diff fluid - Mustang Evolution
Old 06-30-2016, 02:46 PM   #1
diff fluid
I have the 2014 track pack. I changed the diff fluid with royal purple 75-140. how much should it hold? I have 4 quarts in there and I still cant touch the fluid with my finger in it. should be 5mm below the fill hole correct? **** is 20 bucks a bottle... haha.
Massery94 is offline   Reply With Quote
Old 06-30-2016, 03:05 PM   #2
The 8.8 rear in my 01 takes slightly more than two quarts... I have a difficult time believing that your 14 is requiring nearly double that!
Is the rear end sitting relatively level while you are filling it?
Or is the car jacked up from the side?
Old 06-30-2016, 03:16 PM   #3
Yeah it's on a 10 ton lift. And there's 4 quarts in there.
Old 06-30-2016, 03:33 PM   #4
Well that is strange.
It shouldn't be taking that much. Even with an optional diff oil cooler, it should take less than four quarts.
I assume that it has the original track pack differential cover?
Old 06-30-2016, 03:36 PM   #5
Yeah it's the boss 302 diff cover
Old 06-30-2016, 03:39 PM   #6
If you have your owners manual handy, look in the section that shows the fluid fill level capacities and see what it says about the differential.
Old 06-30-2016, 03:48 PM   #7
It says 5mm below fill hole. Just found it hard to belive it's more than 4 quarts.
Old 06-30-2016, 03:50 PM   #8
And I don't know what unit of measurement that Ford used in the 14 owners manual, but in mine the diff capacity is measured in pints.
So keep that in mind.
Old 06-30-2016, 03:57 PM   #9
Yes. I find it hard to believe also.
It doesn't say how much? Just 5mm below the fill hole?
Maybe they want it filled to a higher level with the track pack?
Now I'm second guessing the fluid level in my diff. It is setup just like a track pack. I don't have the diff cover though.
Old 07-01-2016, 12:44 AM   #10
I just filled mine with the same stuff and mine only took 3.5 quarts before overfilling.
2013 mustang v6 premium package
Powder coated gold metallic wheels
MPT ghost cam tune
Quarter window louvers
3.55 gears manual
2008 fz1
Chris44117 is offline   Reply With Quote
Old 07-01-2016, 09:05 PM   #11
When I installed the Ford aluminum finned diff cover on my base model 14 GT, it took two quarts to refill it. I also measured how much fluid came out of it and it was right at two quarts. The cover I installed is the same as the one on the track pack and Boss cars so I don't know how you are getting four quarts in and you still cannot touch oil.
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Diff Fluid Change Socal Stangman 2011-2014 V6 Mustang 14 06-01-2015 11:58 PM
Changing Diff Fluid JoeyM91 General Mustang Discussion 2 01-18-2015 05:17 PM
Diff fluid Screaming Mach General Mustang Discussion 6 10-19-2013 10:01 PM
Rear diff fluid 96 stang General Mustang Discussion 12 06-27-2011 06:10 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
12:13 PM
