Check engine light diagnostic tools ? - Mustang Evolution
Old 08-12-2016, 01:37 AM   #1
Victoryrc's Avatar
Question Check engine light diagnostic tools ?
I want to be able to read my check engine light codes if I ever get any.
What are my options for doing that?
The last time I've done this was probably 1989 on my last Mustang GT.
Probably a dumb question but it's been a while as you can see.
Thank you for the help
2017 Mustang GT
K & N filter for factory airbox.
Blue coil covers.
Victoryrc is offline   Reply With Quote
Old 08-12-2016, 10:21 AM   #2
showsomeskin's Avatar
Do you have a performance programmer? If so you can read check engine lights that way or you can buy an OBD 2 scan tool
Sent from my IPhone at 120mph in 3rd@10psi
showsomeskin is offline   Reply With Quote
Old 08-12-2016, 11:04 AM   #3
Victoryrc's Avatar
No,I do not. I don't want to change the computer software as its a daily driver.
Primary goal is to just be able to get the car running if it has a no start, or just a malfunction light.
2017 Mustang GT
Blue coil covers.
Old 08-12-2016, 11:08 AM   #4
Strange Mud's Avatar
a reader will not fix the problem but it can help diagnose it. I have a simple tester/reader that I (or friends) use often. Go to your local parts monger/wall-mart or online and spend $50 for one. I'd tell you what mine is but it's several models old.
Old 08-12-2016, 11:22 AM   #5
You got the tech/nav package? You don't need anything if you do. Press radio buttons 3 and 6 simultaneously until the bezel enters a speaker walk test. cancel test and follow the prompts to "read DTCs". Bob's yer uncle, done.
Old 08-12-2016, 11:31 AM   #6
jkeaton's Avatar
If not, you can buy a reader that will clear codes for less than $20 nowadays. Best tool you can have in your toolbox.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-12-2016, 05:29 PM   #7
Beviking's Avatar
^yes and ^^yes
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 08-13-2016, 07:35 AM   #8
Victoryrc's Avatar
No I do not that's a nice feature though I bet you a lot of people don't know they can do that.
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 07:36 AM   #9
Victoryrc's Avatar
What are they called? OBD2 code Reader ?
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 07:45 AM   #10
Hodor's Avatar
Yes, among other names:
https://www.walmart.com/ip/Electroni...anner/41285202
A multi-gauge can read and clear codes also:
http://www.americanmuscle.com/aerofo...ptor-0512.html
2012 GT Premium, Brembo Package, M6
VMP Gen II S/C & Tune, GT500 Axle-Backs/Spoiler/Strut Mounts
Steeda Sports/Shocks/Struts, J&M PHB, GT/CS Chin, MMD Fog Deletes
Hodor is offline   Reply With Quote
Old 08-13-2016, 08:05 AM   #11
jkeaton's Avatar
$15.
https://www.amazon.com/Oxgord-Scanne...s=obd2+scanner
07 V6 Coupe
Old 08-13-2016, 10:07 AM   #12
Victoryrc's Avatar
Some good links,thank you.
$300 is more than I want to spend, I have to wonder if the $15 one is any good though.
looks like a big selection,thanks.
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 10:14 AM   #13
Victoryrc's Avatar
This looks nice, much more than I would ever need, however it looks like I can use it on a different car if I had to.
I have to assume it's a good brand..
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 10:33 AM   #14
jkeaton's Avatar
Obd2 is universal. Will work on all vehicles. I have one of those cheap ones I keep in the trunk. I also have a higher end actron one that will give me real time data if I want it. It's all about how much money you want to spend and what you want to do with it. Read reviews on the sites that sell them.
07 V6 Coupe
Old 08-13-2016, 10:52 AM   #15
With a sophisticated car like this, you need to be able to read PIDs, not just generic obd2 codes. If you balk at 300, you might as well buy a used, unmarried tuner, because it'll do that and offer the possibility of tuning later, if you want to.
Old 08-13-2016, 11:27 AM   #16
Victoryrc's Avatar
what are PIDS ?
Im only interested in fixing the car if I ever need to.
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 11:44 AM   #17
jkeaton's Avatar
No code reader will "fix" your car. It will tell you the code and you have to determine the type of repair. It will then clear the code when you have made the necessary repair. All you need is a cheap one. If you have no intention of ever doing anything else, one of those will suffice in your situation. You don't need a tuner and, you don't need to read PIDs (performance information data).
