Regular or Permium Gas - Mustang Evolution
Old 06-29-2016, 05:39 PM   #1
I have a 2014 Mustang V6 and I got over 20k miles on it and I go to the pump 2 twice a week and use the premium so after a while I was wondering if there will be any different if I used regular gas instead of premium.
I drive fairly fast 70-80 freeway and 40+ anywhere else. I don't do racing unless it's on rare occasions with friends.
Pandaism is offline   Reply With Quote
Old 06-29-2016, 05:42 PM   #2
wmschoonover's Avatar
That really depends on what mods if any and if you are using a tune. I also have a 2014 V6 and before I started adding the mods I was running 87 just fine. Now I only run 93 but I have several mods and I'm running a Bama Tune for 93.
wmschoonover is offline   Reply With Quote
Old 06-29-2016, 05:48 PM   #3
I'm running full stock
Old 06-29-2016, 05:49 PM   #4
king_13's Avatar
More horsepower/torque from 93, other than that done run a lower octane that the tune you're running if you are.
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 06-29-2016, 05:57 PM   #5
So I should be fine using 87 if I'm remind stock and dont remind having less hp/torque since I dont really race
Old 06-29-2016, 06:11 PM   #6
king_13's Avatar
Yep, even the 5.0s can run off 87 no problem. The timing isn't advanced as much on the stock tune on 87.
Old 06-29-2016, 06:38 PM   #7
Okay there shouldnt much of a different I assume and I can some money
Old 06-29-2016, 06:51 PM   #8
king_13's Avatar
If you're not racing it, you won't notice a difference and the car will function just as well as if you put Premium in.
Old 06-29-2016, 10:11 PM   #9
Premium is only if you are doing something extreme like racing and stuff.
peter123wallace is offline   Reply With Quote
Old 06-30-2016, 09:00 AM   #10
You aren't getting more power out a V6 with 93, guaranteed. Run 87, you'll be fine.
Old 06-30-2016, 09:04 AM   #11
Strange Mud's Avatar
what they said. I tried premium in mine for a few fill ups 2x...once I saw a mpg improvement the 2nd time not. I run regular 98% of the time.
Old 06-30-2016, 09:42 AM   #12
Sterlingbeast5.0's Avatar
93, it is reccomended but not necessary. it isn't even as much about HP or MPG which it technically helps with but longevity and engine cleanliness. I would unless it is financially a strain to pay the little more
Old 06-30-2016, 10:23 AM   #13
parkerbickel's Avatar
Luckily for you 87 is regular lol here in Colorado regular is 85.
2011 V6 Race Red - Roush Axle Back Exhaust, GT500 Steering Wheel, GROM Audio Bluetooth Module, Raxiom Aero Smoked Tail lights, Raxiom GPS
parkerbickel is offline   Reply With Quote
Old 06-30-2016, 11:36 AM   #14
noldevin's Avatar
There is no reason to run anything more than 87 octane in your v6 unless you have an aftermarket tune that was set up for a higher octane. If you feel a difference switching from 87 to higher octane without a tune, your gas station has crap 87 and you shouldn't go there anymore.
This is absolutely false, higher octane does not help with engine cleanliness, and only affects longevity if your car is tuned too aggressively and starts knocking. The exception being that certain brands of gas may add extra additives to their premium gas. This may help with cleaning but actually hurts octane.
noldevin is offline   Reply With Quote
Old 06-30-2016, 12:01 PM   #15
JimC's Avatar
The 3.7, just like the 5.0, will adjust for higher octane. Both use the knock sensors to advance timing.
Earler models only a tune would make the adjustments.
Now, is it as much as tuning? On either platform you really won't notice the extra 10 or 15 horsepower.
Sent from my SM-G930P using Tapatalk
JimC is offline   Reply With Quote
Old 06-30-2016, 12:03 PM   #16
noldevin's Avatar
Even on the 2016 models, Ford rates the 300hp at 87 octane. They specifically state premium recommended next to the ecoboost and 5.0 hp ratings.
