Cooling System A/C NightMare - Mustang Evolution
Old 05-21-2016, 11:57 AM   #1
Region: New Mexico
I'm stumped, need some guidance.
About two weeks ago I was driving home and my A/C quit blowing cold. Googled the issue and everyone says compressor is bad, get ready to spend $1200+. Not good.
Next morning, driving to work, the A/C is blowing ice cold, so I assume no issues. That day, while returning home, A/C will not blow cold and car overheats - complete with steam coming out of the hood, coolant sprayed all over the engine bay, etc. Even a couple of gallons of coolant on the ground. Even more awesome was when a guy in a Hellcat blew by me and honked. Sweet, proud to be a mustang guy......I thought.
So - I get home after letting the car cool down. I pop the hood again, look at the mess no clue what could be wrong and I start the car, go for a 45 min horse beating drive. A/C blows ice cold, no overheating, no problems whatsoever.
A few days of this go by, sometimes I have cold A/C, sometimes not. The correlation here is that when the A/C isn't blowing cold, I know I am about to over heat. Not fun.
Today - I had some time. So here is what I did.
I filled the coolant res with water knowing I would spill some on the driveway. Started the car, coolant inlet/expansion tank lid off without turning A/C on. Car ran for 30 minutes until turned it off when the water was boiling out of the tank. What I noticed was, the cooling fan(s) NEVER kicked on. NEVER.
I let the car cool down, started it up again, ran for 10 minutes, same thing - water boiled out of the tank, cooling fan never turned on.
3rd time. Started the car, let it run for about 5 mins. At that point, I turned the A/C on - blowing nice and cold and the fan kicked on. No overheat, no boiling water spraying out.
Why doesn't the cooling fan turn on unless the a/c button is pressed?
Why does the a/c blow cold and everything is fine but when it blows hot, I've overheat and have to pull over?
Hard to be a die hard mustang fan when your 2011 car with 50k miles is acting like a 70's model with 100k.
Help
El Guapo is offline   Reply With Quote
What do you do when you completely flush out a cooling system and the car still runs hot? Dru General Mustang Discussion 5 04-02-2010 03:59 PM
cooling system flush - Help!!!- 00stang3.8 Pre-2005 V6 Mustang 2 11-11-2007 11:10 PM
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
Burping the cooling system? I_luv_HP&trq General Car Discussion 2 09-06-2006 09:55 PM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
09:47 PM
