Coyote High Mileage - Mustang Evolution
Old 06-25-2016, 09:35 AM   #1
wgolden30's Avatar
Coyote High Mileage
Guys,
Proud owner of a new used 68k mustang.
Looking for any recommendations of important maintenance of the v8 11-14 GT.
Please no, it's like any other high mile car replies. I am not very car savvy and am looking for good tribal knowledge.
wgolden30 is offline   Reply With Quote
Old 06-25-2016, 10:55 AM   #2
DallasStang77's Avatar
Coyote High Mileage
Originally Posted by wgolden30 View Post
Guys,
http://www.wheels.ca/news/here-are-7...used-car-home/
Assuming you've checked prior to purchase for mechanical problems and signs of abuse.
But technically you're asking us to tell you that the Mustang is some sort of special vehicle than any other used car. It ain't. Lol
But do check for services on all recall issues. At 68k the brake pads should have been changed out. If not do not get factory pads. Go after market.
Old 06-26-2016, 09:59 AM   #3
grabber12's Avatar
68k is not High mileage at all. It is at a point where you would want to flush the transmission just for a piece of mind. Check the color of your cooling system fluid and possibly do a complete flush on that as well. Most people do oil changes and that's it so when you buy a car and are unsure, its just a safe practice to flush any fluid you think is in need of a change. Get an oil catch can and install that to help with oil build up in the intake manifold.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 06-26-2016, 10:01 AM   #4
grabber12's Avatar
oh and do all the work your self. the stuff names above is easy to do and it will save you money when you do the work.
Old 06-26-2016, 12:01 PM   #5
Not car savyy? Take it to a good shop and have them change ALL the fluids, just because. It'll cost a couple bucks but, you know what you have and if there are any issues. The factory fluids are actually quite good quality and you might want to use those, if you're planning on just leaving it stock. Fresh spark plugs if it's running in any way other than totally smooth, NGK Iridium IX in the stock heat range are fine there, or the stock Motorcraft.
Old 07-01-2016, 07:02 AM   #6
wgolden30's Avatar
They want to do an injector clean. Should I just buy a bottle or Lucas instead for 3$?
Old 07-01-2016, 08:13 AM   #7
Strange Mud's Avatar
save the $3 (or much more if they do it) also note this as a shop that likes to sell unnecessary stuff.
Highest Mileage Coyote? seville 2011-2014 Mustang GT 139 05-02-2017 11:29 AM
High Mileage, Newer model vs Low mileage older Davey13GT General Car Discussion 1 07-07-2013 06:49 AM
High Mileage Motor Justin 1979-1995 Mustang GT 13 05-15-2006 06:39 AM
High Mileage engine oil DropTop_Stang Pre-2005 V6 Mustang 0 10-24-2003 07:17 PM
Mileage???What do u think is High... Black95GT The Bar 8 07-27-2003 07:01 PM
11:54 PM
