Squeaking clutch pedal - Mustang Evolution
Old 08-13-2016, 12:38 AM   #1
stangbaby13's Avatar
My clutch pedal is squeaking when I press and or release it!! Help
stangbaby13 is offline   Reply With Quote
Old 08-13-2016, 08:06 AM   #2
jkeaton's Avatar
Find out where it is squeaking and then lubricate it. Pretty simple.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-14-2016, 05:22 PM   #3
94gtconvert's Avatar
Woah hold the car wash. It may not be the actual petal or even the mechanism. I found that when ever if put my clutch in it would make a squeaking noise. Turned out to be my seat. Try ratcheting the seat up a few pumps with the long lever on the side and see if the squeak goes away. For whatever reason the drivers seat squeaks on my car if it's all the way down low as it goes. If you have power seats try just raising it and inch or two.
94gtconvert is offline   Reply With Quote
Old 08-14-2016, 06:40 PM   #4
jkeaton's Avatar
Assuming it has that kind of adjustment. My seat is all electric.
07 V6 Coupe
Old 04-15-2017, 11:13 PM   #5
Boss302PR's Avatar
There is a TSB for this condition
https://latemodel.cachefly.net/downl...sb12-06-11.pdf
"Lubricate both the assist spring pivot shafts and the main pedal pivot shaft using Motorcraft Silicone Spray Lubricant".
Boss302PR is offline   Reply With Quote
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 04:21 AM
New clutch squeaking noise pony5.0 1979-1995 Mustang GT 6 05-02-2016 04:54 PM
Clutch Pedal to Close to the Brake Pedal S Marquard 2011-2014 Mustang GT 1 03-28-2016 10:21 AM
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-04-2015 12:47 AM
Clutch squeaking Myles 1996-2004 Mustang GT 4 01-04-2011 08:46 AM
05:02 PM
