14 GT Crank no start! - Mustang Evolution
Old 06-04-2016, 10:35 AM   #1
Anyone have any issues with their 11-14 5.0 intermittently not starting. It cranks fine but seems like the fuel pump doesn't turn on. First happened a few months back when I installed Airlift suspension. I thought it had to do with the way the system jumps into the fusebox. Couldn't get it to start the entire day so it was towed to the dealer. They called back saying it started dozens of times & is fine. Fixed my Airlift wiring issue and no more problem until last month it did it once. This week it happens once but starts after a few tries. Yesterday it happens half a dozen times where it cranks & no start. The common factor seems to be warm weather. Called dealers & no idea! HELP ME PLEASE! Car only has 25K miles SMH
Steevelo1_stang is offline   Reply With Quote
Old 06-04-2016, 10:49 AM   #2
I think you already know the answer...go through the airlift again. Something has re-****ed up. Maybe run airlift off a relay and separate circuit, rather than off the fuse panel.
Old 06-04-2016, 10:56 AM   #3
I asked about that but not sure how to do it. I've been told these cars don't work that way. On other cars ive had you could wire directly into the ignition but have been told this can't be done anymore. The system needs to work like the entertainment system. On with key on, off with key off
Old 06-04-2016, 11:21 AM   #4
That's not rocket surgery. You just need to find a switched source and use that as your trigger wire for the relay. That isn't a total snap as modern cars work with interfacing modules that don't like other crap hooked to them. You can still power any switched source required object off 12v battery, you just need to remember to switch it off or you'll come back to a dead car.
Old 06-04-2016, 12:05 PM   #5
I don't understand why the ambient temperature seems to play a role. Though
Old 06-04-2016, 12:15 PM   #6
Just because it's warm both times doesn't mean there is a relationship. That's a confirmation bias. No way to determine that temp plays a role with the evidence you have.
Old 06-04-2016, 12:26 PM   #7
Been hot 5 times & 5 times its happened. Ill see today its supposed to be 90. I understand what you're saying but would like to have my suspension power on without having its own switch. I know a dozen people with the same suspension on this car & none have this issue.
Old 06-04-2016, 01:26 PM   #8
...and how many times has it been hot without issue? There is clearly something wrong with your install. The temp may be a factor but, don't get led down the garden path; you need to focus on what you did, not what the sun's doing.
Old 06-04-2016, 01:34 PM   #9
Not many. Its actually been unusually cool for southern California but i understand what you mean.
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 08:29 AM
crank but wont start SH4.6 1996-2004 Mustang GT 3 07-11-2013 01:44 PM
crank no start, cold weather kfuson92 2.3 Mustang 6 02-17-2013 02:11 PM
12 volt source in start & crank position ballajb Classic Mustangs 5 07-06-2009 09:26 AM
02:38 AM
