Coolant leak? What engine bolt is this? With pics. - Mustang Evolution
Old 07-04-2016, 10:07 AM   #1
blmustang01's Avatar
So I was just going to top it off and not check engine compartment as I thought maybe it's just the blistering summer heat but a perfectly sealed system should never have low coolant levels, right? So I took my 15000 lumen flashlight and saw this bolt with orange on it. Nice that it's orange, so it's easier to locate? I also noticed liquid on cement surface but thought it's the A/C system water. Car has 33k miles.
Anyway, what bolt is this on the engine? Thanks for any help!!
2013 mustang gt/leather/pony projection/gt500 axle backs
blmustang01 is offline   Reply With Quote
Old 07-04-2016, 12:30 PM   #2
I guess I can just use threadlocker on it. Probably just leaking from the bolt.
Old 07-04-2016, 12:32 PM   #3
oxford5pointoh's Avatar
Looks like one of the water pump bolts
Old 07-04-2016, 03:01 PM   #4
That's the AC compressor down there....
Old 07-04-2016, 03:42 PM   #5
^nope. Look at the first pic. That's the water pump pulley. Ask me how I know.
Name:	ImageUploadedByMustang Evolution1467664933.075589.jpg
Just installed my whipple and I've been where that pic was taken. AC is waaaaaay lower left
Old 07-04-2016, 05:20 PM   #6
Yeah it's hard to tell exactly where we are from the photo. Lots of real estate in that particular corner. You're probably right.
Old 07-05-2016, 12:31 PM   #7
2012 V6. Had a similar problem--coolant would sometimes "pour" out and other times, not leak. Anyway, the problem was solved with a new water pump at 30000 miles.
kipschitz is offline   Reply With Quote
Old 07-05-2016, 12:59 PM   #8
RBK
First, a closed system will loose liquid over time. A bolt rarely is the cause of the leak, it is where the coolant accumulates and drips from making it look like what is leaking. If it is near your water pump you probably have a bad bearing in the pump causing it to leak.
RBK is offline   Reply With Quote
Old 07-08-2016, 03:36 PM   #9
But a small amount over time? Probably just due to heat exposure and evaporation?
I am unsure as to how long I have been driving below the cold-fill level because being a relatively new car, I know the coolant can last over 100k miles so I never bothered to check the level.
I cleaned the area where the leak was and topped off the coolant and no leaks so I don't when it started.
Old 07-10-2016, 09:56 PM   #10
bsyo1021's Avatar
Water pump pulley bolt for sure.
2012 GT with lots of stuff. ---> Overview Video: https://www.youtube.com/watch?v=tn7qoKqQXwY
Updated Exhaust clip: https://www.youtube.com/watch?v=UtxWRQlREmY
bsyo1021 is offline   Reply With Quote
Coolant Leak? BrKu789 1979-1995 Mustang GT 3 12-28-2010 09:40 AM
bad coolant leak jmachleit 1979-1995 Mustang GT 8 01-13-2010 05:31 PM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 09:40 PM
coolant leak inside car Racin02GT 1996-2004 Mustang GT 8 06-19-2006 07:19 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 11:38 AM
09:49 AM
