Best option for a drag set up? - Mustang Evolution
Old 08-24-2016, 11:09 AM   #1
2014oxstang's Avatar
Hello all, after my horrendous day at the track last week, I'm ready to get some serious rubber and some lightweight drag wheels. I'm pretty much set on a pair of dark stars. Now, a few of my questions are, should I go with a 15x8 and play it safe, or should I relocate the sway bar out back and go 15x10.5. Second question is what should I run for a tire, and how wide and sidewall? The car is a 6 speed, 3.73's, lowered an inch and a half all around, and vortech'd at 6 pounds. My initial thought is a 15x8 with a 275/60/15, but I just want a little input from people who may have this exact set up. Thanks in advance gents.
Eric,
2014oxstang is offline   Reply With Quote
Old 08-24-2016, 11:13 AM   #2
Eric,
Name:	ImageUploadedByMustang Evolution1472055095.132653.jpg
Just a pic for refernce. The car is low on Koni suspension and BMR control arms currently. Will be picking up some Strange adjustables. I'm more concerned with clearance issues than anything honestly.
Old 08-24-2016, 06:34 PM   #3
Bump. Really? Nobody has any decent suggestions?
Old 08-24-2016, 11:16 PM   #4
gqsmash's Avatar
Id go 15x8 with a good bias ply tire, since you are 6 speed. Too big of a good tire will most likely make you bog down unless you have some gears.
gqsmash is offline   Reply With Quote
Old 08-25-2016, 05:06 AM   #5
Grabber Blue5.0's Avatar
Definitely a 15x10 with a full slick. But the 3.73's are hurting you with the blower.
Old 08-25-2016, 05:49 AM   #6
Yeah, like I said in my OP, I was thinking along the lines of a 15x8 with a 275. 50 or 60 sidewall? And suggestion for a particular tire?
I know the 3.73's aren't ideal for the blower, should've stuck with the 3.31's but that would've been no fun while I was stock lol. You think wider is better in this scenario grabber? I'm also worried about clearance like I said. I'm pretty low as I sit currently. What would suggest for a tire in particular? Mind you this will be a dedicated track set up. I was told a DR would be better for a 6spd but you think a full on slick would be better? Sorry for the noobness here...
Old 08-25-2016, 07:59 AM   #7
Softer sidewall is better on a stick car.
For driveability I run a 275/60-15 ET Street Pro on 15x8 on my Cobra. Leave on the 2 step at 4000 and have zero traction issues.
With a bias ply I would bump the launch up to 5500 or 6000 and shave another .5 seconds but I like being able to cruise with no worries.
With correct suspension there is no reason you can't dead hook on a 275 width tire.
Sent from my XT1045 using Tapatalk
Old 08-25-2016, 08:02 AM   #8
I'll add if it's truly a dedicated track setup go with a m&h cheater slick or hoosier quick time pro and let it eat. You will want something narrower on the front with either of those as you will have sway on the big end.
Never steer to correct the sway, keep the front wheels pointed where you want to go.
Old 08-25-2016, 08:07 AM   #9
Revvv's Avatar
You can make the 3.73s work. It will take a little more effort and a dialed in set up to launch, but it can easily be done. Plus right now you are only running 6psi. You have gained a bit more HP, but you haven't jumped into an extreme range yet. Keep making trips to the track and you will keep adding more power. It's addicting.
Old 08-25-2016, 08:13 AM   #10
Wider isn't always better. A 275/60-15 will work good. Also it should be on a 15x10, not a 15x8. Better contact patch plus the 15x8's stick out some from the wheel wells and you could have rubbing issues.
Manual needs a slick, not a drag radial. Drag radial + manual + power=broken parts.
Old 08-25-2016, 08:54 AM   #11
That ET street pro looks pretty perfect for my particular set up. Keep in mind I'll be swapping out the tires at the track so there will be no miles on them other than the actual passes. Looks like it'll be soft enough to hook without being a full on slick. Think I may go this route. I only put down 460/390 on a low reading mustang dyno so I think I may be ok. Stock pulley obviously.
