14 GT Recaros into 12 GT - Mustang Evolution
Old 08-30-2016, 12:45 PM   #1
I spend a few hours searching on the forum here, and it seems like it's more than just a swapping the seats and connect the wires. Although they share the same seat brackets and the wire connectors, they throw the airbag light after installation if the sensing bladder and wire connector is not swapped with 13-14 year ones? is that right? I mean if the air bag doesn't work properly after the installation, then it is not worth it for me so..
Also, how hard/bad is the whole installation process?
Please let me know if anyone knows aboutthis.. thanks in advance
taek_boss is offline   Reply With Quote
Old 08-30-2016, 11:35 PM   #2
anybody?
Old 08-31-2016, 01:34 PM   #3
tezz's Avatar
I have a 13 GT - I found a set of factory leather recaros off Craiglist and installed them with no issues whatsoever. They bolt right in - wires snapped together - no airbag fault codes.
Mind you I haven't crashed the car to test them yet...
2013 Ingot GT, 6M, FRAA Susp, GT500 Axle Backs/Wheels/Spoiler, Baer/Shelby brakes, Recaros, Trac-Cal, etc.
tezz is offline   Reply With Quote
Old 08-31-2016, 01:39 PM   #4
tezz's Avatar
Oh - easy install - plastic rail covers slide off backwards in the back, 4 bolts each, one wire connector ( DO NOT FORGET to unclip the wires before lifting out the seat - duh)
Old 08-31-2016, 01:41 PM   #5
I swapped 13 Recaros into my 2012, and I have the airbag light and so does the guy I swapped with. We need to take the seats apart and swap the occupant sensors to fix the issue. That being said, I still love the **** out of these Recaros, and it was worth it.
2012 Kona Blue GT 6M 11.80 @ 116
Koni STR.t shocks/struts, Steeda springs, BMR LCA, and Panhard bar, BBK off road X-pipe, Pypes axleback, whiteline shifter/trans bushings, Bama 93r tune, JLT CAI, Barton shifter, Shaftmasters 1 piece DS, CHE axle brace, factory HID conversion, and track pack Brembo and Recaro swap
Dave M is offline   Reply With Quote
recaros? 13 stang22 2011-2014 V6 Mustang 25 03-21-2013 07:38 PM
Recaros? Mustang32Bill 2011-2014 Mustang GT 1 01-25-2013 01:31 PM
To get recaros or not? SSTHIS 2011-2014 Mustang GT 23 06-02-2012 08:47 PM
FRPP Recaros Napoleon85 2011-2014 Mustang GT 14 04-10-2012 11:23 AM
Check out the newest Recaros Brent The Bar 17 09-13-2006 07:51 AM
07:22 PM