07 V6 Coupe
Old 08-13-2016, 12:02 PM   #18
Victoryrc's Avatar
Yes I know the code reader won't fix the car. .. I only wanted to read codes.
I can put in a crank sensor or throttle sensor if that's what it says to do.
Yep I don't need a tuner, I really don't want to reflash the computer.
I'm probably going to buy something for 50 bucks but I have to find a nice one
2017 Mustang GT
Blue coil covers.
Old 08-13-2016, 08:04 PM   #19
PIDs are parameter identifiers and are unique to the manufacturer and the vehicle. They tell you alot about unique things that obd won't.
You don't need to reflash anything use code reading on a tuner.
Old 08-14-2016, 12:26 AM   #20
Region: New Mexico
Look up an app by the name of "Torque" and buy the $20 Bluetooth OBD2 reader. I use it exactly for what you're talking about.
PIDs are nice for trouble shooting but not a must. Even if you want them though the app and reader will let you watch them.
Believe me, look into it.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 08-14-2016, 12:42 AM   #21
Victoryrc's Avatar
Thank you all, I have no idea what a PID is, I'll have to figure that one out.
Now the hard part is to find a nice code reader.
2017 Mustang GT
Blue coil covers.
Old 08-14-2016, 09:07 AM   #22
PID, (parameter identifiers) are used more for tuning but are real time info on what's going on inside the engine. You can datalog them and inspect at your leisure.
Old 08-14-2016, 11:33 AM   #23
Victoryrc's Avatar
I wouldn't know what I was looking at, give me a code number and I'm thinking if I bought a sensor I will be back in business.
Some of these diagnostic scanner I believe offer some kind of diagnostics but I'm not sure .
2017 Mustang GT
Blue coil covers.
Old 08-14-2016, 11:37 AM   #24
Victoryrc's Avatar
At this time this is the one I like the best, but it's a lot more than I need.
Innova Electronics Corp 3130E OBDII Diagnostic Code Scanner Brand New | eBay
2017 Mustang GT
Blue coil covers.
Old 08-14-2016, 11:58 AM   #25
jkeaton's Avatar
Innova makes some good ones. You can't go wrong there.
07 V6 Coupe
Old 08-14-2016, 12:47 PM   #26
Region: New Mexico
Your smartphone is nicer than ANY reader, and smarter too. No need for more.
If you spend more than $25 ($20 for Bluetooth OBD2 reader, $5 for the Torque Pro app, and $0 for the phone you already have [heck up give you one of my old phones if you pay shipping]) you are just wasting money for your described needs. The Pro app will do more than you need. I used it for data logging when I tuned my last car.
Unless you just want a name brand handheld unit that is useless for any other duty, at least look at it.
I hate to push so hard but I also hate to see you use money on that when it could be on parts, or even a date with your lady. Anything but paying 5x the price you should to accomplish the same end result.
Old 08-14-2016, 12:54 PM   #27
jkeaton's Avatar
^^ this is true. I have not made the jump to that app yet cause I have good hand held ones that I got years ago before there was such a thing a torque. I agree completely. OP, get the app and the adapter. Done.
07 V6 Coupe
Old 08-14-2016, 02:57 PM   #28
Victoryrc's Avatar
I have a piece of **** TracFone instead of a $100 a month bill. LOL
2017 Mustang GT
Blue coil covers.
Old 08-14-2016, 03:00 PM   #29
Victoryrc's Avatar
I also don't have access to the Samsung apps, torque is not in the Apple apps.
I was looking at it on YouTube, it's basically just a cordless reader.
But you never know if I can find something nice for 50 I'm just gonna buy it.
2017 Mustang GT
Blue coil covers.
check engine
Diagnostic Code P0455 & P0411 Hensonjames Pre-2005 V6 Mustang 3 10-17-2012 10:33 PM
Is this diagnostic code reader worth getting? scorpiouno 2005-2010 V6 Mustang 2 09-09-2011 04:19 PM
Diagnostic Trouble Code?? TafoyaMNAA Pre-2005 V6 Mustang 6 06-03-2007 10:49 PM
Diagnostic code P0455 LarryB Pre-2005 V6 Mustang 19 12-11-2005 03:17 PM
11:36 AM
