Steeda Clutch assist spring - Mustang Evolution
Old 05-27-2016, 05:14 PM   #1
Incase anyone is wondering... Get it!
I put mine in yesterday, the pedal actuation feels a bit lighter overall, could just be me though. However I can feel exactly when the clutch engages instead of the floaty kind of guess before. In fact compared to where I assumed it engaged prior to install the clutch engages close to the top of the pedal travel. I thought it was further down. In short the assist spring clearly reveals just how nebulous the OEM setup really is.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Old 05-27-2016, 05:23 PM   #2
tj@steeda's Avatar
You are not the first ... this part has been a huge hit at improving the overall feel!
We appreciate your support & feedback!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 06-02-2016, 12:10 AM   #3
Any idea if it fixed the high rpm clutch sticking issue? Considering one.
visback is offline   Reply With Quote
Old 06-02-2016, 12:33 AM   #4
It's solved all clutch issues I've had. No more sticking and better high rpm feedback.
Old 06-02-2016, 12:40 AM   #5
Perfect! Thanks! Couldn't get a response from anyone if it had fixed it for them. Ill give this a shot.
Old 06-02-2016, 08:01 AM   #6
noldevin's Avatar
I think this is more intended to be a pedal feel mod, I wouldn't count on it fixing anything.
noldevin is offline   Reply With Quote
Old 06-02-2016, 08:30 AM   #7
Well i have heard the sticking issue comes from the spring setup assembly ford put in these, some people had luck with taking the spring out, so maybe with a new better spring it might fix it.
Old 06-02-2016, 08:41 AM   #8
noldevin's Avatar
It might, but the real issue is the stock clutch itself doesn't like high rpms.
Old 06-02-2016, 11:20 AM   #9
Yeah definitely a new clutch would help but i cant justify putting in a new clutch on the car at 34k miles lol so a cheap fix for now is fine.
Old 06-02-2016, 09:21 PM   #10
I've done a lot of research. High rpm lock out should not be because the clutch does not engage... that would be shifter / gate / accuracy issue
From my research stock clutch will blow up if you live in the higher rpms often AND power shift / stress the clutch
I agree with this. Though there still isn't enough good info to tell why there are issues at higher rpms... for $10 this assist spring helps you feel the clutch actuation better and time your shifts better which would lead to being more accurate through the gate(s) which would solve high rpm lockouts. Worst case is it doesn't fix that for you but your shifting will have more feedback overall.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Now Available -Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) tj@steeda 2011-2014 Mustang GT 36 06-17-2016 10:46 PM
Steeda Clutch Spring ZombieSlayer 2015 Mustang GT 36 05-17-2016 07:48 PM
Steeda's S550 Mustang Clutch Spring Assist 35 lb/in - Now Available! tj@steeda 2015 Mustang GT 1 02-11-2016 07:37 AM
Wanted: Steeda sport spring and Steeda HD mounts paintmann111 Mustang Parts for Sale and Wanted 0 03-17-2015 05:03 PM
Spongy clutch after removing clutch assist spring. Fax22 2011-2014 Mustang GT 2 09-06-2014 10:19 PM
02:53 AM
