Barton short shifter noise - Mustang Evolution
Old 07-29-2016, 09:38 AM   #1
I recently bought a Barton short throw shifter with the two post bracket. To be honest I'm not too impressed with it. At first the noise that came into the cabin wasn't too bad, usually when shifting you could hear the transmission working. But now gears 2,4, and 6 all make a lot of noise while in gear. Does anyone have any experience with this ?
Tyd123 is offline   Reply With Quote
Old 07-29-2016, 10:15 AM   #2
Hodor's Avatar
I don't have the shifter, just the Barton shifter bracket (not two-post), and the NVH increased a good bit over the stock bracket. I can only imagine it is much worse with the entire setup, along with two-post. This is the main reason I haven't invested in an aftermarket shifter - the noise would drive me crazy. I can't hear it with the windows down though, of course.
2012 GT Premium, Brembo Package, M6
VMP Gen II S/C & Tune, GT500 Axle-Backs/Spoiler/Strut Mounts
Steeda Sports/Shocks/Struts, J&M PHB, GT/CS Chin, MMD Fog Deletes
Hodor is offline   Reply With Quote
Old 07-29-2016, 10:42 AM   #3
At first I was only able to hear the transmission while shifting. I have borla s type axel backs on the car as well. Now even with the mufflers, the Windows down, and the radio on, this shifter is making the most noise. I'm worried it might be causing damage to the transmission.
Old 07-29-2016, 12:08 PM   #4
The Barton shifter transmits a lot more noise and some of these mt82 make more noise than others.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 07-29-2016, 12:49 PM   #5
Could changing the transmission fluid quiet things down?
Old 07-29-2016, 01:51 PM   #6
Sterlingbeast5.0's Avatar
Its the shifter. They are good at transmitting noise
Old 07-29-2016, 01:51 PM   #7
elkoritaNAY's Avatar
I installed the sr short shifter and bracket and went back to my regular stock shifter and bracket. The excessive cabin grinding noise was horrible. Noise still there now currently, but not as bad.
410 rwhp 320 ft-lbs
elkoritaNAY is offline   Reply With Quote
Old 07-29-2016, 06:09 PM   #8
I put dynamat around the trans tunnel inside and it helped a lot of the trans noise go away. Mine is a noisy one, can hear the gear clash in the lower gears but it shifts smooth as butter despite the noise it makes. Part of it is the thin fluid Ford specs.
I have an mgw gen 1 and love it.
Sent from my SM-T710 using Tapatalk
Old 07-29-2016, 09:16 PM   #9
I've heard mgw is quieter than Barton. Should I look into that?
Old 07-29-2016, 11:46 PM   #10
LeoGTCS's Avatar
I installed mine about two weeks ago, I have the shifter/two post combo, and to me it's not that noicy. I don't know if I'm not hearing too much NVH because I changed to RP fluid and installed the gasket between the shifter and housing at the same time. I can definitely hear the synchros and feel some vibration( only in the shifter) but not that bad as you describe it. I really love the way it feels and works I would never go back to the crap the stock shifter was.
2014 Mustang GT/CS Silver
K&N CAI- Barton Shifter/2Post- Koni yellows & SR springs- Whiteline Suspension- Pypes pypebomb super system
2014 Explorer Sport Ruby Red
LMS 93 Performance-3 Bar V4 tune-160*Tstat-SP534 plugs-Windstorm-H&R Exp Springs
LeoGTCS is offline   Reply With Quote
Old 07-30-2016, 07:39 AM   #11
I forgot to mention that I also installed a new gasket in between the shifter and the housing. I didn't notice a difference in sound though.
Old 07-30-2016, 09:16 AM   #12
LeoGTCS's Avatar
Can you describe a little be more what kind of noice r u experiencing? There's some things I read that may cause noice. Not tighting all the screws can produce noice, also I read if the shifter rubber booth is not installed like it should would cause noice and may be trouble to put the tranny in some of the gears.
Old 07-30-2016, 09:26 AM   #13
When I had first installed the shifter and bracket the only noise I was hearing was when I shifted gears. I believe it is the synchros working. It's like a swooshing sound. Almost like a rush of air. After a few days all of the bottom gears (2,4, and 6 and also reverse) make a slight grinding noise. It's very annoying. Ive been sure to tighten all the bolts down but not over tighten. The rubber boot is on perfectly. I've watched Barton's instillation videos. I even tried spinning the handle on the shifter 180 degrees. Barton says if you're reverse lockout it 2 inches then your shifter needs to use the 2013 side reverse lock out. I've tried it both ways and saw no difference which I thought was weird.
Old 07-30-2016, 03:11 PM   #14
Coosawjack's Avatar
YES!!!
Coosawjack is offline   Reply With Quote
Old 07-30-2016, 05:53 PM   #15
LeoGTCS's Avatar
A friend has the MGW and it is quieter, I didn't buy it cause of budget. Definitely something is wrong, but I dont think Its the shifter. Have you pulled all apart again to see if something is installed wrong?
Old 07-30-2016, 11:56 PM   #16
Yeah I've installed and reinstalled it to make sure I did everything right. I switched back to the stock shifter but left the two post bracket on. It actually shifts really nice and there is no more noise. I'm pretty happy with the way it drives now.
Old 07-31-2016, 06:39 AM   #17
Some of these mt82s make more noise than others. I wouldn't be concerned. Dynamat on the trans tunnel inside will help a lot.
Old 10-04-2016, 09:26 PM   #18
Dans5oh's Avatar
Yeah I have the Barton short shifter and two post bracket too and I don't have any noise unless I rest my hand on the shifter or when shifting slowly. I don't mind the small noise increase because the throw is sooo close now. I will admit the shifter is very very notchy, but not bad when speed shifting. I love the Barton but if I had to do it over again I would buy the MGW.
2014 GT Premium, Sterling Grey Metallic, 6sp, Brembo's, 3.73's, Comfort, Security, Spoiler Pkgs. Barton short shifter w/two post bracket, Redline hood struts, AM shifter ball, BMR lca, Roush axle backs.
Dans5oh is offline   Reply With Quote
Old 10-09-2016, 04:36 PM   #19
5.Shark's Avatar
Have had mine for almost 5 years no problems
5.Shark is offline   Reply With Quote
Hurst billet shifter plus two or Barton short throw shifter?? hdez41 2011-2014 Mustang GT 25 01-26-2015 09:01 PM
Barton Short Throw Shifter PBrown92 2011-2014 V6 Mustang 2 12-11-2012 03:10 PM
MGW vs Barton Short Throw Shifter Brock23 2011-2014 Mustang GT 26 10-26-2012 04:21 PM
Barton short shifter for the 2011 DDTCM Pictures and Videos 0 01-13-2011 08:46 PM
06:25 PM
