Popping noise from front right - Mustang Evolution
Old 07-12-2016, 12:37 PM   #1
I have a 2014 mustang gt and it just randomly started making a pop noise from the front right strut or brake. It has sr lowering springs and has been fine for the past 4 months but it just started. I checked everything to make sure it was tight and it was so I'm wondering if it could be the strut itself. It only does it when the car is transferring weight like when going from reverse to drive without stopping or heavy breaking at about 20 mph. Any hel would be greatly appreciated
cballard3 is offline   Reply With Quote
Old 07-12-2016, 01:00 PM   #2
oxford5pointoh's Avatar
Most likely the strut mount. Did you reuse the factory one? See any ball bearings fly out when you installed the springs?
Old 07-12-2016, 01:06 PM   #3
I did reuse the stock one but no ball bearing came out stay closed the entire time I made sure of that.
Old 07-12-2016, 01:20 PM   #4
My guess is that is your problem. They are cheap piles of crap.
Old 07-12-2016, 01:22 PM   #5
Which ones would you recommend getting if that is the problem?
Old 07-12-2016, 01:40 PM   #6
Steeda heavy duty
Old 07-12-2016, 01:53 PM   #7
Robostang's Avatar
+1 on the Steeda heavy duty
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-13-2016, 12:21 PM   #8
Beviking's Avatar
+2 on Steeda
Beviking is offline   Reply With Quote
Old 07-13-2016, 10:15 PM   #9
It is definitely the strut mount, they good bad pretty quick once u open them up. Mine went bad around the same time as yours, I had SR performance as well.
visback is offline   Reply With Quote
Front Right Popping Sound KARgt13 2011-2014 Mustang GT 11 09-22-2014 11:11 AM
2nd gear popping popping out Cleancobra22 General Mustang Discussion 4 05-29-2012 08:36 PM
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
popping noise??? girlandherstang Pre-2005 V6 Mustang 8 06-28-2008 10:20 AM
Popping Noise 98StangGT 1996-2004 Mustang GT 8 08-04-2006 11:11 PM
02:56 AM
