Brake caliper problem? - Mustang Evolution
Old 06-25-2016, 06:28 PM   #1
Red_Menace11's Avatar
So my front right caliper is hanging up on something...it is running much much hotter than the left side and the wheel is hard to turn when I jack it up....
Don't know if it's a bad caliper or a bad brake hose....
The pins are greased and move freely and the pads are good as well...
Stock brakes...not brembo
Has anyone had this problem? Or has any knowledge on the matter?
Thanks
Red_Menace11 is offline   Reply With Quote
Old 06-25-2016, 06:59 PM   #2
king_13's Avatar
Brembos or stock?
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 06-25-2016, 08:17 PM   #3
Stock
Sorry for not including that
Old 06-26-2016, 03:55 PM   #4
UPDATE:
It was the break hose leaving the caliper...I'm guessing it was clogged up inside or it went bad.. I don't know but that solved the problem!
Old 06-26-2016, 04:40 PM   #5
wmschoonover's Avatar
Glad you figured it out.
The rubber brake lines are actually dual lines (inner and outer section) and when they are damaged by hanging them while changing brakes etc, the line gets damaged inside and makes releasing pressure more difficult and sometimes impossible. That's why you should never let your caliper free hang from the brake lines. Always set it up on the rotor or hang it with a small bungie cord.
Not saying you did that but that's one of the biggest reasons for failure that's if heard of.
wmschoonover is offline   Reply With Quote
Old 07-12-2016, 12:32 AM   #6
Name:	ImageUploadedByMustang Evolution1468301362.556952.jpg
ID:	203325Click image for larger version
Name:	ImageUploadedByMustang Evolution1468301378.636508.jpg
ID:	203326Click image for larger version
Name:	ImageUploadedByMustang Evolution1468301391.506287.jpg
UPDATE
Here was the problem with the old brake hose. There was obviously something clogging up at the one spot where you can see in the pictures. That spot is exactly where the clamp attaches to the ABS line to hold them together.
Then where the spot was had cracks in it...also in the pictures.
I'm guessing the fluid got down in the cracks and started to swell, not allowing the let the fluid come back and thus keeping the brakes applied.
Old 07-12-2016, 05:36 AM   #7
Strange Mud's Avatar
excellent update
thx!
Old 07-12-2016, 07:31 AM   #8
Robostang's Avatar
That is ugly. Thanks for the info. Time for everyone to check their brake lines!!!
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-12-2016, 08:04 AM   #9
Since you found something in the line... Are you going to flush the brake system?
Old 07-12-2016, 04:35 PM   #10
Oh no I don't plan on doing all that lol
Old 07-24-2016, 03:23 PM   #11
UPDATE:
Put my car up on my lift today to change the rear brake pads...
And GUESS WHAT...
The front right tire is still locking up! Even after I tested it after I put the brake line in and it was fine.
That is so confusing due to what i found in the brake line...
But now it's time to change the caliper cause I really don't think this line is messed up already...
God what did I get myself into getting a ford 😩
Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding Napoleon85 2011-2014 Mustang GT 22 02-02-2012 05:12 AM
Brembo Brake Caliper Question avengnd 2011-2014 Mustang GT 6 01-09-2012 09:50 PM
brake caliper paint question bluestang1724 Pre-2005 V6 Mustang 11 03-23-2011 12:53 PM
Rear brake caliper anchor bolt size/help CakeOrDeath? Pre-2005 V6 Mustang 5 09-01-2007 01:04 AM
Brake Caliper Paint? FloMasta24 Mustang Audio & Video 21 09-12-2004 05:06 PM
09:07 PM
