corrosion - Mustang Evolution
Old 09-07-2016, 07:18 PM   #1
blackie's Avatar
corrosion
checked my battery terminals, 2014 GT, lots of corrosion
on the positive side some on the negitive.
can I remove the positive side for cleaning or will I get a code light?
blackie is offline   Reply With Quote
Old 09-07-2016, 08:32 PM   #2
No. It will not trigger a code.
Disconnecting the battery is actually a method used to clear all of the codes.
Old 09-08-2016, 07:28 AM   #3
Except it won't clear hard fault codes.
However, you should investigate why this is happening. I bet the battery is leaking a little around the terminals. You may wish to just replace it rather than risk paint or other surface damage from the acid.
Baking soda and water cleans the crud off good. Dielectric grease or vaseline helps prevent its formation.
Old 09-08-2016, 06:48 PM   #4
blackie's Avatar
Just finished cleaning the positive terminal, not easy as it may seem.
Ive cleaned a lot of battery terminals in my life and this was the worst
stupid design there's a bracket with like 5 other leads going off it.
all coroded, its really intricate and hard to clean. Made a big mess.
and I stuffed rags all around it.
tools used:
wire brush, tooth brush, batery brush,8mm and 9mm socket wrench.
Rags, baking soda/water, small screwdriver for scraping.compressed
air. Battery grease for re install.
Good news: the car started right up no problem.
There looks to be be no leaks.
Old 09-13-2016, 01:42 AM   #5
kikker's Avatar
Lots of corrosion can sometimes mean your battery is fixing to go Bad. Especially if the car is fairly new. It wouldn't hurt anything to have your battery load tested.
kikker is offline   Reply With Quote
Positive battery terminal corrosion dee_gt 2011-2014 Mustang GT 32 10-20-2017 12:46 AM
battery terminal corrosion can i use these terminals instead of replacing harness? blmustang01 2011-2014 Mustang GT 11 07-20-2016 05:31 AM
Corrosion Jon Al Mustang Paint, Appearance & Detailing 15 06-16-2016 04:05 PM
Corrosion on Battery Terminal sbbamafan 2011-2014 V6 Mustang 30 01-23-2016 10:10 AM
Extremely bad corrosion! Mustang81596 Mustang Paint, Appearance & Detailing 13 05-22-2013 08:46 AM
01:48 PM
