Please tell me there is a remedy - Mustang Evolution
Old 06-07-2016, 07:22 PM   #1
Alabama5OH's Avatar
Hey guys, changed all 4 brakes about 4 months ago because they were squeaking so figured they needed to be replaced. Well, not the case. They looked barely halfway worn down if even that. But i changed them anyway. Now my brakes are squeaking again and it drives me freaking nuts. So if there's any sort of concoction I can spray on them or something, please let me know.
2011 GT Premium
Roush Axelback | UPR O/R X Pipe | Bama 93 Performance and Race tune | MPT Ghost Cam Tune | JLT Cold Air | Brembo Package | Nitto 555
Alabama5OH is offline   Reply With Quote
Old 06-07-2016, 09:46 PM   #2
Psmith129's Avatar
My guess is that your rotors are glazed or you replaced the brakes with cheap pads . I would only recommend having rotors cut once in there lifetime but it's worth a shot .
Psmith129 is offline   Reply With Quote
Old 06-08-2016, 01:55 AM   #3
bucko's Avatar
Ceramic pads don't squeak; good pads for street driving. If you track the car, or tow (doubtful), then semi-metallic or metallic pads are the choice, but they squeak.
Applying anti-squeak on the pad backing helps quite a lot; some pads come with a backing already applied.
What brand of pads did you install?
Old 06-08-2016, 06:01 AM   #4
Alabama5OH's Avatar
Hawk Performance. I'm pretty sure I did ceramic too. And I've got the Brembos on the front.
2011 GT Premium
Old 06-08-2016, 07:10 AM   #5
Sterlingbeast5.0's Avatar
I have squeaked some every since installed new Stoptech cross drilled and slotted rotors with composite pads. Commenting so i can see all answere
Old 06-08-2016, 05:56 PM   #6
olerodder's Avatar
Region: Oregon
Did you turn the rotors when you put the new pads on???
Never....never.....put new pads on worn rotor....and never take used pads and put them on new rotors.
I had Brembo's and GT500 rears and used the stock Boss 302 pads in front on my Brembo's and the GT500 pads on the rear 13.8 rotors....never had an issue.
I can't see a need for drilled/slotted rotors....and if you get them hot enough they have been known to crack....slotted maybe....drilled no....IMHO
Old 06-08-2016, 06:07 PM   #7
Mlp07's Avatar
They will squeak in the mornings or when the rotors are wet, but it will go away once they get hot. That's what the oem pads do, once I had changed mine that went away.
Mlp07 is offline   Reply With Quote
Old 06-08-2016, 06:38 PM   #8
blackie's Avatar
Yes , they squeak easy in humid area, they will get a light glaze of
rust in just hours= squeak. I just lightly hold down the brake while accelerating lightly for a few seconds and it goes away.
Its very humid in Dallas.
blackie is offline   Reply With Quote
Old 06-08-2016, 07:43 PM   #9
olerodder's Avatar
Region: Oregon
Although the average humidity in my area is around 77% I've never had my Brembo's squeak...morning/noon/night. If I let the Mustangs sit for over a week the rust is barely visible....even without holding the brake pedal down it should be gone in one of two stops.
Old 06-08-2016, 07:48 PM   #10
olerodder's Avatar
Region: Oregon
Granted these are Brembo's with 4 piston front.....single piston rear.
If your rotors don't look like this it's time to have them turned and get new pads.
These pictures were taken at about 10k miles.
Name:	2015-05-13 15.26.38.jpg
ID:	202203   Click image for larger version
Name:	2015-04-11 12.52.16.jpg
Old 06-08-2016, 08:27 PM   #11
Red_Menace11's Avatar
Every pair I've had of Ceramic brakes have squeaked on me constantly...
The first time I switched to duralast regulars that are semi metallic.. I haven't had one squeak at all!
Red_Menace11 is offline   Reply With Quote
Old 06-08-2016, 08:35 PM   #12
olerodder's Avatar
Region: Oregon
If your ceramic brakes sqaueaked then you have some other issues....I've had two sets on my ole 14 TrakPak and no squeak....did I forget to say they were GT500 pads and rotors....
Remedy to subwoofer dash rattle in 2013 2013GTpremium Mustang Audio & Video 2 12-07-2015 11:04 AM
2015 Mustang Wheel hop remedy Thread (install videos) Seatown Stang Mustang DIY and Technical 0 08-25-2015 11:15 AM
Anyone know of a good remedy for removing those damn dealership decals? 08MustanGT 2005-2010 Mustang GT 18 03-15-2012 07:27 AM
Could someone please tell me is there a single fuse that works the fog lights in the 1996 Mustangs? Elishama General Mustang Discussion 2 03-24-2010 04:46 AM
Grandpa's Allergy Remedy n8r The Bar 12 10-10-2004 08:02 PM
12:13 PM
