2014 Premium - Cluster Going Crazy... - Mustang Evolution
Old 07-31-2016, 08:20 PM   #1
Howdy folks,
2014 GT Premium with Brembos and around 12k miles, BAMA tuned back in October 2015. No other electronic mods or issues until today. Started her up and after 5 or 10 seconds got all sorts of warnings on the cluster, the AC/nav unit turned off, no turn signals on dash (though they are working externally but flashing fast), TPMS warning light on and e-brake light on. No CEL though and car drives fine...
It was a very hot and humid day - don't know if condensation could be the issue? Other than that, I'm stumped.
Anyone any ideas? I don't want to just disconnect the battery and hope that all is good. (Battery is reading 14.5volts so I don't think it's the issue).
Thanks,
Davy
corrado15 is offline   Reply With Quote
Old 07-31-2016, 11:15 PM   #2
crjackson2134's Avatar
Well it does sound like low voltage regardless of battery. I'd check all the connections and make sure it's not a poor ground.
2014 Black GT Premium - Track Pack - (Apocalypse)
2017 Black Nissan 370Z Roadster - (Lucille)
crjackson2134 is offline   Reply With Quote
Old 08-01-2016, 01:20 PM   #3
What is the static voltage of the battery engine off? Load test it as well. (DVOM on the battery, crank the car over and see what it drops to under startup).
It sound like the IPC lost communication with the car temporarily. If you have tech, you can drop codes throught that, just press radio buttons 3 and 6 simultaneously, until the system enters bezel diagnostics, and follow the prompts to "read dtcs".
Old 08-03-2016, 02:29 PM   #4
Thanks for the suggestions guys. Traveling for work at the moment but will throw a multimeter on it when I get home.
5LHO - what is the 'tech' you're referring to?
Thanks!
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Old 08-03-2016, 03:01 PM   #5
Nav and tech. You'll have the big screen in the centre console.
Old 08-03-2016, 03:07 PM   #6
Got it thanks - I do.
Old 08-03-2016, 03:19 PM   #7
I expect you'll see a code for "lost communication with IPC". That's the instrument panel cluster.
Old 08-04-2016, 12:42 PM   #8
Cluster going crazy.
I got the same problem when my battery was on her way out. I would troubleshoot the battery first. Otherwise, humidity may have gotten in there somehow, but I doubt it.
tonyjuan is offline   Reply With Quote
Old 08-04-2016, 01:05 PM   #9
Thanks man!
For Sale: 2013-2014 Premium Cluster & Switch oxford5pointoh Mustang Parts for Sale and Wanted 3 03-04-2016 08:38 AM
Anyone correct their own mileage on a base to 2014 premium cluster swap? Blown13Coyote 2011-2014 Mustang GT 1 09-15-2015 10:27 PM
2014 V6 Base Cluster to Premium Cluster sid719e 2011-2014 V6 Mustang 11 08-17-2014 01:23 AM
I must be going crazy. matthews.stang Mustang Audio & Video 18 05-01-2007 09:52 PM
Oil pressure going crazy Zim Pre-2005 V6 Mustang 9 11-17-2004 11:28 PM
02:33 PM
