2013-2014 Trunk Filler Panel Removal - Mustang Evolution
Old 06-16-2016, 06:24 PM   #1
Does anyone know how to remove the outside rear trunk filler panel on 2013-2014 GT's? I know they are different from 10-12's. I have the fiber panel off and the 2 torx head screws. Is it just 3M tape after that? I don't want to break it off.
PerkinBaLL is offline   Reply With Quote
Old 06-16-2016, 06:57 PM   #2
There are clips that hold it in after you take the 2 screws out from inside the trunk. I don't believe there is any double sided tape and that its just the clips and foam
StarzTA17 is offline   Reply With Quote
Old 06-16-2016, 07:25 PM   #3
wgolden30's Avatar
Why u removing it
wgolden30 is offline   Reply With Quote
Old 06-16-2016, 09:54 PM   #4
http://www.americanmuscle.com/mmd-decklid-panel-1314-cust-install.html
Hope this helps..gonna be changing mine out saturday
lcp9073 is offline   Reply With Quote
Old 06-16-2016, 10:27 PM   #5
oxford5pointoh's Avatar
Name:	ImageUploadedByMustang Evolution1466137511.667956.jpg
Here is the back of mine when I took it off. Slide something like a plastic putty knife or a bondo spreader between the panel and the deck lid and you will feel the clips. Gently apply downward pressure to the ones in the top and upward pressure to the ones on the bottom to release the clips and it pops right off. No tape.
Old 06-17-2016, 08:12 AM   #6
I'm removing it to get to the GT emblem. Having a custom one made and need to send the orignal with the design. Also thinking of getting stock one painted to match the car.
Old 06-17-2016, 03:01 PM   #7
tezz's Avatar
you don't have to take the panel off then - just remove the center cap. put painters tape around the edge to keep from scratching the panel, slide a putty knife or plastic trim removing pry wedge under the edge and gently twist - working your way around. There is double sided tape holding it on along with locating pegs.take your time so you don't scratch it up.
2013 Ingot GT, 6M, FRAA Susp, GT500 Axle Backs/Wheels/Spoiler, Baer/Shelby brakes, Recaros, Trac-Cal, etc.
tezz is offline   Reply With Quote
Old 06-17-2016, 04:24 PM   #8
^ you can do that, however I do not recommend it. The black surrounding plastic is so easy to scratch or mar. If you pop the panel off you can pop the faux gas cap off from the back with ease.
2014 Mustang GT Running Horse for rear trunk panel kaveh14GT 2011-2014 Mustang GT 1 08-11-2014 06:24 AM
2014 gas filler shutoff issue. dacm99 2011-2014 V6 Mustang 4 05-26-2014 08:58 PM
2014 trunk emblem removal? AmericanBulldog 2011-2014 V6 Mustang 4 05-27-2013 06:27 AM
2013 Trunk floor panel.... 13BlkSunshine 2011-2014 Mustang GT 6 01-16-2013 02:07 PM
2013 Mustang GT Rear Deck Lid Panel Removal Charleston 2011-2014 Mustang GT 3 07-17-2012 04:46 AM
11:23 AM
