UCA Adjustment problem - Mustang Evolution
Old 08-27-2016, 02:00 PM   #1
tsidewayz's Avatar
Good afternoon,
Ok, I installed my BMR UCA and Adjustable mount. Initial set up was set to the same length as the stock UCA and the hole closest to the mounting plate was used on the mount. After the install I took the measurements. As recommended by many I used the bottom edge of the pinion flange and back driveshaft close to the mounting flange. The numbers I came up with were +3 on the pinion and +3.5 on the driveshaft. I loosened the lock nuts and made the adjustments. The best I could do was to get the pinion angle to 0. This leaves me short of the recommended settings of -2. Any suggestions of what I may have missed or what I can do to get it closer.
I'm lowered with Roush springs and I loaded the rear suspension when I measured.
Thanks.
Boss 302 Intake, 85mm throttle body, JLT Carbon fiber CAI, Magnaflow O/R X-pipe, Roush Axle back, Barton Shifter and bracket, See "My Garage" for an extensive list of mods.
2016 Challenger SRT 392
2010 Challenger RT
tsidewayz is offline   Reply With Quote
Old 08-27-2016, 03:27 PM   #2
I don't see how you could get +3.5 on the driveshaft. It's already pointing negatively (downward). Check your measurements.
2014 Premium GT, SGM, Brembo, Auto, Tech, Comfort, etc. GT500s, Steeda UCA, VMP auto N/A tune. 100 shot nitrous on BBR tune. Best e/t 11.42 at 120.64
Old 08-27-2016, 04:55 PM   #3
tsidewayz's Avatar
Ok, that's what I'm missing. When I reviewed the videos they were doing the measurements standing on the driver's side. I did mine on the passenger side. When I compared the direction of the needle I didn't realize it's actually backwards from their orientation. So, you are correct. Mine is at -3.5. So, now the problem is potentially too much negative angle.
2010 Challenger RT
UCA Adjustment Help Fax22 2011-2014 Mustang GT 6 03-03-2016 09:40 AM
For Sale: BMR Rear suspension UCA, UCA mount, LCA, Brackets, PHB MOOSEDAWG29 Mustang Parts for Sale and Wanted 11 10-23-2015 02:14 PM
Clutch adjustment (2001 stang) cagedthought Pre-2005 V6 Mustang 7 03-27-2005 09:49 AM
throttle adjustment question V6Stang33 Pre-2005 V6 Mustang 17 03-07-2005 03:15 AM
» Members Mustangs
Ruby
JAC20
2014 Ford
rawgt6
Add your Mustang
08:01 AM
