Brake Pads - Mustang Evolution
Old 06-17-2016, 07:02 PM   #1
wgolden30's Avatar
Brake Pads
Who's has what brake pads for their coyote?
And recommendations
wgolden30 is offline   Reply With Quote
Old 06-20-2016, 08:46 AM   #2
noldevin's Avatar
Brembos or standard brakes? What kind of driving are you going to be doing? What are you looking to gain or change by using a different pad?
Help us help you.
noldevin is offline   Reply With Quote
Old 06-20-2016, 01:48 PM   #3
I'd like to know any recommendations as well, my car has the brembo brakes and I wasn't too impressed with them. Maybe the pads are worn out but I dont hear anything, car has 36k miles. Car is a daily street only but I do brake hard often going through the twisties and such.
visback is offline   Reply With Quote
Old 06-20-2016, 02:07 PM   #4
noldevin's Avatar
Hawk HPS 5.0 is a good choice for street only use.
Nothing will beat a lower temp range track pad (ex, carbotech xp8) for stopping power and fade resistance on the street, but they are noisy and very dusty. I wouldn't recommend them for everyday use unless you enjoy cleaning wheels often.
Usually if you change to a different type of pad, you want to get a new rotor as well so you can properly bed the brakes and not worry about incompatible compounds.
Old 06-20-2016, 02:16 PM   #5
I'll look into those thanks! any idea how long the stock brake pads last?
Old 06-20-2016, 02:26 PM   #6
jkeaton's Avatar
No one can really answer that for you, it all depends on your driving style. My wife can wear out a set of pads in 10,000 miles. I can make them last 50,000.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 06-20-2016, 02:28 PM   #7
noldevin's Avatar
I'm a bad example. I road course my car so my stock pads (and rotors) went quick.
Old 06-20-2016, 02:59 PM   #8
DallasStang77's Avatar
Stock brake pads suck balls. The front wore out in about 50k and the tears are about to go out at 57k.
Braking wise they suck even worse than the brakes on my F150. No bite at all and after I changed out to some decent (but by no means the best) aftermarket pads the braking improved noticeably. I think I got the PowerStop Z26 Brembo pads and even those are twice as good as the stock ones.
brake pads charkelly9 Pre-2005 V6 Mustang 32 11-24-2005 11:59 AM
Installing Brake Pads and Rotors Mustang414 Pre-2005 V6 Mustang 13 05-21-2005 07:04 PM
Brake pads 19ClearCobra96 1996-2004 Mustang GT 2 02-20-2005 05:26 PM
Brake pads... SilverStang96 1996-2004 Mustang GT 11 11-23-2004 04:07 PM
Hawk Brake Pads Crispy Pre-2005 V6 Mustang 0 08-21-2004 05:27 PM
12:56 PM
