2015 mustang 4 piston "brembo" - Mustang Evolution
Old 07-25-2016, 12:26 PM   #1
Mlp07's Avatar
Hey guys I've been searching and searching for this. This is what I've gathered from other forums. The 4 piston ford calipers will fit with little modifications, you will need 14 inch brembo rotors from the 11-14. The 15s have a different offset so won't fit. You will need to get 9/16 generic ID washers or the caliper won't sit right and will look like this Click image for larger version
ID:	203720with the washers it will correct and fix that problem.Click image for larger version
ID:	203721. Another issue would be getting a different brake line forgot what brand and will need to be trimmed to make it sit flush Click image for larger version
ID:	203723Click image for larger version
ID:	203724 other than everything should fit fine. Again this is what I've gathered from a lot of forums and would like more info on this and help other fellow forum members go this route that's looking for a better brake set up for cheap as it will only cost between 350-500 for everything.
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
Mlp07 is offline   Reply With Quote
Old 07-25-2016, 12:31 PM   #2
Mlp07's Avatar
Old 07-26-2016, 01:05 AM   #3
oxford5pointoh's Avatar
Ummmm you should probably put that caliper on the other side, going to be pretty hard to bleed the air that's at the top like that 🤔
2015 mustang
It is coming up """FAST""" Yes it is !!! ronnie948 The Bar 32 08-10-2016 05:17 AM
FR Brembo vs. Brembo TTmustang10 2015 Mustang GT 8 05-04-2016 07:35 AM
To Brembo or not to Brembo (13 GT?) MustangCPA General Mustang Discussion 14 03-20-2015 09:21 AM
On a 1994 mustang gt unable to get the piston to compress? Dace General Mustang Discussion 5 04-10-2010 05:20 PM
10:32 PM
