID1000 injectors and Brisk plugs, loud BOV, JMS boost a pump, JLT intake. I also have the Boss IM, JLT oil seperator. Pypes Headers, H pipe, and Pype bombs. Many susupension and driveline mods too. Most all in signature lines. Beefcake came with a Lund tune
Old 05-27-2016, 09:42 AM   #29
Awesome that's sounds like what I had originally planned on if you're talking about the beefcake special. I have adjustable shocks and struts as well as adjustable panhard bar with springs but I still need to get uca's and lca's. What driveline mods have you done? I'm assuming I would need a new clutch with the extra power and I'm also planning on getting the aluminum driveshaft. I have roush ab and I'm ordering the bbr off road x pipe to go with it so I'm not sure on headers yet I'll have to see how loud it is with the x pipe. I don't mind loud I just don't want wake the dead loud haha. Plus it seems like lots of money for the gains you get with headers
Old 05-27-2016, 10:04 AM   #30
Honestly I didn't notice squat from the headers. I only did with the thought being easier flow out better when supercharged. I love the sound of the H but thats just preference. As for the offroad it is LOUD. My AB are muffler deletes so yours will be a little quieter I think but higher pitched because of X pipe. Honestly the headers dont really make it that much louder. I did get a gauge pillar for oil pressure and boost gauge. Driveline I have the Tremec T56 magnum transmission, Aluminum 1 pc driveshaft and McLeod RSX twin disc clutch with lightened steel flywheel. I did the clutch line upgrade as well (all that in one package from JPC) I also got the MGW short shifter for it. LOVE the set up. I have a video from the other day on Instagram if you have that.
I will be at Mustang Week again if your going as well.
Old 05-27-2016, 10:48 AM   #31
2014oxstang's Avatar
I opted for the race BOV as well and cannot wait to hear it lol. YouTube and other misc. videos don't do it any justice whatsoever I can tell....
2014oxstang is offline   Reply With Quote
Old 05-27-2016, 11:00 AM   #32
Yeah that's the only reason I would have gotten them but you pretty much just confirmed there isn't much difference but I thought there would be a big difference in how loud it is. Dang dude I plan on getting everything you listed except I might just see how well the stock transmission holds up even though I know that's the weak point in these cars. I'm taking summer classes this year or I would go I would love to see your car. What's your Instagram name?
Old 05-27-2016, 03:49 PM   #33
Superchargers and turbos cook cat pipes on this car....seen it more than once...so headers aren't a bad idea for this car....
Old 05-27-2016, 09:55 PM   #34
Wouldn't getting rid of the cats with an off road x pipe solve that?
Old 05-28-2016, 06:38 AM   #35
Count Dragula's Avatar
Turbo all things. I have a oilless 82mm comp turbo. No oil lines only coolant lines. Turbos generally do require more maintenance but that's the price you pay to make more power.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
JPC oil breather Sakib 2011-2014 V6 Mustang 3 05-30-2014 06:09 PM
jpc november sale Sirtat 2005-2010 Mustang GT 0 11-25-2013 11:10 AM
JPC Paxton Kit, Deal? DWC_SmOziLLa 2011-2014 Mustang GT 10 10-05-2012 05:41 PM
02:24 AM
