Automatic Tranmission removal - Mustang Evolution
Old 06-07-2016, 11:59 AM   #1
Kona Mike's Avatar
2011 Mustang Gt AT.....question. When removing the transmission, do you have to remove, mess with, or go anywhere near the AC compressor . Local Ford dealer may or may may have done some damage to my car. Just trying to get all the facts before I approach corporate.
Kona Mike is offline   Reply With Quote
Old 06-07-2016, 02:15 PM   #2
Kona Mike's Avatar
Old 06-07-2016, 04:12 PM   #3
The compressor is at the front of the engine so I doubt removing the trans would damage the compressor unless they also removed your engine for some reason and it got damaged that way. They might have damaged or disconnected some AC lines near the firewall by where the engine and trans bolt together if you are saying your air no longer works after the work.
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Old 06-08-2016, 07:42 AM   #4
I presume it was recall repair for you, right?
They might have hung the engine off its mounts when the trans was out and that might have strained or cracked a line.
There is no obvious nexus between the two subsystems though.
Tranmission help :) Jayjay 2005-2010 Mustang GT 12 11-25-2012 02:37 PM
tranmission crittenden03gt 1996-2004 Mustang GT 4 07-23-2012 01:30 AM
car losing tranmission fluid kickerofdoom Pre-2005 V6 Mustang 2 06-16-2012 11:19 AM
Will an older tranmission work on a newer car? imported_Andreas Classic Mustangs 3 03-20-2010 11:16 PM
TRANMISSION SLIPPING! Debras96stang Pre-2005 V6 Mustang 11 05-26-2006 11:30 PM
10:41 PM
