Rattling under floorboards - Mustang Evolution
Old 07-24-2016, 07:15 PM   #1
Fax22's Avatar
Ok so I my car is lowered on Sport lines which are pretty low and I had to park over a small mound of mulch one day. Don't ask why.
Basically, when I backed out, the mulch was pulling on something under my car. I gave it a bit more gas and it pulled itself out. Everything seemed fine.
It is not
Since then, there is what I thought was a pretty bad exhaust rattle that sounds like it is where the h pipe is. It only occurs over sharp bumps in the road and I can actually feel it in my gas pedal a little bit.
I might have to rule out the exhaust being loose since I just put my cats back on my car today and retightened and adjusted the exhaust and it is doing the exact same thing.
I am hoping it is not suspension related although I have not checked yet.
It is more severe when my right front tire hits the bumps.
I am koni orange struts and sport line springs with cc plates.
Thanks in advance for any help you guys can provide.
Sent from my SAMSUNG-SM-G930A using Mustang Evolution mobile app
Fax22 is offline   Reply With Quote
Old 07-24-2016, 10:40 PM   #2
oxford5pointoh's Avatar
Predicting your Koni orange on that side is blown, or your CC plate is loose/ strut bolt is loose.
Old 07-24-2016, 10:47 PM   #3
DiESeven's Avatar
Check to see if your KONIs look like this lol... Fixed my rattle by taking that junk out and putting yellows in.
Name:	ImageUploadedByMustang Evolution1469418313.793334.jpg
Name:	ImageUploadedByMustang Evolution1469418350.581553.jpg
Instagram: @v6beast
Old 07-24-2016, 10:50 PM   #4
Fax22's Avatar
My konis are only a year old but I took the wheel off and found that one of the bolts was loose. It was tight on the driver's side. I'll post a picture in a second
Old 07-24-2016, 10:51 PM   #5
Fax22's Avatar
Not sure if that was the problem yet since I haven't driven it yet but hopefully that was a simple fix.
Old 07-24-2016, 10:53 PM   #6
Fax22's Avatar
Image didn't show up in that last post.
Old 07-24-2016, 10:55 PM   #7
DiESeven's Avatar
Let me know when you drive it. Looks clean under there so it's most likely not leaking or going bad.
Old 07-24-2016, 11:02 PM   #8
Fax22's Avatar
I won't be testing it out until tomorrow. It's midnight here right now. I just had to check or I wouldn't have been able to sleep. Im guessing that was the issue though. Makes a lot of sense.
Old 07-25-2016, 03:23 PM   #9
Fax22's Avatar
Ok I just went for a long drive and the problem is completely gone. Feels like a different car. Good thing I found the problem early before it got worse.
Water on floorboards JHghers 1996-2004 Mustang GT 17 08-24-2014 07:29 AM
Rattling noise under car upon acelaration.. 9stan5 Pre-2005 V6 Mustang 22 04-15-2013 12:20 AM
Huge Rattling Under the Car David00 Pre-2005 V6 Mustang 10 03-09-2013 09:31 PM
Help Me! Rattling under my hood sixty4half 2005-2010 V6 Mustang 3 09-04-2012 08:46 AM
Rattling noise under car vinnygt SVT Mustang 5 02-08-2012 11:19 AM
03:19 AM
