Gear issues - Mustang Evolution
Old 08-10-2016, 06:10 AM   #1
jek57's Avatar
Gear issues
Went on a road trip this past sat as i was close to home i noticed noise comming from the differential rumbling in decel and just driving also slight gear whine put a one piece driveshaft on a week before that prior to the trip eveything sounded good .Im thinking the pinion bearing went bad i checked the driveshaft and everything is tight ,,Any else have pinion bearings go bad? i had 3.55s installed this spring ford racing with full install kit also .
jek57 is offline   Reply With Quote
Old 08-12-2016, 11:48 AM   #2
olerodder's Avatar
Region: Oregon
Did you check the pinion angle before and after you installed the 1 piece driveline????
Go through this list...rearend gear noises can be one thing or a multitude of different things...first on my list would be to check the pinion angle.
Diagnosing Differential and Driveline Noises | eBay
Old 08-13-2016, 05:35 AM   #3
jek57's Avatar
I thought that if your car isnt lowered you don't have to adjust the ,i might be wrong on that if so i will check that out as well it's going to the garage Mon
Old 08-13-2016, 10:09 AM   #4
olerodder's Avatar
Region: Oregon
Anytime you swap driveline components....driveshaft....especially from a 2 piece to a single piece....or rearend components....even if you are not dropped....you should always check to make sure the pinion angle and transmission shaft angle are within specs....granted the transmission angle is pretty much set in place and hard to change.
Now with that said the 1 piece driveshaft will translate a lot more noise than the old 2 piece so maybe this condition has been going on for sometime without your notice...
Old 08-13-2016, 11:31 AM   #5
jek57's Avatar
That very well could be i had it back to the guy who did the install a couple of months ago cause they were making that rumbling noise he did some adjusting and they were much better but after we made a road trip with the car last weekend the noise got worse closer to home we got so i suspect something went bearing or something but i'll see Mon...Thanks for your feedback i'll post when i find out what the deal with them.
Old 08-14-2016, 10:18 AM   #6
olerodder's Avatar
Region: Oregon
Do you know what he did to make the rumbling noise go away?
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 10:22 AM
2nd gear issues Notorious_rob Shelby Mustang 20 11-16-2013 07:35 AM
2012 mustang 3rd gear issues Sprintradc 2011-2014 Mustang GT 13 07-29-2012 07:58 AM
01 GT auto gear issues iflyhi22002 Pre-2005 V6 Mustang 5 12-28-2005 05:48 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
07:03 AM
