2013 GT Can I clean the Throttle Body and MAF Sensor - Mustang Evolution
Old 09-20-2016, 10:55 AM   #1
I have a 2013 GT Can i clean The Throttle Body and MAF Sensor?
5.OHBRUH is offline   Reply With Quote
Old 09-20-2016, 11:22 AM   #2
Senior Member
dgc333's Avatar
They actually sell a spray solvent that is specifically formulated for cleaning MAF sensors. I have always just used carb cleaner on throttle bodies.
dgc333 is offline   Reply With Quote
Old 09-20-2016, 12:08 PM   #3
So it wont mess anything up if i just clean the throttle body because awhile back i had a friend clean his 2009 chevy malibu throttle body and he messed it up and had to get his ecu reprogrammed?
Old 09-21-2016, 07:09 AM   #4
Region: West Virgina
I removed my TB to clean the carbon buildup, had no issues at all. Just make sure that the O-Ring is properly seated if you take it off.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 09-21-2016, 07:48 AM   #5
Don't use carb clean, it's too aggressively caustic for TB or maf use Use maf cleaner, it's effective enough and totally safe. Unless you are encountering idling or low speed drive ability issues, it's probably unnecessary.
Old 09-26-2016, 07:42 PM   #6
k1DBLITZ's Avatar
I've personally cleaned my own MAF with MAF cleaner. No issues.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 09-27-2016, 06:52 PM   #7
InfinibandGT's Avatar
I'm surprised a 2013 would need a MAF cleaning unless you have high mileage or a problem with your air filter.
InfinibandGT is offline   Reply With Quote
Old 09-27-2016, 08:51 PM   #8
k1DBLITZ's Avatar
I had to clean mine because oil from the filter got on the MAF sensor.
Old 09-27-2016, 09:26 PM   #9
Ah, maybe you are running a K & R filter. I had one in a 2012. Didn't like it and switched back to paper.
Or you have an aftermarket cold air intake.
I haven't found anything better than the stock air box and the paper filter. I was surprised that the paper filters are not that expensive here.
The oiled filters are a pain in the ***.
What size MM MAF meter and throttle body do i buy? Sybesma07 1979-1995 Mustang GT 0 09-30-2013 11:58 PM
Clean your Throttle Body BaSohol 2005-2010 Mustang GT 13 12-07-2012 12:08 AM
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
Cai and tune .. New MAF sensor Damnyer 2005-2010 Mustang GT 9 06-21-2012 08:06 PM
What should I use to clean the throttle body? blue95stang General Mustang Discussion 8 07-15-2008 08:12 AM
12:56 AM