Old 06-30-2016, 01:04 PM   #17
It won't infinitely adjust timing up for increased octane. There is a very small amount of upward adjustment allowed for but, it's capped tightly and won't increase power meaningfully.
Old 06-30-2016, 01:06 PM   #18
93oct the only way to go!!
Wheela is offline   Reply With Quote
Old 06-30-2016, 01:06 PM   #19
Jon3.7's Avatar
What is permium? Some new type of fuel? hehe
93 Tuned, 87 stock.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-30-2016, 01:30 PM   #20
JimC's Avatar
And that is what I said. The increase isn't enough to really notice. It's there, but without a tune not enough to make a difference on either platform
Old 06-30-2016, 01:44 PM   #21
Revvv's Avatar
My car has a 91 octane tune and I run 93.
There are no special cleaning agents, super power additives, or any other mythical advancement to higher octane fuel. In simple terms, the higher the octane number, the slower the fuel detonates.
The best example I can give is this; an engine with a high compression ratio needs a fuel that is stable under extreme pressure. If you run a low octane fuel in a high compression engine the fuel can ignite in the cylinder before the piston strike is complete. Now you have a downward force on an upward moving object that is connected to the other pistons via the crank shaft.
Several bad things can happen in this situation. Rods can bend or break. Bearings can be flattened out and destroyed. Head gaskets can blow. Cylinder walls can be scratched. Sometimes blocks themselves can crack.
Old 06-30-2016, 02:35 PM   #22
RBK
I have a 2012 V6 and never run premium, I had a 2011 5.0 and also ran regular. In the V6 you are not going to gain anything by running premium, if you engine does not knock, which it should not do in a V6 running regular, the management system will not ****** your timing which cause you to loose power. In my 5.0 I'm sure I lost power as the computer probably retarded my timing to keep the engine from knocking. A gallon of premium does not have any more energy in it than regular, unless of course you get premium without ethanol as ethanol does not have as much energy as gasoline. Save your money and run regular until you make some type of modification that requires you to use gas that will withstand higher pressures before igniting.
RBK is offline   Reply With Quote
Old 06-30-2016, 02:57 PM   #23
king_13's Avatar
This is indeed a myth/lie, and could not be any further away from the truth.
Octane is not a measurement of power or cleanliness, simply the ability to resist igniting prematurely. Which is needed in high compression and turbo applications.
Detergents in fuel do not have anything to do with octane rating, the gas supplier does.
Companies that use above the number of average detergents are listed on the "Top Tier Gas" website. Examples include Shell, Exxon, BP, and Chevron.
Old 06-30-2016, 04:33 PM   #24
Revvv's Avatar
Now we are all repeating one another using different phrasing.
Old 06-30-2016, 05:31 PM   #25
I wonder if the place where I buy gas is on that list???
"Mo's Liquor"
Old 06-30-2016, 05:58 PM   #26
king_13's Avatar
I'd prefer 1 wrong and 10 right posts than 10 wrong posts and 1 right, leading the OP to believe the wrong information to be true.
Old 06-30-2016, 06:06 PM   #27
Gravydog316's Avatar
93 Tuned, 87 stock.
ERR MUH GERD PERMIUM!!!
I only put Premium in when my sis borrows my car. I tell her, "Fill it to the top, & DO NOT get regular!!" hee hee...
(lol never saw the forum. my bad. again.)
Premium vs regular gas scurfie 2011-2014 Mustang GT 37 06-22-2015 08:30 AM
Boo :: 2014 Ford V6 Permium Pilotman323 Member Garages 2 05-26-2014 12:18 PM
Switch from premium to regular gas NEED HELP Nick Proben 1979-1995 Mustang GT 41 04-27-2013 07:02 PM
Who puts regular gas in new 5.0? 11SHELBYGT500 2011-2014 Mustang GT 33 05-19-2011 08:34 PM
Burning regular gas in a 5.0 jimbullit 2011-2014 Mustang GT 35 02-22-2011 10:00 AM
09:54 PM
