oil consumption - Mustang Evolution
Old 06-03-2016, 11:24 AM   #1
stampde's Avatar
oil consumption
So purchased my 11 GT about 2 months or so ago ,I've put 5,000 miles on it
Luv the car , picked up some Mobil 1 to do my 1st oil change this coming weekend
yesterday when i started it up in the A.M. it started clacking but seemed to go away after the oil pressure went up , So i did the diagnostic check and it still said oil 100%
went to work got some Motorcraft oil to dump in to get me to the weekend
5 quarts later it was on the stick , WTH ??
could it be using that much oil ? or did the dealer forget to fill it ?
oh and now the clack wont go away
2011 GT Auto
Old 06-03-2016, 11:37 AM   #2
Strange Mud's Avatar
the olm (100%) is the amount of expected life in the oil.....not how much oil is in it.
I hope you have a wtty on it, If so bring it back and don't volunteer that it needed 5 qts of oil.
Strange Mud is online now   Reply With Quote
Old 06-03-2016, 11:40 AM   #3
stampde's Avatar
ya its got a warranty ,we will see how that goes , ,there going to look at it Monday
it shouldn't have been 5 quarts low , why not tell them ? that's an issue ,it shouldn't be using that kind of oil ,either that or they for got to fill it ?
and I got NO low oil warnings or anything , I found out today the oil life should go down with the mileage , so that's not working either
2011 GT Auto
Old 06-03-2016, 11:42 AM   #4
for others (& OP) with any car check fluids often especially at first.
Old 06-03-2016, 12:32 PM   #5
stampde's Avatar
you got that right
2011 GT Auto
Old 06-03-2016, 05:28 PM   #6
Yeah, what to say. You've ghosted the motor because you didn't check fluids when you got a used car and for a further 5000 miles. Who knows what it had in it when you got it?
Good luck with the warranty, given the age of the car it's gotta be one of those used car dealer warranties, right?
Old 06-03-2016, 07:19 PM   #7
dave73's Avatar
Maybe whoever did the last oil change didn't realize it holds almost 9 quarts.
dave73 is offline   Reply With Quote
Old 06-03-2016, 11:11 PM   #8
It holds 8 but I'm sure that person must have figured out it held more than three....
Old 06-04-2016, 03:37 AM   #9
dave73's Avatar
oil consumption
No but I could see a used car lot mechanic dumping 5qts in it due to either being ignorant or cheap. Then you have driven it for 5000 miles which could have easily consumed a quart which is not uncommon or possibly more from internal parts not being properly lubricated and that would put it right there.
Old 06-04-2016, 07:44 AM   #10
REG
Oil consumption
FYI, most Manufactures use 1 qt/750 miles as the excessive limit. Above that they won't take issue.
Look for leaks as most vehicles today don't burn oil.
I don't think I've had a vehicle that used more than a quart every 3-5 k.
Usually they are down less than a quart when I do an oil change.
The mustang hasn't used any in 5 k
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 06-04-2016, 08:22 AM   #11
Here's my theory on Coyote oil consumption, based upon owning two Coyotes in a row, the first stick and the second auto:
I believe that it is the time spent in the overrun (compression braking) that leads to the oil consumption. My auto, being auto, is frequently upshifting and running at lower rpms than my old 3.73 stick car was and doesn't compression brake nearly as much or as hard as the old stick did, even when I use sport mode.
The auto doesn't use a drop, the stick would pretty regularly drink a quart or two between oil changes and put some small volume into a catch can every week. Both engines made great power and full compression so, there were no mechanical issues.
Old 06-04-2016, 08:52 AM   #12
k1DBLITZ's Avatar
Actually, I read the engineers made the oil pan 8qts so that we could go longer between oil changes.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 06-05-2016, 05:25 AM   #13
Originally Posted by stampde View Post
ya its got a warranty ,we will see how that goes , why not tell them ?
idk if it's a good idea to mention the 5 qts low or not, but keeping oil in it (and checking it!) is your responsibility. Not trying to slam ya but I would not want to give them an excuse. good luck and keep us posted on what they say.
