2014 Mustang 5.0 Engine - Mustang Evolution
Old 07-20-2016, 07:01 PM   #1
Mustang_96's Avatar
Some people say that some of 2014 Mustang 5.0s have 2015 5.0 Engines. It that true? How could I find out if my has a 2015 engine? Also heard something about the build date of the car has to do with the engine.
Mustang_96 is offline   Reply With Quote
Old 07-21-2016, 07:32 AM   #2
noldevin's Avatar
I don't think any of them have a full 2015 engine. I believe a handful might have a few 2015 parts.
noldevin is offline   Reply With Quote
Old 07-21-2016, 08:06 AM   #3
It's the head castings. Some have the later castings. My late 14 has them. What's inside is the same as the 2013s though.
Old 07-21-2016, 01:40 PM   #4
Mustang_96's Avatar
How can I find if mine has the 2015 head casting?
Sent from my HTC One M9 using Mustang Evolution mobile app
Old 07-21-2016, 03:06 PM   #5
Pull the mani cover, look immediately down at the front of the cylinder head, there is a water port there. 15+ will have a straight edged casting here, the sub-2014 will have a dogleg in the same place.
It doesn't make any difference anyway. The performance is unchanged. It's still loaded with the same camshafts, valves, springs and VCT tuning as the 13 cars. My '14 is not any faster, mph wise, at the track than my similarly loaded 2012 car.
Old 07-21-2016, 07:04 PM   #6
Heads are better tho right? like if you were to swap in boss intake cams would you get a higher potential performance?
Old 07-21-2016, 07:16 PM   #7
I think the heads are loaded with all the same stuff as the 13 cars so, the fact the castings are a bit better is diminished. Like I said, the car ain't faster, materially. Nitrous speeds my car up....
Old 07-22-2016, 02:44 PM   #8
Eh... The 11-14 heads will support ridiculous power bone stock so whatever. Would be nice to have the newer castings for a bolt on car tho. Might support a little more power there with the boss cams and a boss or frpp intake.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-22-2016, 05:55 PM   #9
Ya, mine has the 2015 heads, Supposedly larger ports, 10+ hp.
TroyB is offline   Reply With Quote
Old 07-22-2016, 06:01 PM   #10
Right.....
My instrumented testing reveals no gains. Large ports won't help you if you have the same cam timing and valves. Might actually hurt a bit.
Old 07-22-2016, 06:16 PM   #11
Think it's the concept of easy air in/easy air out.
Old 07-22-2016, 07:02 PM   #12
I'm guessing you haven't built too many engines. Much more important on the road than total port volume is cam timing, low lift flow and port velocity.
No matter how much volume you have, if it's choked by a small valve, you can't take advantage of it and might induce reversion and other problems.
Old 07-22-2016, 08:01 PM   #13
Obviously you can't read or comprehend that I'm not stating my opinion or fact, I'm merely stating what I've found investigating the change on these cylinder heads. For your information I've owned my own repair shop for 14 years and have employed some of the best mechanics in the field. Dumb ***
Old 07-22-2016, 08:42 PM   #14
When you use terms like easy in easy out in this context, it betrays a simplicity of mind, bigger is better philosophy around how engines work. I don't really see how it could be read differently than that.
I've put this particular conception to the test at the dragrstrip, with similarly equipped s197s. There is no measurable difference between the supposedly better castings than the older, lower rated v8 the 11-12 cars had. I've got nearly 200 passes worth of data here.
Old 07-22-2016, 08:54 PM   #15
noldevin's Avatar
I'm with 5HLO on this one. Slightly better head casting isn't going to do you any good without the other goodies to go with it.
With an NA car, the weakest link will still be your performance limiter and in this case, your cams, valves, tune, etc are all weaker links than the head. If one part is limiting your flow, opening up something that comes after it isn't really going to help.
Old 07-22-2016, 09:00 PM   #16
Not my opinion, just stating what I've found on the subject. FYI, I have a Degree in Psychology, Human resources, Human Behavior and Sociology. Sometimes simpler is better. Lol
Old 07-22-2016, 10:58 PM   #17
....for a Canadian, you seem to have an unusually volatile temperament. You've made a bunch of claims unsupported by evidence and and when contradicted, with evidence, you blow a gasket and start cussing me out. Then, you try to showcase your education as if that makes it all ok somehow.
Old 07-22-2016, 11:26 PM   #18
If u read back what I posted I've made no personal claims, just the information that I've found on the subject. No biggy. Just u don't know me and u have no idea how many engines I've built in my life, that's ok. Hence the Human behavior degree.
Old 07-22-2016, 11:31 PM   #19
I might have showcased my education, because my intelligence was questioned, that's ok, sorry if I came off to aggressive, Didn't mean to be.
Old 07-23-2016, 06:47 AM   #20
Well, I think everything that needs saying has been said and we each know where the other stands.
I put my virtual hand out to you , sir.
Old 07-25-2016, 04:01 PM   #21
Do you like apples?
Well I got her number, how do you like those apples? I just could' t resist that's what it reminded me of. Motor on!
goman is offline   Reply With Quote
2014 mustang
2014 Mustang GT/CS :: 2014 Ford Mustang GT/CS 14GRAYGTCS Member Garages 0 07-28-2015 04:42 PM
2014 Mustang 3.7 :: 2014 Ford Mustang 3.7 jayochs Member Garages 0 11-17-2014 04:31 PM
2014 Mustang :: 2014 Ford GT Celtic Member Garages 0 08-23-2014 12:59 PM
Mustang GT 5.0 2014 :: 2014 Ford Mustang jeanmorissette Member Garages 0 09-20-2013 07:08 PM
02:47 AM
