Hood latch disengaged! - Mustang Evolution
Old 05-21-2016, 03:21 PM   #1
k1DBLITZ's Avatar
Exclamation Hood latch disengaged!
Has this happened to anyone?
I was pulling out of Sam's parking lot and accelerated quickly to make it into the turning lane. After I entered the lane I began to brake quickly. At this point I am headed straight. There was quite a jarring bump in the road unbeknownst to me. It was enough to cause the ABS to kick in but the tires seems to stay planted.
I proceed to the highway... after some spirited merging I'm driving along (at the speed limit) when I notice my hood started popping up/bulging. My first thought was catastrophic engine failure, but then my brain quickly realized that the engine wasn't sputtering, I wasn't decelerating, etc.
I move over to the far right as quickly as I can while letting off the gas.
The whole time my brain is analyzing (while in a bit of shock, mind you) and I realize that the hood had become unlatched and the secondary hood catch was preventing my hood from slamming into my windshield.
After I pull over I pop the hood and eye over the engine bay quickly.. everything looks in place so I slam the hood down ensuring it is in place.
As I drive home I'm a bit gun shy at this point...
I've never had this happen before...Now I'm a bit leery of driving down the highway..
Has this happened to anyone before? Is there a recall on the hood latches I'm not aware of?
I can't believe that going over a well placed bump could cause the hood latch to release.
Thank goodness for that secondary latch! I would have been screwed.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 05-21-2016, 03:45 PM   #2
Region: New Mexico
Never happened to me. Let us know what you find out.
WoodDA is offline   Reply With Quote
Old 05-21-2016, 03:53 PM   #3
GrabberMeBlue's Avatar
Far reach, but is it possible the last time you closed the hood it didn't latch completely? Maybe grabbing just enough to appear closed but not caught completely, and then the jar was enough to pop it? How long have you had the car? If it never happened before and you keep an eye on it and it doesn't happen again, I would probably chalk it up as a fluke. The other thing you could do is has someone pull the release from inside the car and you look under the hood to make sure the cable and latch are moving freely with full range of motion. I had an old Dakota where the cable needed to be greased up from time to time or it wouldn't spring completely back and allow the hood to fully latch when closed.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 05-21-2016, 05:02 PM   #4
k1DBLITZ's Avatar
I thought about that too, but it's extremely unlikely.
I drove the same highway on the way to Sam's and the hood didn't pop up.
I also drove that same highway (to and from) to get gas last time I drove the car.
Bought it new in March of 2014.
I will definitely look into that... Thanks.
Old 05-22-2016, 09:25 AM   #5
JOberlander's Avatar
I've had the latch mechanism fail or jam partway on a few cars in the past. It's usually one of the springs that's the issue or something got a bit bent.
JOberlander is offline   Reply With Quote
Old 05-22-2016, 07:18 PM   #6
That secondary hook is there for a reason. Check and see the latch mechanism moves freely, like everyone is saying, by having someone pull the handle with the hood up and you just watch the actuation.
I watched this go bad on the road just the other day. Some ******hat went around me in Dad's new Maxima, cutting me off and got a couple hundred yard away when the hood flew up and smashed his windshield. I felt it was poetic justice, frankly.....
Old 05-22-2016, 08:21 PM   #7
twk
twk's Avatar
When I bought my '09 used, one of the many little things I had to fix was the hood jiggling around as I drove over rough surfaces. I adjusted the snubbers in the front corners a bit and quickly fixed that problem. Then on my first drive out, BAM, the hood popped up off the latch on to the secondary latch. Like you, it startled the crap out of me.
I had adjusted it a bit too much. The front corners are now down a tiny bit, the hood still doesn't jiggle, and it latches much better! Something I wasn't paying attention to.
twk is offline   Reply With Quote
Hood won't shut. New latch needed? Bryan02V6 Mustang Paint, Appearance & Detailing 13 09-10-2012 01:18 AM
Hood latch ? Poopyhead44 1996-2004 Mustang GT 9 08-22-2012 11:22 AM
Squeak when the clutch is disengaged RedRocketGT 1996-2004 Mustang GT 10 07-16-2012 08:20 PM
How do I latch my hood on my 67 Mustang? Zachaios General Mustang Discussion 3 03-10-2010 10:31 PM
NTB ASAP hood latch support and rod mild2002gt Mustang Parts for Sale and Wanted 2 03-03-2005 06:07 PM
02:55 PM