Old 06-05-2016, 08:13 AM   #14
stampde's Avatar
purchased from a Ford dealer with a cary over 100,000 mile warranty , certified , yada,yada
being taking care of
2011 GT Auto
Old 06-05-2016, 08:21 AM   #15
stampde's Avatar
my old 3 valve had 130,000 miles on it it would use about a quart in 5,000 miles , this car has 60,000 on it i didnt expect it would use any and with an 8 quart pan i figured it was fine , it has that oil life meter on the diagnostic check and i actually would run that at least once a week ,and it constantly showed 100% i didn't know it was supposed to count down as i've never had one of those before, i thought it was telling me it was 100% full , stupid me for not knowing ? that was not working for sure , the oil presssure was at 80% of the gauge ,and NO warning lights either , so i'm sure the system wasn't working properly
2011 GT Auto
Old 06-05-2016, 08:25 AM   #16
stampde's Avatar
update : took it in for service yesterday and it didnt make it , engine wen't KABOOM!!! on the way there , about 15 miles from the dealer , waited 8 hours for a tow from Ford roadside assistance , what a joke
at least the dealer gave me a free loaner
hope fully a get a new engine and not a bandaid on the old one
oil pressure was great the whole time ,etc ... the tap got louder all of a sudden and then it made a weird noise and shut off
2011 GT Auto
Old 06-05-2016, 08:32 AM   #17
stampde's Avatar
i don't know why not , no car should use 5 quarts of oil , no car , i purchased a problem , and they should know about it , i have all the service records ,all the work was done at that dealer all oil changes were done there ,between 5 and 8 thousand mile intervals , and one just before i purchased it , so who knows what happened , in my opinion the tech forgot to fill it
only thing that makes sense to me , his girlfriend probably was texting him at work ,or it was lunch time or whatever ?
2011 GT Auto
Old 06-05-2016, 03:40 PM   #18
k1DBLITZ's Avatar
THIS! Damn millennials!
So annoyed at this crap happening at businesses everywhere.
IF YOU WORK IN A CUSTOMER FACING ENVIRONMENT, YOUR CELL PHONE SHOULD NEVER BE OUT!
Old 06-05-2016, 03:41 PM   #19
stampde's Avatar
LMAO
2011 GT Auto
Old 06-06-2016, 04:30 AM   #20
Stampede, it sounds like it's going as well as it can. The loaner is a great start and with the blown engine while that sux at least they can't tell you "it's normal" good luck and stay on the dealers friend list.
Old 06-06-2016, 12:17 PM   #21
Just adding my 2 cents.
When I picked up my 2012 in early 2014 it was also about 5 quarts low. I didn't notice it for about a week (my fault for not checking fluids and it was my first "new" car) when the engine started making a little ticking noise but no warning lights or anything. I just did a full oil change and it went away. Someone also had the bright idea of putting loc-tite on the drain plug. Found that when I couldn't get it out easily. From that point on I always had to add about a quart of oil between changes. All the research I did said it was fairly normal for a coyote motor. The strange part is I haven't had to add a drop since I installed long tube headers. Maybe this whole issue is something with Ford tuning.
J Vic is offline   Reply With Quote
Old 06-06-2016, 06:06 PM   #22
stampde's Avatar
wow, so i'm not the only one
ya i honestly think they forgot to put the oil in it
2011 GT Auto
Old 06-11-2016, 11:54 AM   #23
stampde's Avatar
update :
my dealer in putting a used engine in , hopefully its good
my engine had 76000 miles on it ,the used one has 42000
guess they didn't want to drop to much money into it ,considering I got it for $17500
was hoping for a new or reman
2011 GT Auto
Old 06-11-2016, 12:02 PM   #24
Revvv's Avatar
update :
Under warranty I would not have settled for less than a new crate engine.
