What clutch is good to upgrade to? - Mustang Evolution
Old 08-17-2016, 03:11 PM   #1
blmustang01's Avatar
I am thinking of upgrading to this clutch over stock. Is it good? Exedy Mach 500 Stage 3 Mustang Clutch 07807LB (11-14 GT) - Free Shipping
What flywheel should I get though? I want something not too expensive.
2010-2014 Mustang Flywheels | AmericanMuscle | Free Shipping
I believe the clutch is ready to go. I have always had some kind of issue with clutch. Clutch pedal/car will shudder like it's stalling when launching in 1st gear. Too much rpm in 1st gear and it launches too hard. The amount of work with clutch now vs when I first got the car is day and night. I have slightly softer pedal feel but still firm. Only issue is significant amount of power loss during rpm climb. Never any grinding of gears, smooth shifts.
2013 mustang gt/leather/pony projection/gt500 axle backs
blmustang01 is offline   Reply With Quote
Old 08-18-2016, 08:48 PM   #2
I'm in the same boat. I've been reading about the exedy Mach 500. It seems to be a good balance from the reviews as far as performance and daily type drivability.
Chris13 is offline   Reply With Quote
Old 08-19-2016, 04:09 AM   #3
Funny thing is car feels better than yesterday but it's just a matter of time before clutch goes out, I had so much power loss esp in 3rd gear so I am staying under 3k for a while now. I also have several 93 octane tunes from different companies plus a tps booster. Yeah, I believe worn clutch is the result for the power loss.
Found this flywheel that I think I'll get with the Mach 500.
Exedy Lightweight Racing Flywheel 8 Bolt Billet
https://lmr.com/item/EXD-EF502/Exedy...-Mustang-96-14
Old 08-19-2016, 06:30 AM   #4
Sterlingbeast5.0's Avatar
Go with McLeod! I had the Exedy Mach 600 and lightened steel fllywheel. I had to switch to the McLeod RXT when I tranny swapped and even though transmission is different not apples to apples I like the McLeod a TON better. TON. Even installer who does all my stuff mentioned the difference when I picked it up
Sterlingbeast5.0 is online now   Reply With Quote
Old 08-19-2016, 02:37 PM   #5
Beviking's Avatar
Haven't needed a clutch yet but I have my sights on the McLeod RST. Talked with rep at the AM show and he said what I've read numerous times...break it in right and it'll be golden. They had a car there with the RST in it and let me try it. It was like the clutch in my Focus!!! I was like "is this thing on!?!". I heard they were lighter than stock but dang, that was light light!
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 08-19-2016, 03:47 PM   #6
The McLeod clutch looks really nice, talk about pricey though. No wonder it works like a dream. Must be that extra disc. Yeah break it in gently under 3k for first 500 miles. I might get that I don't know yet depends how long my clutch will last. Clutch pedal is certainly softer and clutch engagement seems it is slightly slipping. Car certainly has it's issues and I don't even abuse the thing much. Like all the time when shifting to 2nd, release clutch, press accel pedal, I can feel and hear the trans hitting the shifter or maybe it's the driveshaft. I feel confident the car needs new clutch/flywheel. It's to the point where I would get an auto after the car is paid off and get similar to what I have.
Old 08-20-2016, 07:23 AM   #7
Beviking's Avatar
No doubt it's an expense! I don't have comparative experience but instances like this, I tend to favor quality over price b/c it's not something you're going to swap out anytime soon and you want it to last a long time. Not saying anything against Exedy either b/c I don't know. If you're thinking of trading for an auto then the cheaper (cost wise) solution is probably the wiser choice for you.
Old 08-27-2016, 12:42 PM   #8
jordan16's Avatar
http://www.americanmuscle.com/exedy-...-kit-1114.html
I just recently put this clutch in my 2014 Gt and I love it! It grabs hard and for being a stage 3 it is not that much stiffer. I would recommend if you do get this clutch then also get the matching flywheel made by Exedy. You can resurface your stock flywheel but if you are going to replace the clutch you might as well do it right and also get a new flywheel.
jordan16 is offline   Reply With Quote
So I did some research for a good stereo upgrade at a good price Josh_101 Mustang Audio & Video 1 12-24-2014 04:04 PM
clutch upgrade chefron50 2011-2014 Mustang GT 4 07-13-2014 07:22 PM
For Sale: BNIB: JPC 2005-2014 GT/GT500/BOSS BLACK Clutch Line Upgrade ThinBlueLine Mustang Parts for Sale and Wanted 9 07-11-2014 08:37 PM
what clutch should upgrade to 97 gt? jaydogg209 1996-2004 Mustang GT 6 08-14-2013 07:17 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
10:19 PM
