A6 - Issue on 2-3 shift - Mustang Evolution
Old 07-04-2016, 07:36 AM   #1
Having a weird issue I wanted to see if anyone else has experienced. Car is a 14 GT with Vortect V3 kit for reference.
Car started doing this recently and I am trying to chase down what it could be - basically on the 2-3 shift when I am WOT, the car will nose dive a bit, shift hard enough chirp the tires, and pick right back up. Right before the shift at 7000pm I can see the boost shoot back towards around 5psi - I'm on the stock 3.6 pulley.
All the IC pipes look good, no issues with the t-bolt clamps. The tial BOV is clamped down pretty tight, stock bov removed and blocked off.
Nomadic is offline   Reply With Quote
Old 07-04-2016, 08:17 AM   #2
Whose tune are you running? That is where I would start, asking for a reflash perhaps. Odd that this is only happening on one of the shifts, and not any others.....
Old 07-04-2016, 08:22 AM   #3
AED tune, took it to a local dyno, it is also doing it on his test tune as well.
Old 07-04-2016, 03:02 PM   #4
It's unusual on the stock pulley but, I'd be looking at belt slip. What hole do you have the idler in? Second one from the outside?
2014 Premium GT, SGM, Brembo, Auto, Tech, Comfort, etc. GT500s, Steeda UCA, VMP auto N/A tune. 100 shot nitrous on BBR tune. Best e/t 11.42 at 120.64
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 01:42 AM
shift indicator stuck on park, but can shift Da_xtreme 2005-2010 V6 Mustang 1 02-19-2015 07:55 AM
Mustang sport shift (shift at 3000 rpm's ?) Charlesph55 2011-2014 V6 Mustang 5 07-24-2014 10:58 AM
Annoying shift issue in Sport Shift mode... alludc 2011-2014 V6 Mustang 9 02-08-2013 03:20 AM
Econo Shift/Skip Shift Rant michael81 2011-2014 Mustang GT 17 01-30-2012 07:52 PM
10:00 AM