Old 06-11-2016, 12:15 PM   #25
stampde's Avatar
I hear ya ,im just happy to get her fixed , they know I reflashed the ecm ,but cut me some slack ,because they know it had nothing to do with what happened
2011 GT Auto
Old 06-12-2016, 01:56 AM   #26
dave73's Avatar
oil consumption
Had he bought the car new he would have a better case for it. The case could be made now that what he is getting is as good or better than what he had. He doesn't have to accept it if it's not a good motor. Though hopefully it is and your saga is over. A junkyard motor is a crapshoot let's see how it plays out.
Old 06-12-2016, 05:10 PM   #27
REG
New motor
I agree, junk yard motor is a crap shot and the engine swap will probably bring up a few nuisances as well.
My advice, look to trade for a 12-14 with a little lower miles and sell them on I got all the bugs worked out with the new motor, its got 42 K not 72.
You might get a deal on one that some one had to have the ecco boost or something.
But don't be in a hurry, time is your friend! Plus you can flog the hell out of this one and claim it was a junk motor to start with!
Win Win!
Obviously it worked well for you sticking to you guns!
When you go into negotiations you don't have to get everything to win!
Also, getting the last word doesn't mean you won!
Old 06-12-2016, 09:37 PM   #28
Compstall's Avatar
Mines always burned oil. At oil change time I just get two 5-qt jugs because it goes through about a quart and a half to two quarts through the life of an oil change.
I have 6 cars, and the only one that sits dead on the stick the whole time is my 88 S10.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-13-2016, 07:06 AM   #29
stampde's Avatar
yup, still waiting ,although I am digging the 30+ MPG I'M getting with the Escape and the versatility of it ( can fit lots of stuff in the back ) lol
I miss My Stang
2011 GT Auto
Old 06-13-2016, 08:16 AM   #30
I rode the dealer's Escape for a month waiting on them to rebuild the trans in my last S197 so, I hear ya. Very convenient little box that thing was, way better than the Fukus I had for the first couple days.
Old 06-20-2016, 11:59 AM   #31
stampde's Avatar
finally got the car back over the weekend , all is well
funny $8200 work order , new belts ,hoses ,gaskets to transfer over parts ,intake pan,valve covers etc ... oil , Freon , coolant ,all part of warranty ,but they charged me $88 for spark plugs ,they weren't covered ?? lol ,whatever they had to make me pay something I guess ......
2011 GT Auto
Old 06-26-2016, 06:59 PM   #32
73jd31's Avatar
That's it??? Consider yourself lucky.. Now maybe you will check your oil level more often?
73jd31 is offline   Reply With Quote
Old 06-27-2016, 07:31 AM   #33
stampde's Avatar
I'm usually really good at that , but I guess I figured a low mileage car that just had an oil change at a Ford dealer would be good to go , my bad
put about 800 miles on this engine already and I've checked it 3 times ,lol
2011 GT Auto
Old 06-27-2016, 07:35 AM   #34
sweet, good luck with it. I also found the spark plug thing funny but at least that wasn't also labor.
Old 06-28-2016, 02:51 PM   #35
stampde's Avatar
ya I can't complain , the whole ordeal took about 2 weeks , loaner car , no hassle , they took care of me , no problems
2011 GT Auto
Oil Consumption tonyjuan 2005-2010 Mustang GT 8 02-23-2013 09:16 AM
oil consumption todd mulder 2005-2010 Mustang GT 10 09-11-2012 10:16 PM
Oil Consumption CurbRash 2011-2014 V6 Mustang 3 07-03-2012 11:00 AM
Oil consumption issue @ 101kmi. any conclusions????? rinfield2004 SVT Mustang 3 04-16-2012 10:24 AM
Oil Consumption Ravnus 2011-2014 Mustang GT 7 02-21-2012 06:26 AM
07:50 AM
