Drag Race Tire Pressure?? - Mustang Evolution
Old 09-15-2016, 12:26 PM   #1
Sterlingbeast5.0's Avatar
Is there a good rule of thumb? I am going to the track next weekend and it will be the dirst time I am using Drag Radials. I have 285 40 18 NITTO NT05R. I know it will be a busy night at the track and I would love advice on a good place to start with tire pressure for first run
Old 09-15-2016, 02:55 PM   #2
Grabber Blue5.0's Avatar
Why are you using drag radials with a manual? Are you just begging to break something? Don't air them down to much.
Old 09-15-2016, 03:14 PM   #3
crjackson2134's Avatar
I'm not a racer, so be nice... but... are you saying this because the DR's hook really hard and cause a lot of driveline shock?
Just curious...
Thanks
2014 Black GT Premium - Track Pack - (Apocalypse)
2018 Black Nissan 370Z Nismo - (Lucille-2)
crjackson2134 is offline   Reply With Quote
Old 09-15-2016, 08:06 PM   #4
JimC's Avatar
Drag radials don't have as much "give" as a set of bias ply tires. That is why people with manuals tend to use the bias ply racing tire. At launch, the side wall wrinkles to lessen the shock on the drive train.
But bias ply tend to "dance" when you get to the traps. Quite unnerving to feel like the back end is swaying all over until you get used to it. Run bias tires up front and it eases the dance; don't run bias and radials.
JimC is offline   Reply With Quote
Old 09-15-2016, 10:05 PM   #5
I understand, thanks for the explanation.
Old 09-16-2016, 06:54 AM   #6
noldevin's Avatar
Unless you baby your launches (then what's the point of running DRs?), you will inevitably break something in your driveline running drag radials with a manual.
noldevin is offline   Reply With Quote
Old 09-16-2016, 07:31 AM   #7
Start at 22-23 and move up until you spin. The NT05 is not a true dr so they may not take a hit too well.
Old 09-16-2016, 12:22 PM   #8
Mimi15GT's Avatar
Probably run with 18-20 psi....I'm slowly getting my car prepped before I hit the strip with the same drag radials. I already have the aluminum driveshaft, and getting upgraded half shafts soon. Stiffened up the suspension so far with the wheel hop elimination parts, which has worked. Then trrack time to try and beat my Crossfire SRT6's time of 11.7 @116 mph. Good luck....
Mimi15GT is offline   Reply With Quote
Old 09-16-2016, 12:43 PM   #9
I do have BMR UCA, LCA and LCA brackets. Panhard bar and aluminum one piece shaft. I see guys all time who daily NT555r no issues.
Sent from my SM-G930P using Mustang Evolution mobile app
Old 09-16-2016, 03:05 PM   #10
32VALVR's Avatar
I run NTO5rs and they seem to work best for me at 16.5-17 lbs hot. I'm auto now, but ran them when I was manual as well.
03 Mach 1
Kenne Bell 2.1 Stock block, built 4r70w w/ Fairbanks, Accufab, SLP, Moser, 3.73, welded tubes, Trick Flow, Magnapack, Megabite Jrs, AFS
1/4 11.57@119.6, 1/8 7.4@95 on NTO5r dr's.
32VALVR is offline   Reply With Quote
Old 09-16-2016, 06:20 PM   #11
Thanks a ton man!!
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
Drag bash london drag strip in ky. This sunday 4/29/12 H.A.W.K At the Track 1 04-30-2012 01:37 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
NC, Mooresville Car Show / Drag Race KrazyPony The Bar 0 11-23-2003 09:09 PM
05:17 PM