Old 08-25-2016, 08:57 AM   #12
Crap, I just saw this post. So what do you suggest for a tire grabber? And 15x8's stick out further then the 10's?
Old 08-25-2016, 09:01 AM   #13
275/60-15 ET Pro on 15x8 racestars. 18 psi. 4000 2 step launch. 490/490. 4.10 gears.
Traction is not an issue.
Old 08-25-2016, 09:02 AM   #14
Revvv's Avatar
Just drive train stuff. Who really needs a drive shaft, or the tail shaft on a transmission?
Old 08-25-2016, 09:04 AM   #15
Revvv's Avatar
The offset of the wheel is different. The 10" wheel tucks under the car more.
Old 08-25-2016, 09:14 AM   #16
If it breaks it was meant to be upgraded anyway.
Old 08-25-2016, 10:00 AM   #17
I have an upgraded shaft masters 1 piece as well forgot to mention that. I just want a tire that'll grab, possibly without destroying everything lol. Doesn't need to be extreme, just something to cut a sub 2 second 60. 2.2xx currently on all seasons lol
Old 08-25-2016, 10:05 AM   #18
True
The M/T ET Pro is also a great tire and essentially a slick even though it's called a radial.
Old 08-25-2016, 10:22 AM   #19
True
I think that's what I'm leaning towards grabber. You think it'll suit my needs? Not a crazy 3 season dragger, but I like to get down to the strip a few times during the summer and let her rip.
Old 08-25-2016, 11:26 AM   #20
That tire will work just fine for you.
Old 08-25-2016, 11:41 AM   #21
Ok cool. Thank you all for your input.
Old 08-25-2016, 12:50 PM   #22
Fabman's Avatar
Dr's with an auto, Bias play with a stick. Word.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 08-25-2016, 01:28 PM   #23
2014 setup
Im also pretty new to this, but have a similar setup to yours.
2014 gt, roush stage 1 kit, 465 rwhp, 440 tq. 3:73 ford racing gears, ford racing short shifter. American muscle track pac wheels 18x10, 305/40-18 mickey Thompson et street SS on the back. I got about 15 runs in now, getting 12.4s to 12.6s at about 115mph. Tires are sticking, nothing broken yet, knock on wood. in 2 weeks im having rear upper and lowercontrol arms, eibach pro kit springs, and a panhard installed. I want to get my car in the 11s. Next summer: aluminum driveshaft, roush stage 1 to stage 3 upgrade kit, then im hoping to be done!!hahahah
rmoeslein is offline   Reply With Quote
Old 08-25-2016, 01:38 PM   #24
Not bad man. Yeah my best time was a 12.4 @ 121. Car def has mid 11's in it, just need the right tire and a good 60 ft. I have all the suspension and driveshaft modifications. I do need to swap out to some drag shocks though. That run was also ran with my heavy 19's.
Old 08-25-2016, 03:21 PM   #25
Revvv's Avatar
Exactly. That's what I used as an excuse for more parts when I was racing bikes.
Old 08-25-2016, 03:23 PM   #26
Revvv's Avatar
The all season tires are a large problem in your 60ft.
Old 08-25-2016, 04:48 PM   #27
For sure brother. I knew that would be. This last time out was just to see what I'd trap. I just need something with some good bite.
Best Spring Option and Install Smoked50 2015 Mustang GT 5 07-09-2015 06:54 PM
Best under 1500 wheel/tire option? Jvibe92 2011-2014 Mustang GT 15 04-13-2015 07:00 PM
01 Cobra Drag set up questions rinfield2004 SVT Mustang 4 07-26-2014 08:37 AM
1999-2003 is it the best option for splitport conversion+ windstar intake? lemons95 Pre-2005 V6 Mustang 6 06-11-2014 09:36 PM
Good drag set up rims and tires? Rs3Rkw Roush Mustang 4 03-05-2014 11:41 AM
09:45 AM
