Hot brakes - Mustang Evolution
Old 06-10-2016, 07:51 AM   #1
Hot brakes
Hey all, over the weekend I changed out all of my brakes. New rotors and Brembos up front, new larger rotors in back. Stainless steel lines all around. This morning was my first "long" drive with them. When I pulled into work I could smell something burning. I figured it was my brakes. Yep, the rear rotors were on fire, especially the driver rear. Fronts were fine. Any ideas why?
G x crSent from my iPhone using Mustang Evolutionôh
Old 06-10-2016, 08:11 AM   #2
Didja use a caliper piston rotation tool to install the rear pads? If you didn't, you've jacked up the rear calipers and will need to replace them.
Old 06-10-2016, 08:34 AM   #3
Yeah, I rotated the piston to seat it in order for it to fit over the pads and rotor.
Old 06-10-2016, 09:07 AM   #4
Check the e brake. Disconnect the cables and see if that helps.
Old 06-10-2016, 09:52 AM   #5
Voltwings's Avatar
were they on fire or were they smoking? Bedding new pads will cause them to smoke. If you installed the 13.8 rears and were able to pump enough heat into them during a commute to set them on fire, you would have had to notice the obvious amount of drag from that corner.
Old 06-10-2016, 10:29 AM   #6
No fire. They were just very hot b
Old 06-10-2016, 10:32 AM   #7
Strange Mud's Avatar
was traction control coming on? maybe messed up speed sensor? Any drag on wheels (hard to test I know)
Old 06-10-2016, 11:13 AM   #8
No traction control light. There was probably drag, I wasn't really paying attention this morning. But now that I've been thinking about it, my car didn't coast as well as usual.
Old 06-10-2016, 11:31 AM   #9
make sure the caliper is free on the pins and the piston is in far enough.
Old 06-10-2016, 11:49 AM   #10
noldevin's Avatar
Sounds like one or both was probably dragging. Happened to me after I took my brakes off to paint the calipers. I took it all off, cleaned up the hub, rotor hat, and rusty brake pad backings, and put it all back together. Works fine now but I cooked my pads and rotors when it was dragging. I think it was either the ebrake cable not seated right or the crumbly rust bits causing extra pressure.
noldevin is offline   Reply With Quote
Old 06-10-2016, 06:08 PM   #11
Update: drove home and all rotors were of normal temperature. Definitely digging in the rotors, I guess I'll just keep an eye out.
Brakes dragging when hot? slick3 2011-2014 Mustang GT 1 07-09-2015 08:35 PM
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
Hot Brakes Ssstang Pre-2005 V6 Mustang 12 04-14-2008 10:34 PM
Hot chick, loser car. **WW** Brent The Bar 32 09-16-2004 08:10 PM
My lil bro showing off my hot rims Black95GT The Bar 12 12-06-2003 11:46 PM
11:55 PM
